OME Springs - Heavy or Medium - JeepForum.com
post #1 of 19 Old 07-09-2007, 04:53 PM Thread Starter
tangofox007
I am planning on installing an OME suspension package. Can anyone provide any insight on whether I should go with the "Medium" or "Heavy Duty" option. Apparently the only difference is in the rear springs. Most of my driving is fairly "unloaded" but I do take occasional trips carrying a fairly heavy load. My inclination is to consider the "worst case" scenario and go with the HD package. Lift is not an objective, per se.
tangofox007 is offline
post #2 of 19 Old 07-09-2007, 04:56 PM
Scottmc01
1993 XJ Cherokee
i'd say the heavy duty springs would be for towing. or if you added alot of weight to your xj such as bumpers and racks etc.
93 Jeep Cherokee Country 4.0 AW4
Flowmaster / APN header
3" mismatched lift
30" Bighorns on V5's
Scottmc01 is offline
post #3 of 19 Old 07-09-2007, 05:22 PM
Goldenknob
2007 WK
what if you have a 150lb speaker box in the back permanently?
Goldenknob is offline
post #4 of 19 Old 07-09-2007, 05:26 PM
Steamer98
Steamer98's Avatar
Go CS034RA if your looking for around +2.5" CS034RB for +2"
Quote from Dirk at DPG
From this thread http://www.jeepforum.com/forum/showt...ighlight=happy
"That's a broader question than I wanna post to completely, but here's the down low:
JC1A is now CS034RA
This leaf typically nets close to 3" of lift on a stock XJ.
JC1B is now CS034RB-
This pack is closer to 2" of lift.
We should keep in mind that advertised lift heights do vary a bit. This is true throughout the industry. For example, RE kits usually sit taller than advertised on a stock jeep.
You could put the exact same kit on 3 different jeeps and net 3 different lift heights, due to how each jeep is set up. Another little know fact is that XJ's came with a number of different leaf spring packs over the years. Lift heights and spring rates were not all identical.
There has been some confusion here because ARB has referred to the JC1B as a medium leaf and the JC1A as a HD leaf pack. They both have the same # of leafs, and the leafs are the same thickness. Therefore, with these leafs, the spring rates are basically the same. The reason the JC1A sat a bit taller was simply because they are arched more. To me, that's not HD. HD would mean a higher spring RATE to me. I've had a lot of people call to order OME leafs, and they said they didn't know if they wanted to JC1A or the B, but whichever one was "heavy duty"... Of course, the taller spring would hold more weight at a certain height than the other.
The JC2A and JC2B were the leafs with the straight overload leaf. They were designed for towing and hauling heavy loads. Obviously, the new OME Dakar part#'s are the CS035** series. I usually don't recommend these leafs, so I'm not sure which part#'s correspond to 2" or 3". I don't even have the new part #'s for those leafs listed in my OME books.
OME has also had a #JCXL extra leaf available for their packs. That new part# is
D22XL. These are not the typical aftermarket AAL, which is usually fatter and much more heavily arched than the springs they fit with. While the typical AAL FORCES the flatter pack to arch, creating a conflict within the pack, the OME extra leafs are the same thickness and arch as the OME pack. This is actually a compliment to the pack. These leafs usually add about an inch of lift and a bit of extra spring rate too. They still make for a nice riding pack that flexes well too.
We've built a bunch of different suspension set-ups with a variety of these and other parts for lifts netting anywhere from 2" to 4.5" or so. Applications vary greatly depending on each jeep, how heavy it is, how that weight is distributed, (front & rear) the lift height and ride characteristics desired, and so on.
That's not something that can easily be summed up here- especially considering that every jeep is different. Hopefully, that helps a bit though."
98 XJ Limited
Stock XJ tire carrier for sale
Steamer98 is offline
post #5 of 19 Old 07-09-2007, 07:20 PM Thread Starter
tangofox007
Steamer, thanks. That is good info. I am not really looking for lift or the associated complications, so it looks like the medium springs would be best for me.
It's interesting, though, that some vendors claim that you get less lift out of the HD springs as compared to the medium.
post #6 of 19 Old 07-09-2007, 07:32 PM
dopod
dopod's Avatar
I have the heavy duty ones. They netted me about 2.5" unloaded. They ride and flex great. I can get them to droop further than my stock springs/spacer in the front. Either one would be a great choice.
dopod is offline
post #7 of 19 Old 07-09-2007, 07:46 PM Thread Starter
tangofox007
What is the stock number? According to some sources, the HD version is CS035RA. (The one that DPG does not recommend.)
post #8 of 19 Old 07-09-2007, 08:00 PM
dopod
dopod's Avatar
Yes that is the version I have. I don't know why he doesn't recommend them, they are great. I removed the flat overload leaf because they tend to scoop up dirt, though. They would net you about 3" if you left that overload leaf on.
dopod is offline
post #9 of 19 Old 07-09-2007, 08:09 PM
hermantherugger
hermantherugger's Avatar
Just an FYI...
I ordered the HD OME springs from Qtec...they're backordered for a few weeks.
'97 Sahara - 8.8 Swap w/ Artec Truss, UCF Tummy Tuck, ZJ V8 Coils & some spacers, 35" Mud Kings, Rokmen Corners, & 2 car seats :)
'93 Wrangler - 2" BDS Springs, MORE Shackles & Body Lift - Sold
'99 Cherokee Sport - 2" OME springs, Trimmed Fenders, Custom Bumpers - Sold
hermantherugger is offline
post #10 of 19 Old 07-10-2007, 06:30 AM Thread Starter
tangofox007
Originally Posted by hermantherugger
Just an FYI...
Quadratec has a good price on the HD springs. But they are not very competitive on the light and medium versions.
It looks like my decision is now between the non-HD springs. I am not really looking for lift and would like to avoid any lift-related problems.
post #11 of 19 Old 07-10-2007, 09:06 AM
gorman
gorman's Avatar
If you don't want/need a lot of lift, go with two CS034RB - there is about an 1" free camber length difference between the A and B springs. These are the medium ones. If you find there are not heavy duty enough - OME makes an add-a-leaf that you can add later that is said to increase the spring rate by about 20%.
2000 Cherokee Country 4.0l, AW4 auto, NP242, RE/OME 6" lift, OME N35L & N36 shocks on raised mounts, JKS Quicker Disconnects, RE SYE, RE CV driveshaft, 33" Maxxis Bighorns, Cragar D window 15x8 with 4" backspacing, ARB bumper, Hella Comet 550's, Warn M8000 winch, GME GX300 29mhz, custom rocksliders, Gearmax Mod 89 rear axle, HP D30 front axle with WJ knuckles, steering and brakes, 4.56 ratios
gorman is offline
post #12 of 19 Old 07-10-2007, 03:39 PM Thread Starter
tangofox007
Thanks for all the input. At least I now think I understand the differences in the various spring models. So it appears to boil down to whether I want more lift or less.
In any case, it would seem that OME would do a better job of providing product information. Their promotional material focuses on extolling the virtues of their merchandise, while providing little technical data on the various spring models. For a product with such a great reputation (and high price tag), that's a bit disappointing.
post #13 of 19 Old 07-10-2007, 04:53 PM
Steamer98
Steamer98's Avatar
I hear ya, frustrating... Give dirk a call at DPGoffroad, you might be surprised at the actual cost of the OME/ARB packs. Screw Quadratech.
Dopod, are you sure about the CS034RA? Mine dont have any overloads, and also gave me +2.5"
Pics of my CS034RA before install, no overload
during
After
98 XJ Limited
post #14 of 19 Old 07-10-2007, 05:39 PM
dopod
dopod's Avatar
I have the CS035RA ones, not CS034RA
dopod is offline
post #15 of 19 Old 07-10-2007, 06:17 PM
Steamer98
Steamer98's Avatar
My fault...
98 XJ Limited
Medium or heavy duty OME leaf springs 71mach1 XJ Cherokee Technical Forum 7 07-14-2011 11:33 PM
Heavy Duty Springs RogueXJ XJ Cherokee Technical Forum 13 08-21-2009 02:48 PM
Going to order OME springs today, HD or Medium duty? dorsalfin3 XJ Cherokee Technical Forum 6 06-06-2009 08:24 PM
OME light vs. medium springs and shocks duke000088 XJ Cherokee Technical Forum 2 03-20-2009 02:18 PM
Medium Duty springs or HD springs w/my BB 2" lift mrtosh XJ Cherokee Technical Forum 6 09-16-2008 10:23 AM
