only broke 1 top shock bolt... now i need to get it out
#1 | |
so all f the shock bolts came out goo, except for one, little bugger was in there good, well i figured ide break at least one... so i wasnt worried when i broke it, but now all said and done.... i need to get it out.
i checked out the FAQ area on the upper shock bolt replacments, but i was thinking more along the line of doing the drill and tap, but i was wondering how this will come out, and/or if i can use a easy-out. this is my first lift, so this is the first time im running into anything like this, so im not too sure what to do at this point ![]()
( northjerseyjeepclub.org ) 99 cherokee sport auto/231 - RK 3 link long arms, RE 5.5" coils, RC 4.5 leafs w/ RE 1.5" boomerang shackles, RE track bar & bracket, JKS disco's, rustys/RC shocks, P.O.R.C SYE w/ front drive shaft, rugged ridge steering, OR-fab front winch bumper w/ superwinch LP8500, surco roofrack, airflow snorkel, bushwackers & 33" maxxis bighorns . 95 cherokee sport auto np231 - 4.5 RE coils, OME 3 inch full packs, stock track bar ,RE upper and lower control arms, JKS quicker disco's,RC shocks and steering stab.stock tires/rims,t-case from the 99xj, slowly being robbed of all its part before it goes to the JY |
#2 |
Little Red Menace
Grind the broken piece smooth and drill it out.
I would "attempt" to drill it out and use an easy out. I would try a big drill bit and that would weaken the remaining broken piece and either break it up or extract it.
93 Sport Beer is proof that God loves us and wants us to be happy............Ben Franklin Specs in Profile. http://www.cardomain.com/ride/325707/1 http://www.cardomain.com/ride/2406854/1 |
#3 |
We drilled and tapped all 4 of mine to 5/16 coarse thread
'99 Sport...Custom Front & Rear Bumpers, Rusty's Air Tube, Dynomax Exhaust, Hacked Fenders, Cut 'n Fold Rear Quarters, Durabak'ed Fenders-Rockers-Doors, OME 2" & 265/75R16 Kumho's, Silverstars w/ Upgraded Harness SOLD
#4 |
and i shouldnt have any problem tapping it? this wont weaken the upper shock mount or anything?
#5 |
Theres about 3 threads with this info already- but I'll put my 2 cents in- I just cut the holes in the floor- takes maybe 15 minutes to get completely done, and then you know its strong. I put grade 8 5/16 bolts in so I know they'll never break.
#6 |
We didn't, and everything is holding together fine. I'd have a little more of a warm fuzzy if we would have drilled through and used a nut, but this worked out pretty well.
#7 |
I drill all 4 of mine out and used a recoil kit which worked out really well.
#8 |
I went in through the floor on the top and cut open access to it with a dremel. Should have done it hours earlier instead of fighting with it.
2009 Rubicon Unlimited *SOLD* 1996 XJ rusty's 3" AAL - 15x8 cragar soft 8 - yoko geolander 31x10.5 a/t - polyurethane motor mounts DEATH WOBBLE GONE! |
#9 |
i just ended up drilling and taping it, took me all of 15 minutes and worked out well, now i just need ot get the front leaf bolts out!
#10 |
I busted all of mine.. There is a lil room there I just dropped a bolt thru top with a dab off silicone on it smoked one and crawled back under.. lube the bolt good spin on nut add locktite insert key and drive been on there for bout 2 years now.. A buddy didnt trust my setup so he did almost same thing almost but he used 2 nuts after he got 1st one on he put shock in place the put on 2nd nut and tightened against each other both ways under 20 mins..
#11 |
I used the meathode shown in the tech sticky, use an impact hammer and drive the old hardware out then fish stainless bolts thru the back side. of coarse I broke all but one of mine so if I were you I would try to fix the one that is broke first and make it the same as the others.
1999 Cherokee 2 Door Sport (To be modified) Mine. http://www.cardomain.com/ride/2814633/1 5.5" Composite lift, Rough Country Control Arm Drop Brackets, 31X10.5X15 Dayton Timberline AT's On Canyons, 31X10.5 Firestone Destination MT's, P.O.R.C. SYE and front CV Drive Shaft, Homemade Short Ram Intake, Locked 8.25. Comming Soon: Stroker. 2000 Grand Cherokee Laredo (To be left alone) Wife's. http://i151.photobucket.com/albums/s127/fedrusion/IMG_0007.jpg |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
