Opinions on replacing AW4 transmission fluid - Page 2 - JeepForum.com
post #16 of 65 Old 02-04-2009, 10:36 AM
justanotherjpr
I use regular fluid instead of synthetic because I can afford to change the regular fluid at reasonable intervals. IMO, fresh regular fluid is better than old synthetic fluid. YMMV.
So do you actually hear your thoughts in your head or is it just sort of a dull roar before you smash your face into your keyboard and just submit whatever dumb **** ended up on the page?
justanotherjpr is offline
post #17 of 65 Old 02-04-2009, 11:19 AM Thread Starter
87warrior
87warrior's Avatar
The synthetic "no-no" is what I found when searching around for this topic. The general consensus is that if you have a high mileage AW4 that has never gone through regular flushings, it is best to stick with the conventional oil. I certainly do not understand the science behind it, but if folks have issues with synthetic in a high mileage AW4, I will take it for what is worth.
I just purchased the truck and it has 185K on the odometer... shifts fine as far as I can tell.
03
(Rubicon build)
92
(92/99 Comanche Project)
86
(Heavy Four)
87warrior is online now
post #18 of 65 Old 01-06-2010, 02:49 PM
Metzroth
I know this thread has been dead for months but I feel the need to chime in. If you go to the AMSOIL website and read about their universal ATF, one thing they mention is the "Friction Durability". The section reads: Todayís transmissions are smaller and must withstand higher horsepower and torque while delivering smoother shifts, all with longer fluid life recommendations. AMSOIL Synthetic ATF is formulated with friction modifier additives that deliver outstanding clutch-holding capacity (static friction), torque-transfer ability (dynamic friction) and anti-shudder properties (slipping torqueconverter clutches).
In other words, all of those ATF additives on the shelf at the auto parts store that many people add to their conventional ATF are not necessary in AMSOIL ATF because they are already there. We will see...I just ordered $230 worth of AMSOIL fluids to replace Trans fluid, transfer case fluid, front and rear diff lube, and engine oil.
2000 XJ Classic - 33" GY Duratracs, 15x10 Cragar V5s, Crown HD springs, Clayton adjustable shackles, OME Nitrocharger Sport Long Travel Shocks, JKS Discos, extended brake lines, 2" poly spacers in front with V8 ZJ springs, Powerslot Rotors, Hawk HPS Pads, Hella E-Code headlight housings, Narva 100/130 Bulbs, Olympic Top Hat Rack, etc.
Metzroth is offline
post #19 of 65 Old 01-06-2010, 06:44 PM Thread Starter
87warrior
87warrior's Avatar
Metzroth - I hope the Amsoil works out well for you. I, personally, am not an Amsoil fan. Most of their products have not been tested for the specification(s) they recommend the product for. I will only run a product that MEETS or EXCEEDS a specification, not RECOMMENDED for a specification. But hey, that is my philosophy, I do NOT want to debate Amsoil!
I simply replaced the fluid in the MJ back in February with generic Dex/Merc ATF. 10 months later I have had no ill effects.
03
(Rubicon build)
92
86
(Heavy Four)
post #20 of 65 Old 01-06-2010, 07:46 PM
Metzroth
All I hope for is atleast the same results and hopefully using superior products will give me a better chance to achieve those results.
Metzroth is offline
post #21 of 65 Old 01-06-2010, 09:20 PM
Kevin108
I've got something like 125,000 on mine and did the filter a few months ago. I was going to do a full fluid flush because my stuff was brown-looking. It didn't smell burnt but it didn't look ideal. I wound up just replacing the filter and topping off. I figure next time I change the oil I'll drain the trans pan and top off again. That'll make it mostly new fluid and the stuff that's in there is working great now. On the plus side, there was practically no material in the filter or on the magnets, so either it's all been done before or this transmission is holding up well.
But yeah, go for it. New fluid itself isn't going to hurt anything at all.
My build thread has pics again. http://www.jeepforum.com/forum/f177/kevin108s-2000-xj-build-867428/
Kevin108 is offline
post #22 of 65 Old 01-07-2010, 01:50 PM
Weebur
1997 XJ Cherokee
There's no disrespect intended for those with other opinions, but I went with the Chrysler engineers that recommend that the AW-4 trans now should use ATF+4 synthetic fluid. I changed mine out this past summer and its shifting fine, even during a 900 mile trip towing a heavy popup camper. Here's a clip I took from the Technical Service Bulletin:
NUMBER: 21-014-07
GROUP: Transmission
DATE: October 16, 2007
THIS BULLETIN SUPERSEDES TECHNICAL SERVICE BULLETIN 21-010-06, DATED APRIL 14, 2006, WHICH SHOULD BE REMOVED FROM YOUR FILES. ALL REVISIONS ARE HIGHLIGHTED WITH **ASTERISKS** AND INCLUDES THE ADDITION OF THE ASIAN WARNER (AW4) TRANSMISSION AND ADDITIONAL MODELS AND YEARS.
SUBJECT:
Automatic Transmission Fluid Usage ATF+4 (Type M59602)
MODELS:
1997-2006 (TJ) Wrangler
2001 - 2004 (WG) Grand Cherokee (International Markets)
Vehicles equipped with Gas engines
1999 - 2004 (WJ) Grand Cherokee
2005 - **2008** (WK/WH) Grand Cherokee
2006 - **2008** (XK/XH) Commander
1989 - 1995 (YJ) Wrangler
**1989 - 2001 (XJ) Cherokee**
**1989 - 1993 (MJ) Comanche**
1996 - 1998 (ZG) Grand Cherokee (International Markets)
1994 - 1998 (ZJ) Grand Cherokee/Grand Wagoneer
NOTE :**AWA (Asian Warner) transmission are now included in this Service Bulletin. ATF+4(R) is recommended for AW-4 (Asian Warner) transmissions**
Weebur is offline
post #23 of 65 Old 01-07-2010, 02:58 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
That Technical Service Bulletin gets mentioned often, but in the bulletin, there is no justification or reason given for the change in fluid specs. Most TSB's are released to address specific customer complaints or documented problems with a specific part or assembly.
Dexron-III/Mercon is what the original designers and manufactures of the AW-4 transmission specified and used, and Dex-III/Merc is inexpensive (unlike Amsoil) and readily available at any auto parts store, WalMart, and even the local grocery store has a few bottles. I prefer regular fluid changes instead of some expensive wonder fluid.
Why change what has worked well since the first AW-4 was installed in a Cherokee ?
CJ7-Tim is offline
post #24 of 65 Old 01-07-2010, 02:59 PM
Kevin108
Most of the time when people say they have problems from changing fluid or switching to synthetics, the whole story is they had problems before that initiated the chain of activities that led to the fluid replacement or switch and when the synthetic, the last step in the process, doesn't fix things, they blame it for everything. It sounds crazy, but I know all of you know somebody who thinks like that.
Kevin108 is offline
post #25 of 65 Old 01-07-2010, 04:13 PM
Weebur
1997 XJ Cherokee
Your points are valid. But it's well known that synthetic fluids flow better at low temps, and it gets very cold here (northern Illinois), that's the main reason I went with ATF+4. I would not have had I not stumbled on the FSB. I called my local dealer to confirm the bulletin and get their input...the service manager wasn't even aware of it.
I would like to know why they issued the bulletin, as you rightly say they usually issue bulletins to address problems.
Weebur is offline
post #26 of 65 Old 01-07-2010, 05:04 PM
Kevin108
I would call Aisin and ask them what to use in it.
AISIN U.S.A. MFG., INC.
1700 East Fourth Street
Seymour, Indiana 47274
Phone: 812-523-1969
Kevin108 is offline
post #27 of 65 Old 04-09-2010, 10:57 PM
Jeepman_97
So I stumbled upon this thread just in time. I will be replacing my transmission fluid in my 97 XJ Sport in the next few days. It has 181K and I have owned it since 113K w/o replacing the trans fluid.
I called a local Jeep dealer and was told to purchase ATF+4 fluid. I picked up a few quarts of Penzoil ATF+4 transmission fluid from a local parts store.
Is this the wrong type of fluid to use? Is it a problem if the current fluid is not ATF+4 and I mix it in?
Jeepman_97 is offline
post #28 of 65 Old 04-09-2010, 11:48 PM
filluptrk
I use a Multi Vehicle Fluid. It is sold by Pennzoil, Super tech(walmart) etc. Bit of a mixture of regular Dex and synthetic fluids. Works great in my 00.
The real enemy of AutoTrans is heat, not fluid types. If you really want yours to last a long time put a cooler on it. Phil
filluptrk is offline
post #29 of 65 Old 04-10-2010, 11:21 AM Thread Starter
87warrior
87warrior's Avatar
As stated above, Dexron-III/Mercon is what the original designers and manufactures of the AW-4 transmission specified.
For no apparent reason Chrysler decided to issue a TSB in the mid-2000's that suggested the ATF+4. Many agree that the ATF+4 is the WRONG fluid to use and may cause damage.
Pick up some Dexron-III/Mercon and be done with it.
03
(Rubicon build)
92
86
(Heavy Four)
post #30 of 65 Old 09-01-2010, 10:01 AM
praetorian
Quick question, why do some of you say that a transmission flush is bad for these transmissions?
I'd rather be judge by twelve than carried by six.
praetorian is offline
Replacing front & rear differential fluid? Mee_Too XJ Cherokee Technical Forum 38 02-12-2013 07:08 PM
replacing front diff fluid Cherokee98_4x4 XJ Cherokee Technical Forum 3 11-18-2009 03:32 PM
help Replacing Auto tranny filter and fluid motu1983 XJ Cherokee Technical Forum 14 10-06-2007 06:51 PM
Automatic Transmission fluid change, and Transfer Case fluid change questions. MageXX9 XJ Cherokee Technical Forum 4 04-28-2007 06:08 PM
Replacing transmission filter/fluid fourlow XJ Cherokee Technical Forum 8 02-18-2004 04:24 AM
