OME Hybrid Lift - JeepForum.com
post #1 of 4 Old 02-10-2009, 12:52 PM Thread Starter
06bigdaveJP
OME Hybrid Lift
First off I wanted to say thanks to everyone for all the awesome information on this site. I think I have decided on how to lift my 01 XJ, and just wanted any feedback or advice from you guys. My goal is to clear 31's for my daily driver and keep the driveline and steering geometry as close to stock as possible. This is what I'm thinking of installing.
OME medium duty leaf springs with 2 degree shim
JKS adjustable coil spacers
OME shocks and steering stabilizer
Superlift 2.5" lift lower control arms
1" t-case drop
sway bar drop bracket
adjustable trac bar
Any input is appreciated.
06bigdaveJP is offline
post #2 of 4 Old 02-10-2009, 05:58 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
You won't need the shims with the rear springs, and most likely won't need the t-case drop.
xjfever is offline
post #3 of 4 Old 02-10-2009, 07:42 PM
lathan888
1993 XJ Cherokee
also will not need the lower control arms if you stay in the 2 inch range, and probably will not need the sway bar drop bracket.
Owner of a 1 owner 93 XJ county trim, 4.0, AT, 8.25 rear and 3.5 gears. It has goodies like pw/pl, cc, tilt, cd changer, keyless entry, rear wiper and defrost...overall a nice old jeep, my fifth owning previous wanglers and commander
[/COLOR] also own/restored a 1972 Pontiac Lemans GT originally owned by my grandmom....39k original miles.
lathan888 is offline
post #4 of 4 Old 02-10-2009, 07:48 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
Yeah, the leafs, coil spacers, and shocks, along with a front end alignment will get the job done. But 31's will be tight.
xjfever is offline
Putting together 4.5" hybrid lift, have question.. xjfan XJ Cherokee Technical Forum 0 11-04-2009 11:21 AM
Hybrid lift idea or cutting too many corners? RWB214 XJ Cherokee Technical Forum 5 03-03-2007 02:33 PM
How much lift will FSJ Wagoneer/XJ hybrid springs give 1badxj XJ Cherokee Technical Forum 1 01-26-2006 09:19 PM
?'s about hybrid lift on XJ B-mac XJ Cherokee Technical Forum 6 01-19-2006 02:25 AM
what's needed for a hybrid lift kit? orangez XJ Cherokee Technical Forum 3 11-20-2004 10:52 PM
