Opinions on replacing AW4 transmission fluid - JeepForum.com
post #1 of 65 Old 02-03-2009, 11:49 AM Thread Starter
87warrior
87warrior's Avatar
I finally have a Jeep with the AW4 transmission and have a concern. It is in a '92 with 185k on the odometer. Due to the fact the truck is 17 years old I am planning a fluid change for everything.
Should I change the fluid/pan filter in the AW4? If so, with what?
I recall that some folks suggest not to change the ATF in an auto with a lot of miles on it. Please school me on this.
Thanks
03
(Rubicon build)
92
(92/99 Comanche Project)
86
(Heavy Four)
87warrior is offline
post #2 of 65 Old 02-03-2009, 01:03 PM
98muddyjeep
rockin lil red wagon
98muddyjeep's Avatar
you should be ok changing the fluid and filter since when you drain the pan you only get half the fluid the other half is in the converter so the new fluid will mix with the old so you will be ok.Do not get a trans flush that can cause more problems than its worth.
ah,beer the cause of and cure to all of lifes problems ...Homer J Simpson... I am the guy in the red jeep!
98muddyjeep is offline
post #3 of 65 Old 02-03-2009, 02:14 PM
Jason, aka: Jeepin.com
Vendor
Jason, aka: Jeepin.com's Avatar
1995 XJ Cherokee
Ditto on all of the above.
Changing the filter is a bit of a paradox though. I don't think I've ever read where someone's changed the filter and looked at it and thought that it needed to be replaced, but at the same time, everyone, myself included, has always felt better having replaced the filter, even if it looked perfectly fine.
Some places are now offering a non-pressure flush, where the transmission itself cycles all the fluid -- it's not forced through under pressure. That's the only type of "flush" I'd ever consider doing, and you can do that yourself with a couple of buckets and a bunch of fluid.
Be sure to use Dex/Merc III type fluid and nothing else. It may be a "Chrysler" vehicle, but it does not have a Chrysler brand transmission.
Jason West -
'16 JKUR Hard Rock, RE/Synergy 3.5", 37" GY MTR/Ks
'95 XJ, RE 5.5", 35" MT/Rs, D30 w/hubs & ARB, D44 w/Detroit, 4.56s, C4x4 bumpers, etc, etc.
'00 TJ, SOLD, wife's, RE 4.5" long-arm, 35" MT/Rs, D30+OX, D44+ARB, 4.88s, full cage, winch, C4x4 & Jeeperman bumpers, etc, etc.
Jason, aka: Jeepin.com is offline
post #4 of 65 Old 02-03-2009, 02:24 PM
kadetklapp
1997 XJ Cherokee
Chry Co doesn't manufacture the AW4? Hmm, didn't realize that.
I use Dex/merc anyway.
What I have done with my 99 XJ is simply change it frequently using the handy-dandy drain plug. I gleefully use it as most all my mechanical experiance is with Chevrolets and in most cases you have to drop the pan on them. It's a real PITA.
Last summer when I bought my XJ the fluid was nasty, but the trans shifts fine. I went ahead and changed the fluid six times over the course of the late summer and early fall. In some cases I even got in the XJ and for a VERY short period of time would start it up and allow the pump to force some more fluid into the pan. I brightened the shade of red considerably using this process, and I never had to lower the pan.
**1997 Jeep Cherokee SE**
Former Police Car assigned to 54-26, RIP.
kadetklapp is offline
post #5 of 65 Old 02-03-2009, 03:09 PM
Vendor
1995 XJ Cherokee
Nope. The AW4 is made by Aisin AW (though it ceased to be called Aisin-Warner in 1987, coincidentially the same year that Jeep started using the transmission, and is now just Aisin AW). If anything, it's a "Toyota" transmission because it shares a lot of parts with the Toyota 450-43LE that was used in I think the Supra and 4Runner. Toyota also owns a majority stake in the company, but Aisin AW provides transmissions to just about every car maker.
http://en.wikipedia.org/wiki/List_of..._transmissions
Jason West -
post #6 of 65 Old 02-03-2009, 03:30 PM
kadetklapp
1997 XJ Cherokee
Wow I'll be darned!! Must be why the label on mine says something about Japan....
post #7 of 65 Old 02-03-2009, 03:52 PM
Vendor
1995 XJ Cherokee
Heh-heh, it's somewhat ironic that something considered one of the most bullet-proof parts on an XJ is actually made in Japan.
Jason West -
post #8 of 65 Old 02-03-2009, 04:07 PM
justanotherjpr
By the time you have the pan down and the filter out, you should be replacing the filter. It's cheap and the cost of the fitler and gasket kit isn't a whole lot more than the cost of just the gasket, if you can even get it. Use only Dex III in the AW4. May consider the transmission pump flush, but, as Jason said, do not use any machine that flushes under power.
So do you actually hear your thoughts in your head or is it just sort of a dull roar before you smash your face into your keyboard and just submit whatever dumb **** ended up on the page?
justanotherjpr is offline
post #9 of 65 Old 02-03-2009, 04:43 PM
tjwalker
It's the crank sensor!
tjwalker's Avatar
I've heard that before as well and I couldn't disagree more with it. It defies logic to leave old, dirty, worn out, burnt tranny fluid in a vehicle.
The AW4 has a drain plug on it. You can change out approx. 3 quarts of fluid by just draining the pan. Do it a few times over the next few months if the fluid looks bad or smells burnt.
If you're ambitious, drop the pan and clean or replace the filter which is basically just a screen. Most important thing though is to get some fresh fluid circulating.
Use Dex III fluid.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is online now
post #10 of 65 Old 02-03-2009, 07:12 PM Thread Starter
87warrior
87warrior's Avatar
Thanks for the help guys. This whole Auto thing has me running in circles!
Should the Dex III/Merc III fluid available at the local auto parts store? I know synthetic is deemed a "no-no" on a high mileage AW4.
I think initially I will simply drain and replace the fluid. After 6 months I will replace the filter and fluid.
03
(Rubicon build)
92
86
(Heavy Four)
post #11 of 65 Old 02-03-2009, 07:20 PM
Vendor
1995 XJ Cherokee
Dex/Merc III is a regular trans fluid, it should be available anywhere that sells vehicle fluids.
Jason West -
post #12 of 65 Old 02-03-2009, 07:55 PM
jjg214
why shouldnt synthetic dex/merc be used on a high mileage AW4?
jjg214 is offline
post #13 of 65 Old 02-04-2009, 05:31 AM
jjg214
anyone have a reason for me?
jjg214 is offline
post #14 of 65 Old 02-04-2009, 07:28 AM
tjwalker
tjwalker's Avatar
I have used synthetic transmission fluid (Amsoil) in my AW4 since the first service. I also use synthetic fluids in the differentials and transfer case. You will find many differing opinions on this. In my opinion, there isn't a right or a wrong answer.
There are people that claim that the synthetic fluid is actually "too slippery" for the AW4 but I haven't seen enough actual failure analysis to support that claim. Just because a transmission fails early and that individual was using synthetic doesn't necessarily mean that synthetic fluid was "root cause" of the failure. A certain percentage of anything as complex as a transmission will suffer premature failure no matter what fluid is circulating in it.
The AW4 certainly doesn't require a synthetic; plain old Dex III is much cheaper and works just fine with plenty of evidence of AW4 transmissions going 200-300k on conventional fluids.
However, there are a number of reasons that people "choose" to use a synthetic. To each their own. Use the SEARCH function for tons of light reading on this. No need to reinvent the wheel.
post #15 of 65 Old 02-04-2009, 08:22 AM
kadetklapp
1997 XJ Cherokee
I use plain Dex/Mex just because it's plentiful and cheap.
Some people believe that putting fresh fluid in an old transmission causes it to fail. The fact is, if the trans is slipping after fresh fluid, then the trans has been on it's way out for a LOOONG time. If it does slip, and you need to get a little more life out of it, then you can use a friction modifier in the fluid to help get "grip."
That's all it is. The old gritty fluid causes the stripped transmission to get better "grip" and when new fluid is injected, it starts to slip.
Replacing front & rear differential fluid? Mee_Too XJ Cherokee Technical Forum 38 02-12-2013 06:08 PM
replacing front diff fluid Cherokee98_4x4 XJ Cherokee Technical Forum 3 11-18-2009 02:32 PM
help Replacing Auto tranny filter and fluid motu1983 XJ Cherokee Technical Forum 14 10-06-2007 05:51 PM
Automatic Transmission fluid change, and Transfer Case fluid change questions. MageXX9 XJ Cherokee Technical Forum 4 04-28-2007 05:08 PM
Replacing transmission filter/fluid fourlow XJ Cherokee Technical Forum 8 02-18-2004 03:24 AM
