OME 2" leafs - JeepForum.com
post #1 of 6 Old 06-09-2013, 05:43 PM Thread Starter
MrSundays
OME 2" leafs
Can anybody please provide me some insight into the height of the leafs after install? I hear anything from 2" to 4" without explaining if its the HD or MD or if its even the 2" springs. The product code is CS035RA. The XJ needs new leaf packs and Im doing a mild lift for all intensive purposes so I was just trying to get a 2" pack.
SOLD- '13 JKR with lots of goodies
Current- '98 TJ Sahara: build coming in October
MrSundays is offline
post #2 of 6 Old 06-22-2013, 10:18 PM
xjtribe
1985 XJ Cherokee
it has been a few months since I looked at it, but I did see a site called cheep junkyard lifts. or something along that means. dnt hold me to it with the name . but the site did give part name of what vehicle it was for the lift. very helpful. its just been a minute since I have looked at the site. You can also look up BARSTERD PACKS, whitch is taking leaf springs of a vehicle and making a add a leaf. Just look it up . And good luck to you, I hope I was helpful..XJ TRIBE
xjtribe is offline
post #3 of 6 Old 06-22-2013, 10:31 PM
DerMeister
Good luck, when I put my medium leafs on I was around 4" of lift over stock specs.
Now I'm down to about 3" of lift.
DerMeister is offline
post #4 of 6 Old 06-24-2013, 08:23 AM
nickcospo
I did a bastard pack lift and it works
nickcospo is offline
post #5 of 6 Old 06-24-2013, 12:14 PM
cory4um
I got 2.5'' out of my 2'' HD pack. Thats 2.5'' over STOCK height from factory with no cargo/weight (not measuring with stock worn leafs, in which measurements in the 3-4'' range are likely)
currently at 4.5'' using:
2'' HD pack
shackle relocation
and MJ shackles
cory4um is offline
post #6 of 6 Old 06-25-2013, 08:52 PM
jorban
The 35RA and 35RB are the same leafs with a different amount of arch. I have the shorter of the two and it settled right around 2". They drive pretty good, especially when the back has some load on it. I paired them with a 1.75" coil spacer in the front. Still I am going to add a .5" or 1" block in the back to get a little rake; I don't like the squatted look.
jorban is offline
