Oil Pressure Problem - JeepForum.com
post #1 of 6 Old 09-07-2012, 06:25 PM Thread Starter
spalatucc
1997 XJ Cherokee
Hi guys,
I recently rebuilt my engine, and got it up to 500 mi with no issues. However, when I changed the oil @ 500, as my manual said too, my oil pressure gauge has started going haywire.
When I first start up my jeep it registers as normal pressure, right around the middle mark (at least this was what it did before the rebuild), but after driving for about 5-10 min the gauge drops to zero and the "Check Gauge" light comes on. After I stop, shut off the engine, and let it sit for like 15min, when I start it up again the pressure gauge goes back to normal.
Does that make sense? Do you think it's just a problem with the gauge? (Remember this only started after my recent oil change).
spalatucc is offline
post #2 of 6 Old 09-07-2012, 06:37 PM
tjwalker
It's the crank sensor!
tjwalker's Avatar
I think it is likely to be more of a problem with the oil pressure sending unit.
The sending unit is located directly above the oil filter. It can be jostled when you or a shop is changing the oil filter.
First thing to do is to check the connector leading to the sending unit. If it is okay, I'd recommend changing that sending unit. It is a very common fail. And if you do so, do yourself a favor and buy the replacement directly from Jeep for the best reliability/accuracy/mating with your factory gauge.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #3 of 6 Old 09-07-2012, 07:31 PM
CF
What's this sending unit look like? Not to hi-jack the thread. But I think I just blew mine up and now Im leaking crazy. Oil pressure gauge was pegged high since changing the oil a month ago.
So just a heads up.
94' XJ - 3"lift, 31s
CF is offline
post #4 of 6 Old 09-08-2012, 04:34 AM
tjwalker
tjwalker's Avatar
So just a heads up.
Look above the oil filter and you can't miss it. And if your sending unit is leaking oil, you better get a new one in there and do it fast as if it's leaking now, it could catastrophically fail and leave your engine without oil.
And then you'll have much bigger fish to fry.
tjwalker is offline
post #5 of 6 Old 09-08-2012, 03:20 PM Thread Starter
spalatucc
1997 XJ Cherokee
Hmmm... Well I replaced the sending unit when I rebuilt the engine because I accidentally broke the old one. The replacement is from Advanced Auto and not a OEM part. I guess that makes sense.
Back to the dealership I go
post #6 of 6 Old 09-08-2012, 05:00 PM
tjwalker
tjwalker's Avatar
[QUOTE=spalatucc;14140182Back to the dealership I go[/QUOTE]
Good idea.
I buy plenty of aftermarket parts, but the oil pressure sending unit, crankshaft position sensor and most other engine management sensors I buy only from Jeep. Money well spent for reliability AND longevity.
tjwalker is offline
gauge , oil , oil pressure
oil pressure problem michaelleegarre XJ Cherokee Technical Forum 8 01-22-2012 07:51 PM
oil pressure problem mikethefisher XJ Cherokee Technical Forum 6 11-16-2010 04:23 PM
Oil Pressure Problem RedZeppelinXJ XJ Cherokee Technical Forum 3 08-27-2009 10:01 AM
Here we go again..ANOTHER Oil pressure problem Whtfairladyz XJ Cherokee Technical Forum 25 03-06-2009 01:10 PM
oil pressure problem Jayhawk077 XJ Cherokee Technical Forum 5 04-14-2006 09:09 AM
