OOPS! Overfilled Tranny - JeepForum.com
post #1 of 13 Old 01-14-2013, 12:25 AM Thread Starter
aldersonfilm
Overfilled the fluid in my tranny. What's a good way to get the extra out, without having to drop the pan again and get a new gasket?
Anybody had success with a hand pump in the dipstick tube? I'm worried about getting a hose stuck in there.
aldersonfilm is offline
post #2 of 13 Old 01-14-2013, 04:40 AM
rugsucka
Assuming you don't have a drain plug (my '00 does) it's pump it or drop the pan.
If you are really bold, you could try to drain it a bit thru the radiator send/return lines, but I would expect a mess in your engine bay over that.
rugsucka is offline
post #3 of 13 Old 01-14-2013, 04:50 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Pull the plug.
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #4 of 13 Old 01-14-2013, 07:42 AM
Paradise XJ
1988 MJ Comanche
Originally Posted by cruiser54 View Post
Pull the plug.
...let it drain. Refill with 3~3.5 qts. Drive, and I don't mean just around the block, let it get warm, check level*, top off as necessary. If you only put in 3 qts. you'll probably only need to add 1/2 qt. after checking the level.
*Drive your Jeep until it gets up to operating temp under normal circumstances, park on level surface, keep it running. Check dipstick level. Should be AT full.
If it's reads ADD...you don't necessarily need to add a whole quart. You might want to drive it around, check it, add a 1/2 quart at a time and so on.
1990 XJ Laredo - White & Chrome
1988 MJ Pioneer - Metallic Green and Black
Paradise XJ is offline
post #5 of 13 Old 01-14-2013, 12:48 PM
biffgnar
biffgnar's Avatar
How much did you over fill it? Some transmissions don't mind or even work better (e.g. 42RLE in TJs) being a little over full. All suggestions (plug, pump, cooler hoses) will work. You decide what you are most comfortable with.
Romney in 2020!
biffgnar is online now
post #6 of 13 Old 01-14-2013, 09:28 PM Thread Starter
aldersonfilm
Don't have a drain plug. Wish I did. But some good suggestions. I think I'm gonna try and pump it out with a harbor freight syphon.
My friend changed the fluid and overfilled it by quite a lot. I discovered this while driving and it started surging and wouldn't go into gear as it warmed up. I'm hoping that it's because the level is high and not a worn band or something. It's also leaking around the pan. People say it will blow out the "vent." Where is this vent?
post #7 of 13 Old 01-14-2013, 09:44 PM
rugsucka
It can foam when overfilled and that will cause the mis shifts. The vent can blow out the excess and it will drip by the front of the transmission at the inspection cover. You can also blow out seals.
It is better to just get the level correct.
rugsucka is offline
post #8 of 13 Old 01-15-2013, 05:46 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
I've never seen an AW4 without a drain plug. Are you looking at the trans or transfer case bottom?
post #9 of 13 Old 01-15-2013, 10:41 AM
Kevin108
Pull the pan and add a plug if you don't have one. http://www.amazon.com/80250-Automati.../dp/B00029WR78
My build thread has pics again. http://www.jeepforum.com/forum/f177/kevin108s-2000-xj-build-867428/
Kevin108 is offline
post #10 of 13 Old 01-15-2013, 03:06 PM Thread Starter
aldersonfilm
Hey, what'd ya know! I have a drain plug! Look at that... Whoops! Well it's draining now. Found out it's been overfilled for almost a full year!!! The previous owner over filled it too! Man, I hope I didn't destroy the tranny.
post #11 of 13 Old 01-15-2013, 03:29 PM
Paradise XJ
1988 MJ Comanche
I don't think you have to worry about hurting the tranny, per se, with too much fluid. The peril is having tranny fluid overflowing, spewing, out of the fill tube, gooping up your underside OR pouring on your hot exhaust... and leaving a smoke screen down the road or worse yet catching on fire.
The total capacity for the tranny is ~8-9 qts. The majority of that is held inside your torque converter etc. A simple drain and fill is ~3.5 qts.
post #12 of 13 Old 01-15-2013, 09:21 PM
Kevin108
I spent a whole day riding around trying to find a drain plug to add when I was doing the filter on mine. I felt like a fool when I dropped it and it had a factory drain.
The problem with overfilling is froth, as I've read. Apparently when you have too much fluid, it winds up in places it shouldn't and gets whipped into a foamy mixture that doesn't work the same as unaerated liquid fluid will. I think this was an issue on 700R4s but may or may not be the case for our AW4s.
Kevin108 is offline
post #13 of 13 Old 01-16-2013, 04:38 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Drop th eplug and drain it. 3.8 quarts to refill. Always a good idea to replace the drain plug crush washer to prevent leakage.
transmission , transmission fluid , transmission fluid level
