oil pressure sending unit, coolant temp unit - JeepForum.com
post #1 of 7 Old 01-29-2006, 02:24 PM Thread Starter
h2rescue
h2rescue's Avatar
which oil pressure unit do i need, i have a 96 sport with the gauge, the store offers 1 and 2 wire, i dont wanna buy the wrong one its 25 minutes away .
and where is the engine temp sending unit for the dash gauge located?
h2rescue is offline
post #2 of 7 Old 01-29-2006, 05:45 PM
BrunoS
yours for the full gauge cluster would be a 2-wire one.
the one-wire one simply sends a pressure/no pressure signal switch, at less than 5 psi, the points touch and your oil warning light comes on.
the full-gauge sender has an actual spring and resistor that is hooked to a thin metal diaphram inside, and this is what sends actual oil pressure value via variable resistance.
Newly Painted! Emerald Green '96 XJ 4x4 4.0 HO 5-spd
3" Lift + 31" Tires / D35 TracLok / NP231
Drilled out Stock Airbox / Gauge Cluster Upgrade
Magnaflow Muffler / High-flo Cat / MSD Coil
BrunoS is offline
post #3 of 7 Old 01-29-2006, 05:47 PM
jbrem
jbrem's Avatar
2005 WK
Sorry to hijack, but where is the oil pressure sending unit located? (i think near the oil filter? ). My gauge is all messed up, pointing right right 100% of the time, even when the engine is off.
jbrem is offline
post #4 of 7 Old 01-29-2006, 06:02 PM
Pat96XJ
I've got a 96 xj with gauges, not just the light, and my oil pressure sender is the 1 wire version. (I've got the 4.0L) It's located on the passenger side of the engine, about 6" above the oil filter, and towards the front of the engine.
Pat96XJ is offline
post #5 of 7 Old 01-29-2006, 10:53 PM Thread Starter
h2rescue
h2rescue's Avatar
jbrem, thats what mine is doing. hmm. 1 says 2 wire the other has 1 wire. i suppose ill have to pop the damn hood and look
h2rescue is offline
post #6 of 7 Old 01-30-2006, 05:19 AM
JoBo
That's the best way As for the temp guage sensor if you've got one on the left rear of the cylinder head then that's it. But as I recall my 96 only had the one on the thermostat housing
JoBo
Columbus, Ohio USA
2006 KJ CRD Atlantic Blue Pearl Coat Limited
2000 Cherokee Classic with factory 16" wheels
JoBo is offline
post #7 of 7 Old 01-31-2006, 09:23 PM Thread Starter
h2rescue
h2rescue's Avatar
jobo your right there are 2 on the 96 the one i need to change is on the head, except the valve cover is in the way, and it looks like someone tried to get at it cause the brass is folded over and stripped, oh well i wanted to change the valve cover gasket anyway
h2rescue is offline
Temp Sending unit? XJKyle1995 XJ Cherokee Technical Forum 9 05-28-2011 12:59 AM
Oil Temp and Pressure Sending Unit Location Magus2727 XJ Cherokee Technical Forum 0 03-10-2009 08:39 AM
new engine temp sending unit jeeptorino68 XJ Cherokee Technical Forum 4 03-02-2009 05:58 PM
Temp sending unit failing? PhatJeeps XJ Cherokee Technical Forum 1 10-16-2006 06:49 PM
Where's my Temp Sending Unit????? joshsg XJ Cherokee Technical Forum 3 06-22-2003 11:53 PM
