Quantcast One Wheel Peel? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > One Wheel Peel?
FREE shipping on Rugged Ridge Soft tops @thejeephut.comGR8TOPS Introduces the Exogate HD Tire CarrierJcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!
Old 11-15-2006, 06:32 PM   #1
88XJSport
1988 XJ Cherokee
One Wheel Peel?
My 88 cherokee will "one wheel peel" the right rear everytime i make a right turn when it is wet outside. It does not peel making a left turn, just a right. The light turns green, i go to make the right, and i cannot touch the gas at all or i will redline. It is really annoying. It doesnt have to be downpouring, just wet. I dont know what i could do to help it, so i will ask. Oh i have a D35 without Limited Slip (but you already knew that)
88XJSport is offline   Reply With Quote
Old 11-15-2006, 06:34 PM   #2
olds442
get a limited slip
Family Wheelin...
Dad- '08 JK Rubicon- Stock, BB and 33s coming
Sister- '07 FJ Cruiser- Rear locker, BFG A/Ts
VT
Projects:
1970 Oldsmobile 442
1970 Yamaha R5
olds442 is offline   Reply With Quote
Old 11-15-2006, 06:34 PM   #3
88XJSport
1988 XJ Cherokee
But isnt dumping money into a D35 an oxymoron? All i was wondering is why it would do it so bad. When i had my driveshaft out to do a ujoint, i spun the yoke when the back was in the air, and the right turned faster than the left, and the left was barley turning.
Old 11-15-2006, 06:35 PM   #4
90lerado
either bald tires or the right tire is low on air
"Few men are killed by the bayonet, many are scared by it. Bayonets should be fixed when the fire fight starts"
- General George Patton Jr, "War as I knew it" 1947
new vehicles:1996 Ford F150 5.0l 4X4 with a plow.
90lerado is offline   Reply With Quote
Old 11-15-2006, 06:36 PM   #5
olds442
not really, i mean yes in a way, but for a DD and 235s i wouldnt worry about it
Family Wheelin...
VT
Projects:
1970 Oldsmobile 442
1970 Yamaha R5
Old 11-15-2006, 06:37 PM   #6
88XJSport
1988 XJ Cherokee
1/2 inch of tread, 40 psi
Old 11-15-2006, 06:52 PM   #7
90lerado
then the only other way is if your giving it to much gas through the turns. unless you have a brake dragging.
Old 11-15-2006, 06:55 PM   #8
88XJSport
1988 XJ Cherokee
When i barlely crack the throttle thru the turn, it will still break traction.
Old 11-15-2006, 06:55 PM   #9
mdoug445
just get an lsd and be done with it. i was considering this for my XJ as well, that got very annoying and I had great tires. i was told on here that the D35 can handle an LSD.
Gone: 97 Cherokee Sport
mdoug445 is offline   Reply With Quote
Old 11-15-2006, 06:59 PM   #10
boman40
boman
1995 FSJ Cherokee
What size are your tires that you are running 40 psi in them? 235 only needs 35 psi, and for soft ride
you could go down to 30 psi. to much could cause your problem, not enough tire on the road, be sure to use a good pressure gauge when checking your tire pressure.
boman40 is offline   Reply With Quote
Old 11-15-2006, 07:03 PM   #11
olds442
yeah hes prob right, drop the psi down to about 30 should help alot
Family Wheelin...
VT
Projects:
1970 Oldsmobile 442
1970 Yamaha R5
Old 11-15-2006, 07:59 PM   #12
Matt1994XJ
to me it sounds like something is wrong. esp when he said "When i had my driveshaft out to do a ujoint, i spun the yoke when the back was in the air, and the right turned faster than the left, and the left was barley turning." im not sure what could be wrong but it doesnt sound as simple as let your foot off or air down your tires. and in order for brakes to do that it would have to be dragging pretty hard. jack up your vehicle and try to spin the left tire..and see if it spins hard..that would let you know if the brake is dragging.
2005 WK 5.7L QDII 245/75-17 on stock
1994 Cherokee 2-Door 4.0L HO w/ 5 speed
SOLD :( Miss it everyday
Matt1994XJ is offline   Reply With Quote
Old 11-15-2006, 08:00 PM   #13
1990JEEPXJ
1990 XJ Cherokee
some came from the factory with them so of course they can handle an LSD. mine has one and i CANT do one wheel peel. love it. wish i had a locker for wheeling though
Twin 242's
The 'build' thread
1990JEEPXJ is offline   Reply With Quote
Old 11-15-2006, 08:27 PM   #14
patchouli
Same thing happened to on the hills of downtown Seattle the other day.
I was freaking out.
All my tires were at 30 psi, okay tred. I am looking at new tires that offer better wet pavement traction (seattle).
Someone recommended that I put more weight in the back.
Also, my shocks are shot, so any bump or turn, there isn't great force against the road.
patchouli is offline   Reply With Quote
Old 11-15-2006, 08:33 PM   #15
carmike692000
I have the same problem; only worse. And just to let you know up front, my stock size tires are all dead on at 35psi.
I can one-wheel peel almost that easy on *dry* assphault. Whenever I'm turning right on a dry road, and I have to get on it a little bit to jump in a hole in traffic, it'll spin. I can also get it to spin making left turns.
Now, you wanna talk about wet roads? Can you say oversteer? Can you say going down the road sideways? With a HUGE grin on your face? And then doing a 180* or even 270* on a busy road with an entirely different look on your face? Haha. I've done it at least 10 times or so. And, before you say I must have had the go pedal mashed to the floor, the majority of the time I get sideways on a wet road, it's by accident.
I've also discovered something else I can do in my XJ, though I've not explored it nearly so much yet. Drifting. I found out a few weeks ago quite by accident, and accompanied by first horror and panic, then shock, then awe, and then excitement, that I can drift through one particular exit ramp. If I enter it doing about 50, suddenly remember I'm on an exit ramp and hit the brakes while simulataneously turning the wheel, she'll rotate, and end up drifting for at least *some* distance. The first time was a mistake, and I've only tried to do it once since then, so I'm not exactly sure what all I can do. But boy I thought I was going to a) flip or b) run over the curb that first time. What a shock when she just glided through the turn and then straightened out.
And yes, both of my back tires could get me a ticket. However, they were both new at some point and I still had traction problems. I need to take a pic of how the tires are now, 'cause they're soooo close to being bald. The right one is *almost* there consistantly. The left one is pretty close only in the middle.
[quote=XJ4oh]I did a top speed run today.
I hit teh NOS when I was at like 100 and my speedo bent around like 3 times, I guess I was going like 300 mph. It felt like I was sitting still, I ran out of road but luckily I was going so fast that I hit a bump and took off. I guess the Supra wing really helped out, luckily I landed in a lake and my wheels were spinning so fastz that I scrambled across it like those crazy scandanavians with their 4x4s that walk on wata. I go off of the lake just in time to hit a dirt field right before my flux capacitor quite.[/quote]
carmike692000 is offline   Reply With Quote
Glock Forum
