OME lift came today! Am I ready?! - Page 2 - JeepForum.com
post #16 of 25 Old 10-13-2009, 12:58 PM
Swagger_Wagon
You can go get brake lines from a YJ wrangler from an auto parts store. They're longer than the XJs. And most auto parts stores should have the longer U-bolts, I got mine from autozone.
P.J. O'Rourke
The Jeep is a manly device. And a womanly device. An American device. Its a fitting instrument to transport the free people of a free nation with the respect to which we are entitled and the dignity that we deserve. Okay, were a little crazy to have a Jeep for a daily driver. But if we go off our meds, we might wind up in a Prius
Swagger_Wagon is offline
post #17 of 25 Old 10-13-2009, 01:21 PM
multmigs
2003 WJ
do you have to do anything with the bumpstops either front or rear on a 2-3"lift?
multmigs is offline
post #18 of 25 Old 10-13-2009, 01:23 PM Thread Starter
Tess
1997 XJ Cherokee
Good Call
Answers anyone?
Tess is offline
post #19 of 25 Old 10-13-2009, 05:22 PM
Swagger_Wagon
I didn't but I probably should because of my 31s. I've had a few buddies in the way back before along with 3 people in the back seat and I went over a speed bump and I heard and felt my rear tires bottom out in the wheel wells. So while it's not necessary to get extended bumpstops, it may be a good idea.
P.J. O'Rourke
post #20 of 25 Old 10-13-2009, 06:26 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
Tess, you may need a longer rear line. The fronts will be fine though. You can buy a new rear line for a 95 wrangler and it will be 3" longer than your line and bolt right up. If you have a 2wd you will not have to worry about a t-case drop or SYE until you get up in the 5 to 6" of lift range. Without the t-case you have a much longer driveshaft that will be affected a lot less by the lift.
xjfever is offline
post #21 of 25 Old 10-13-2009, 07:44 PM
Lupitaboy
I glued old hockey pucks to the base of the coil spring mount for my original 4 inch lift. You can often get them free from ice rinks that support hockey.
96 w/ 5spd, 4.10s w/ lsd, Bastard Packs, armor/ rack, BFGs & JK Blacks
Lupitaboy is offline
post #22 of 25 Old 10-13-2009, 08:20 PM
jeep12827
1987 XJ Cherokee
and how did the glue hold up and what typer of glue
jeep12827 is offline
post #23 of 25 Old 10-13-2009, 09:32 PM
Lupitaboy
Any construction adhesive like PL200 or something with exterior applications will work fine.
post #24 of 25 Old 10-13-2009, 09:42 PM
Swagger_Wagon
Just to sum everything up and simplify things, here's everything you'll need...
-Your OME Kit
-Extended U-Bolts for your particular axel
-Coil compressor for putting the spacers on (you can rent one at most parts stores)
-Rear brakelines from a '95 YJ
-Some hockey pucks for the front bumpstops (and the adhesive to hold them in place)
-Maybe look in to extended bumpstops for the rear, it's not imperative (at least in my case) but it wouldn't hurt
-2-4 decent jackstands and a solid floor jack (If you're doing this yourself)
-Hit all the hardware (bolts, etc.) that you'll need to access/take out with some PB Blaster
P.J. O'Rourke
post #25 of 25 Old 10-13-2009, 09:51 PM Thread Starter
Tess
1997 XJ Cherokee
LOVE IT! Waiting for the rest of my stuff to get here on Thursday! Then looks like I'll be ready to go. Thanks! WOOOOOOT
Tess is offline
Ready to lift? Eman XJ Cherokee Technical Forum 4 06-06-2008 12:36 PM
Getting ready for lift. burger XJ Cherokee Technical Forum 8 05-10-2008 11:16 PM
Getting ready to lift-what to look out for. tdogg55555 XJ Cherokee Technical Forum 21 02-01-2008 07:50 PM
Getting ready to lift... adam.gutt XJ Cherokee Technical Forum 2 03-07-2006 08:27 AM
ready for my lift shylow XJ Cherokee Technical Forum 4 12-23-2003 12:07 AM
