Oil pump sucking air? - JeepForum.com
post #1 of 7 Old 07-15-2013, 02:11 PM Thread Starter
pushrodswhy
Hi,
I just put in a 1998 Cherokee engine into my 01. I put a melling oil pump / screen in with the paper gasket and now every 40- 60 seconds I hear it suck air then the lifters tap for a couple of seconds (that's what it sounds like anyway). I let it idle for quite a while and so far oil pressure is good but it isn't going away. I did prime the pump with a drill before I started it up.
I'm going to pull the pan again and take a look, is there any trick to getting these screens/pumps to seat properly? I know if you take the screen out again you have to get a new one since its an interference fit. (couldn't they just use a bolt to hold it on like everyone else?)
Also gasket or no gasket?
pushrodswhy is offline
post #2 of 7 Old 07-15-2013, 09:52 PM
79chiefs
1988 XJ Cherokee
IIRC the engine changed in 01. What pump did you use? What engine did the parts come off of? Did you reuse parts from your 01 in the 98?
99WJ Laredo I6-A 2wd
88XJ-Building on a budget.
95 E34 540i-DD
79chiefs is offline
post #3 of 7 Old 07-16-2013, 05:41 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Some of the oil pumps interfere with a block casting, and feel tight when they're actually not fully seated. Worth taking a look.
If you own a Renix Jeep, you'll want to check this out.
An index to over 30 write-ups can be found in the link below
My Jeep Technical Photos
cruiser54 is offline
post #4 of 7 Old 07-16-2013, 06:27 AM
CCKen
CCKen's Avatar
This may be what cruiser54 is talking about:
http://www.jeepstrokers.com/forum/vi...hp?f=34&t=2671
CCKen is offline
post #5 of 7 Old 07-16-2013, 06:40 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
That's EXACTLY what I'm referring to.
post #6 of 7 Old 07-16-2013, 03:22 PM Thread Starter
pushrodswhy
I used a brand new Melling pump and screen for a 1998 engine. Should be the same parts though. I have seen that post and checked when I installed it. Looked plenty tight to me but I used the gasket which would raise it up a bit. I'm leaning towards the gasket or the pickup screen being the culprit. I'm going to get it all apart and try to stick feeler gauge in there w/out the gasket. I'm worried that the pickup screen is leaking because I had to turn it slightly to get it under the pan and line the bolt up (which doesn't line up properly).
post #7 of 7 Old 07-17-2013, 06:13 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Brand new or not, I'd be looking for the interference at the mounting area.
