Only starts on second try - JeepForum.com
post #1 of 16 Old 06-29-2006, 10:18 AM Thread Starter
fossill
I've had this problem as long as I've owned this jeep, bought it used in 04. The first time I try to start it, it'll just crank away and I won't get the engine to turn over. So I stop after a few seconds and try again, bingo! Always. Cold start, warm start, all types of temperatures and weather, its all the same. Any thoughts?
1998 XJ Sport
Completely Stock Suspension
TB spacer + cone
30x9.5x15s
fossill is offline
post #2 of 16 Old 06-29-2006, 10:26 AM
AznDrgn
Have you tried turning the key to the on position and leaving it for a few seconds and then starting it? Or turn the key on and off a couple of times then start. Mine did that for a while before I changed the fuel pump, was probably the check valve in the pump not holding prime and the fuel system needing to reprime before it starts.
'87 Jeep Cherokee Laredo 4.0L, NP231, AW4, 5.5" lift, s10/waggy/XJ bastard pack, 7" fabtech TJ coil springs - Weekend play thing
'83 Porsche 944 2.5L Callaway turbo - Daily driver
'81 Porsche 924 - Custom EFI and forced induction project
'83 Porsche 944 2.5L - Sold
'78 Porsche 924NA 2.0L - RIP
AznDrgn is offline
post #3 of 16 Old 06-29-2006, 10:28 AM
XJH-007
XJH-007's Avatar
Whoa...strange.
When you turn the key over the 1st time can you hear the fuel pump energize??
Could be a problem with the Fuel/Oil pressure relay. If the CPU detects lack of oil pressure it will shut off or not engage the fuel pump (incase the vehicle is rolled in a firey accident).
So by cranking you are pumping up the oil pressure, then the 2nd time the CPU see's the pressure and kicks the fuel pump on........
Scott-Crawlorado Native
I have an addiction.....
*00' XJ_T-n-T Y-Link/6" RE_OME's_33" KM2's
Tera 4:1 / 4:56's_Elec. Locked D44
**84' CJ7 4"BDS 33's
***02 WJ Overland
XJH-007 is offline
post #4 of 16 Old 06-29-2006, 11:31 AM
chowner
2014 WK
CPS, mine does the samething sometimes too.
chowner is offline
post #5 of 16 Old 06-29-2006, 12:22 PM
winks00XJ
winks00XJ's Avatar
I used to have the same problem, wouldnt start on the first crank even though I would hear the fuel pump. It would start on the second crank. I replaced the fuel pump and the problem went away.
winks00XJ is offline
post #6 of 16 Old 06-29-2006, 12:47 PM
jrn1023
I'll add another vote for the fuel pump(more specifically the regulator which is part of the fuel pump module). On our `98 it would crank and crank. Turn the key off and on again and it would then start. Had a mechanic friend put a fuel pressure gauge on it and you could see it was not getting up to full pressure. Turning the key on and of a few time before cranking would cause the pressure to build enough to start. Replace the fuel module/pump unit and all is well. Oh, and leaving the key in the on position for a few seconds before cranking would not work for us since the pressure would begin to drop almost immediately after turning the key to the on position.
jrn1023 is offline
post #7 of 16 Old 06-29-2006, 01:04 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
1997 and newer XJ's have issues with their fuel pumps. The check valve that holds pressure in the fuel line when the motor is off, likes to fail. It is located in the fuel pump and is not a seperate replaceable part. When you shut off the motor fuel pressure slowly falls to zero slowly at first, then faster and faster. Mine would lose pressure after 10 minutes.
Test the pressure at the fuel rail after the XJ has not run for 8 hours.
You can just ignore it and turn the key on and off a few times to pressurize the line. Or You can install a new fuel pump. (EXPENSIVE). Another cure is to put a check valve in the fuel line near the gas tank. Call BMA parts and order one.
I put in the BMW check valve, it came with the rubber hose and some hose clamps, problem solved. (Edit: Not really, keep reading)
www.bmaparts.com BMA Parts 1-888-262-3911
p/n 16 14 9 068 988 - fuel line check valve for a BMW 1990 735 iL
about $18.00 shipped
CJ7-Tim is offline
post #8 of 16 Old 06-29-2006, 01:17 PM
jrn1023
Originally Posted by CJ7-Tim
1997 and newer XJ's have issues with their fuel pumps. The check valve that holds pressure in the fuel line when the motor is off, likes to fail. It is located on the fuel pump. When you shut off the motor fuel pressure slowly falls to zero slowly at first, then faster and faster. Mine would loose pressure after 10 minutes.
I put in the BMW check valve and it came with the rubber hose and some hose clamps. Problem solved.
Wow Tim I wish I would've had that information a few hundred dollars ago.
jrn1023 is offline
post #9 of 16 Old 06-29-2006, 04:56 PM
MontyTJ02
before actually turning the key to start it...just leave it in the ON position for a second or two then turn it over. Need to let the fuel pump turn on and pump fuel to the rail and injectors....the no start is caused by no fuel.
FireFighter's Jeep Club #84
I started out with nothing and still have most of it left.
Im getting tired of thinking...guess I'll do some wishful drinking.
MontyTJ02 is offline
post #10 of 16 Old 06-29-2006, 09:08 PM Thread Starter
fossill
You guys rock. After work, got in the xj, turned it on listening for the fuel pump, turned it off, turned it back on, waited a sec or two, tried turning it over and voila! Completely worked. Thanks!
1998 XJ Sport
TB spacer + cone
30x9.5x15s
fossill is offline
post #11 of 16 Old 07-28-2006, 08:03 PM
Creek Rat
I definitely have a loss of fuel pressure after the engine has been off. When it started I wouldn't see the problem unless it sat in the heat all day but now I lose all pressure anytime after 30 or so minutes.
I've got an external check valve to put in tomorrow but I have a question about the fuel lines. On a 2000 XJ there are two lines out of the fuel pump, a pressure line and a return line. Is there a way to verify I'm cutting the right line?
I see from your picture you've put the valve on the line with the quick connect fitting. According to the manual if you disconnect these fittings you have to replace the guts will all new O rings and a fitting to reconnect them, is this true or can the existing fitting be reconnected?
Also, what I guess is the return line goes to a box a few feet from the tank and then lines run to the front. What is this box? I can't find it in the manual, what does it do?
Thanks!
Creek Rat is offline
post #12 of 16 Old 08-29-2013, 03:43 AM
ultimo
Any reply to the above?
Build Thread-- http://www.jeepforum.com/forum/f197/ultimos-build-1477712/
ultimo is offline
post #13 of 16 Old 09-02-2013, 04:46 AM
danblue636
You can't use that external check valve on jeeps after 96...your 2000 has no return line...it will heat soak...build pressure and blow out the diaphragm in the fuel rail...the diaphragm is not replaceable so will need to replace the whole fuel rail.
danblue636 is offline
post #14 of 16 Old 09-02-2013, 04:48 AM
ultimo
OOOH THANKS! i think i will replace the fuel regulator first, read from the service manual there is a check valve function there too and that this fix worked for some even after they replaced the pump
ultimo is offline
post #15 of 16 Old 09-02-2013, 06:32 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
How come CJ7Tim has one on his 2000 then?
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is online now
Sometimes starts and sometimes doesn't? surfology22 XJ Cherokee Technical Forum 6 11-05-2009 07:14 PM
4.0 starts but low rpm's and now starts and stalls Radium08 XJ Cherokee Technical Forum 1 07-22-2009 12:53 PM
4.0 starts sometimes not always nochurch69 XJ Cherokee Technical Forum 4 06-07-2009 08:20 PM
Cold Starts Fine, Hot starts Not So Fine!!! Protrkr XJ Cherokee Technical Forum 0 04-21-2009 08:30 AM
ok this is where it starts..... blacky_j XJ Cherokee Technical Forum 5 03-25-2005 02:49 PM
