One Wheel Peel getting worse I think, I need a fix.
#16 | ||
'94 XJ Sport (my toy) - 5.5-ish inches of lift, 33/12.5/r15, locked in the front, custom armor, OBA '86 MJ XLS (family toy/budget build) - 5-ish inches of lift, 32/11.5/r15 '99 WJ Limited (my DD) - 2.5 inches of lift, 255/70/r16, some go fast goodies Only 22 and on a college budget, but loving every minute of the 'Jeep Life' If you wanna know more about the rides or if you need something made just ask! :) |
#17 | |||
Makes for a *****. Both wheels spinning, there is at least forward movement, and it takes much less off throtle time befor they hook again and you can go. Quote:
Kia AWD would work, except they are ugly as sin.
1999 XJ, black, 4x4, NP231 Command Track, 8.25 rear. 3" Old Man EMU, 30" x 9.5" x 15" General Grabber AT2 |
#18 | |
Got my eye on you.....
http://i131.photobucket.com/albums/p...k_banner-1.gif Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08 |
#19 |
make sure your tires are the SAME pressure. Diferent pressure in each tire could cause u to supin. and it has to do with ur driving habbit, u can beleive us or not. but the ONLY time i spin out in the rain is when im on my way to a fire call, and im driving like an *******. and punching the accelerator. otherwise i drive easy and i DONT spin.
74 CJ5 86 CJ7 89 Cherokee
#20 |
I've never run my tires any more than 32 PSI, so to me 34 is overinflated. I still get Wheel-peel but my keds are almost bald! try running a lower PSI to see if that helps a bit.
Is your jeep a standard or Auto tranny?
XJ [COLOR="Red"]3.5" Warrior coils, Full leaf packs, Skyjacker Quick Disconnects, Rear swaybar delete, Pro Comp shocks, HD Steering stabilizer, BFG AT's, 1" drop shackles, Front tow hooks,Front skid, Warn T-case skid bcjeepclub.ca |
#21 |
Stock off the line PSI for just about every jeep is 32psi. If your running 34 PSI that can effect how well your tread is touching the pavement.
#22 |
get an Np242 TC...and keep it in full-time
#23 |
all tires are the same, i check every week or so.
I put the tires to 32, (2psi really isnt much at all) so we will see if that helps at all. reading reviews anywhere I cant see anyone say these tires are bad in the rain. I mean when I brake hard they dont lock early, even with standing water they hold. So I dont see how its the tire. I swear it was never this easy to get the wheel peel, seems like it does it more and more often. Driving habbits, well I want to go above 1800 rpm when merging from a stop to traffic going 40 mph, otherwise its really hard to get anywhere because you need such a large opening. I hardly ever go wide open unless I am passing or something.
#24 | |
is that an easier/cheaper/better option over a lsd for someone that doesnt do offroading much of anything?
#25 | |
#26 |
Im not going to get into a battle about it. just giving my opinion backed with facts from previous experience.
You can choose to believe me or not.
#27 |
i would say the tires could be the culprit. with my old tires i could spin them all the time but my new ones i have to try to spin them. its not that they are hard to spin on wet pavement but just normal driving they dont spin much. and i have a lead foot as is
92 xj laredo, 4.0l 5spd, 3 inch lift, chopped fenders, 33x12.5x15 wildcountry rvts, lincon locked rear, 9500 winch, hombrew bumpers and snorkle and the list goes on |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
