OME lift came today! Am I ready?! - JeepForum.com
post #1 of 25 Old 10-12-2009, 11:27 PM Thread Starter
Tess
1997 XJ Cherokee
Pieced together my lift and am going to have it installed. Just want to be sure I have everything together before I get too excited
2 OME 2" HD Full Packs
4 New Rubber Bushings
2 1.75 Spacers
U-Bolts? I need to know what TC I have to get the right fit? How do I tell?
I'm going to put off shocks until I can afford the OME's, I've ready both ways that this is OK, as well as bad. I figure if waiting for shocks destroys the stock ones already on there, I didn't lose anything...
Also waiting on the SYE/TC Drop to be sure it's necessary for this particular lift.
Am I missing anything!?!
THANKS!
Tess is offline
post #2 of 25 Old 10-12-2009, 11:55 PM
chainerx
You need to know what rear axle you have for u-bolts, not transfer case. If you look under the jeep and the bottom of the rear differential has a noticable flat spot you have a chrysler 8.25 rear axe, if not it's a dana 35.
A transfer case drop shouldn't be neccisary but even if you have some vibrations, they should be minor at that height so you can probably wait to find out if you have vibrations before buying the TC drop.
I say you're fine on the shocks, really all it will do if burn them up faster and probbaly make it ride worse until new ones are installed.
Are you doing the lift yourself, paying a shop do do the work, or having a buddy do it for you?
1990 XJ -Sold
1997 XJ -Sold
1998 XJ -Current DD
chainerx is offline
post #3 of 25 Old 10-13-2009, 12:07 AM Thread Starter
Tess
1997 XJ Cherokee
I thought I was going to put it in myself... then I saw how heavy those leaves are! I did some reading on the rusty bolt issues, getting the leaves to line up... Just going to take it all to my mechanic. He said it'd be 150-200 for the install. From what I've read, I'll save that much in the extra jackstands cost!
BTW Thanks I've got the 8.25
Tess is offline
post #4 of 25 Old 10-13-2009, 12:31 AM
chainerx
It does help being 6'4" and 270lbs when it comes to moving axles around, heh.
It does sound like your mechanic has given a pretty reasonable price though. I'd never be able to get that kind of deal where I live, thought hats probably because of the tourist based economy around here. Here people in BMW's and and caddys just pay whatever the shop feels like charging.
Are you planning on new tires as well?
1990 XJ -Sold
1997 XJ -Sold
1998 XJ -Current DD
chainerx is offline
post #5 of 25 Old 10-13-2009, 12:42 AM
ar4130
I would go for a larger spacer up front. Chances are those leafs are going to give more than the advertised 2 inches. You will prob get more like 3-3.5, leaving you noticebly lower in front. Some people like that look though. What size tires do you plan on running?
1997 XJ 6.5 mixed RC,OME,IRO w/ SYE.
2001 XJ 4.5 RC lift,JK Wheels w 32's
ar4130 is offline
post #6 of 25 Old 10-13-2009, 12:48 AM Thread Starter
Tess
1997 XJ Cherokee
The lift is due to the new tires I stuff the back pretty often and I could proly get away with trimming... Gives me an excuse to lift a bit I've got 235/75/R15's on there right now, and I'll see if they'll look too small once I get the lift on, shocks upgraded etc. I've read that about the OME 2" lifts. They're all over the place from reported settled lifts of 1.5" to 3.75". Gonna wait to see what I need to level out the front I got the HD with overload leaf and heard some people are taking off the overload? Any reason I should look into doing this myself?
Tess is offline
post #7 of 25 Old 10-13-2009, 12:51 AM
chainerx
I would wait and see about the overload.
1990 XJ -Sold
1997 XJ -Sold
1998 XJ -Current DD
chainerx is offline
post #8 of 25 Old 10-13-2009, 01:04 AM Thread Starter
Tess
1997 XJ Cherokee
Also, if I do end up with 3-3.5" from these packs... will I need to get longer brake lines (or think about anything else for that matter besides the SYE)? Is this something I could get away with doing myself after my mechanic does all the "heavy lifting"?
Tess is offline
post #9 of 25 Old 10-13-2009, 01:12 AM
Swagger_Wagon
Good stuff, the shop around here wanted almost $600 to put my lift on. Needless to say I did it myself.
P.J. O'Rourke
The Jeep is a manly device. And a womanly device. An American device. Its a fitting instrument to transport the free people of a free nation with the respect to which we are entitled and the dignity that we deserve. Okay, were a little crazy to have a Jeep for a daily driver. But if we go off our meds, we might wind up in a Prius
Swagger_Wagon is offline
post #10 of 25 Old 10-13-2009, 01:13 AM Thread Starter
Tess
1997 XJ Cherokee
Was it the pain that I read about?
Tess is offline
post #11 of 25 Old 10-13-2009, 01:17 AM
Swagger_Wagon
No not at all. Just make sure you have plenty of jackstands and some coil compressors. It just took me and my dad longer than usual cause all 4 rear upper shock mount bolts busted
P.J. O'Rourke
post #12 of 25 Old 10-13-2009, 01:50 AM
chainerx
Ironically, I had just the opposite of what happened to HevinDester. On my 20 year old Jeep every bolt but the 4 upper shock mounts broke/broke off the nut in the frame. But with a 2000, you should be fine. Being in Michigan weather for so long didn't do my XJ any favors.
1990 XJ -Sold
1997 XJ -Sold
1998 XJ -Current DD
chainerx is offline
post #13 of 25 Old 10-13-2009, 11:22 AM
Swagger_Wagon
Yeah my XJ's an Illinois Jeep, so that didn't do much good either. Guys who's XJ's have been down south and in the SW their whole lives have it easy when it comes to installing stuff like lifts.
P.J. O'Rourke
post #14 of 25 Old 10-13-2009, 01:12 PM
chainerx
Not to mention they're cheaper since 4wd isn't needed for the winter.
1990 XJ -Sold
1997 XJ -Sold
1998 XJ -Current DD
chainerx is offline
post #15 of 25 Old 10-13-2009, 01:26 PM Thread Starter
Tess
1997 XJ Cherokee
Yup! I was lucky that the lowest mileage Jeep I found was 2wd. Los Angeles isn't a 4wd place and I didn't want the repair costs for something I'd use a few times a year. Thanks all, just gotta order the new U-bolts and I'll be set!
One last question. If I get more lift than anticipated, 3" +, should I go ahead and get a longer brake line when I get the U-Bolts? This doesn't seem like something to "wait and see" about... I dunno. Or would a mechanic have these things already?
Thanks again!
Tess is offline
Ready to lift? Eman XJ Cherokee Technical Forum 4 06-06-2008 01:36 PM
Getting ready for lift. burger XJ Cherokee Technical Forum 8 05-11-2008 12:16 AM
Getting ready to lift-what to look out for. tdogg55555 XJ Cherokee Technical Forum 21 02-01-2008 08:50 PM
Getting ready to lift... adam.gutt XJ Cherokee Technical Forum 2 03-07-2006 09:27 AM
ready for my lift shylow XJ Cherokee Technical Forum 4 12-23-2003 01:07 AM
