oil pressure problem - JeepForum.com
post #1 of 6 Old 04-13-2006, 09:05 PM Thread Starter
Jayhawk077
so at idile my oil pressure is a 2 notches below center and when im accelerating its a notch above center where it normally was. do i have a bad oil tube somewhere or a mechanical failure with my gauges. at the same time my speedometer got sticky
Jayhawk077 is offline
post #2 of 6 Old 04-13-2006, 09:10 PM
adamleeanp
thats normal, you need more oil at higher RPMs so it gives you more oil running than at idle.
adamleeanp is offline
post #3 of 6 Old 04-13-2006, 09:19 PM Thread Starter
Jayhawk077
ya but moving 3 notches from idle to when im going 40 doesnt sound right
post #4 of 6 Old 04-13-2006, 09:50 PM
adamleeanp
i have a 2000 also, not 4x4, and it does the same thing, let me know if that is a problem.
adam
post #5 of 6 Old 04-13-2006, 11:18 PM
00XJsport
ive got a 2000 with 4x4 and it does the same thing im sure its fine...
2012 GECKO GREEN JKU Sport S, Limited Slip, 3.73, 6spd, soft top. Officially named Gordon Gecko
2000 XJ Sport, 4.0L, 4x4, NP231, Auto, Flowmaster D50.
00XJsport is offline
post #6 of 6 Old 04-14-2006, 09:09 AM
xj-xile
xj-xile's Avatar
The problem is undoubtedly with the sensor, not your actual oil pressure.
Use this article to troubleshoot the problem: http://www.olypen.com/craigh/pressure.htm.
(brought to you courtesy of the all-knowing Tech FAQ Sticky at the top of the XJ forum)
xj-xile is offline
Oil Pressure Problem? TheIceMan XJ Cherokee Technical Forum 10 05-14-2015 06:27 PM
Oil Pressure problem? Livewire94 XJ Cherokee Technical Forum 24 08-06-2009 04:38 AM
Here we go again..ANOTHER Oil pressure problem Whtfairladyz XJ Cherokee Technical Forum 25 03-06-2009 01:10 PM
Oil pressure problem phickle XJ Cherokee Technical Forum 4 09-26-2004 11:03 PM
Oil pressure problem SpikeSpeigel XJ Cherokee Technical Forum 6 11-08-2003 04:18 PM
