Oil Pressure Problem - JeepForum.com
post #1 of 4 Old 08-26-2009, 09:21 AM Thread Starter
RedZeppelinXJ
ok so on my '96 XJ Sport 4.0L H.O. my oil pressure gauge is showing something strange.....it used to be at 0 when the engine was off then around 40 at an idle and go up a bit when i'm on the highway.....but recently the gauge has been saying 40 even when the engine is off (and has been off for a while) and says about 60 at an idle and goes up a little from there when I drive......
is it my gauge thats messed up or is it my oil pump or filter or what? is this a big problem?
'99 XJ Sport - The Green Lantern (sold) 4.0/AX-15/NP231/HP30/C8.25, 3" RC lift, 30's
'96 XJ Sport - The Red Zeppelin (DD) 4.0/AX-15/NP231/HP30/C8.25, 2" BB, IRO Front Hooks, Hella Black Magics
'91 XJ Briarwood - The Spruce Moose (Parting Out)
'79 J10 - Spartacus (Parting Out)
RedZeppelinXJ is offline
post #2 of 4 Old 08-26-2009, 09:52 AM
_litz
1997 XJ Cherokee
Shouldn't all the gauges drop to zero when powered off ?
- _litz
1997 Jeep Cherokee Sport
1976 Fairmont MT-19
_litz is offline
post #3 of 4 Old 08-27-2009, 06:03 AM
xjhavens
there is an oil pressure sending unit that sends the signal to the guage. i would say that the unit is going bad. its buy the oil filter. i pretty sure thay are cheep and easy to fix.
xjhavens is offline
post #4 of 4 Old 08-27-2009, 10:01 AM
tjwalker
It's the crank sensor!
tjwalker's Avatar
Oil temp sending units are a very common failure on the Jeep 4.0 engine. And when they go south, they often exhibit the symptoms you are describing.
Some guys temporarily put a mechanical oil pressure gauge where the sending unit resides to verify their exact oil pressure, but my bet is that a new sending unit will restore your oil pressure reading accuracy. It is located directly above the oil filter.
You might want to try cleaning the electrical connector to the sensor with electrical contact cleaner first before replacing it.
I would highly recommend purchasing this directly from Jeep for best accuracy/mating with your factory gauge. Many people including me have had mixed (poor) luck with aftermarket hardware.
Good Luck!
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
Oil Pressure Problem? TheIceMan XJ Cherokee Technical Forum 10 05-14-2015 06:27 PM
Oil Pressure problem? Livewire94 XJ Cherokee Technical Forum 24 08-06-2009 04:38 AM
Here we go again..ANOTHER Oil pressure problem Whtfairladyz XJ Cherokee Technical Forum 25 03-06-2009 01:10 PM
oil pressure problem Jayhawk077 XJ Cherokee Technical Forum 5 04-14-2006 09:09 AM
Oil pressure problem SpikeSpeigel XJ Cherokee Technical Forum 6 11-08-2003 04:18 PM
