oil pressure problem - JeepForum.com
post #1 of 7 Old 11-15-2010, 10:06 AM Thread Starter
mikethefisher
ok, heres the deal. changed my oil and oil filter since my gauge was pegged out at 80. thought it might be clogged. now the gauge sits on 80 at idle and until i reach a speed of about 35 plus mph. you guys think its a faulty sensor? i know that the sensors are sensitive and will go bad if you bump it or something.
mikethefisher is offline
post #2 of 7 Old 11-15-2010, 11:53 AM
the_weirdo
the_weirdo's Avatar
Swap out the sensor.
the_weirdo is offline
post #3 of 7 Old 11-15-2010, 12:04 PM Thread Starter
mikethefisher
plan on doing that this weekend!
post #4 of 7 Old 11-15-2010, 04:05 PM
tjwalker
It's the crank sensor!
tjwalker's Avatar
Pegged oil pressure is almost assuredly the oil pressure sending unit.
I buy mine from Jeep for best accuracy/reliability/mating with your factory gauge.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #5 of 7 Old 11-16-2010, 04:16 PM Thread Starter
mikethefisher
sounds good. should be pretty simple to replace right? im also wanting to replace my crank pos sensor. i know where its located. shouldnt even take 10 minutes to replace? or is it harder than what i thought?
post #6 of 7 Old 11-16-2010, 04:40 PM
tjwalker
tjwalker's Avatar
It will take longer than 10 minutes.
Search this forum for "crankshaft position sensor" and you will easily find a thread that has pics and the procedure.
tjwalker is offline
post #7 of 7 Old 11-16-2010, 05:23 PM Thread Starter
mikethefisher
ok will do, thanks
Oil Pressure Problem RedZeppelinXJ XJ Cherokee Technical Forum 3 08-27-2009 11:01 AM
Oil Pressure problem? Livewire94 XJ Cherokee Technical Forum 24 08-06-2009 05:38 AM
Problem with my oil pressure rnuover XJ Cherokee Technical Forum 11 01-27-2008 01:30 PM
Oil pressure problem phickle XJ Cherokee Technical Forum 4 09-27-2004 12:03 AM
Oil pressure problem SpikeSpeigel XJ Cherokee Technical Forum 6 11-08-2003 05:18 PM
