Oil Pressure.. Opinions! - JeepForum.com
post #1 of 13 Old 09-04-2012, 05:59 AM Thread Starter
acurrier2012
In my 01 XJ, my oil pressure stays up pretty high, whether im idling, or cruising down the road. Usuall is up around 75-80...
I have my oil changed regularly, and i do not beat on my Jeep.
Any ideas why the pressure would be so high? Thanks in advance.
acurrier2012 is offline
post #2 of 13 Old 09-04-2012, 07:24 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
I'm guessing the oil pressure sending unit located near the oil filter is defective and needs replacement.
cruiser54 is offline
post #3 of 13 Old 09-04-2012, 07:24 AM
Finallyajeep
x2 same thing happened to mine
Firefighters Jeep Club
Finallyajeep is offline
post #4 of 13 Old 09-04-2012, 10:12 AM Thread Starter
acurrier2012
Nice, Never though of that. Thanks!
post #5 of 13 Old 09-04-2012, 10:20 AM Thread Starter
acurrier2012
Oil Pressure Switch..... Oil Pressure Sending Unit.
Any differences? Same thing? Never delt with one. Thanks.
post #6 of 13 Old 09-04-2012, 10:45 AM
jeepkid03
Winning
jeepkid03's Avatar
The switch is for the gauge cluster that has just the oil light. The sending unit is for the cluster that has an oil pressure gauge. You want the sending unit. Also remember that some sensors from the auto parts stores are cheaply made and bad right out of the box. I've had good luck with RockAuto.com as well as dealership sensors.
-Josh
My 0331 Head Swap How-To Thread:
Build Thread:
jeepkid03 is offline
post #7 of 13 Old 09-04-2012, 11:46 AM Thread Starter
acurrier2012
Ill order one of RockAuto.com. Thanks for the advice man!
post #8 of 13 Old 09-07-2012, 05:15 AM Thread Starter
acurrier2012
This is what i see every morning.... Anybody out there seeing the same thing?
post #9 of 13 Old 09-07-2012, 05:17 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Kinda high reading.
post #10 of 13 Old 09-07-2012, 05:23 AM Thread Starter
acurrier2012
Thats what i assumed. It does go down after a 5-10 minute ride. Just didnt know if it was something obvious..
post #11 of 13 Old 09-07-2012, 08:29 AM
jeepkid03
Winning
jeepkid03's Avatar
Did you replace the sensor? Its a common failure.
If you replace the sensor and still have problems I'd suspect the gauge is bad. Check with a mechanical oil pressure gauge first to verify your pressure. They are easily rented from autoparts stores and screw into the fitting that the sensor goes in on the block.
-Josh
Build Thread:
post #12 of 13 Old 09-07-2012, 08:41 AM
Marconis
Same thing has been happening to me for a few months, but I haven't done anything about it. When I start my XJ, it goes straight to 80. When driving, it stays at 80. Sometimes when I idle, it goes to a little above 40 (where it used to always be most of the time), and then shoots right back up to 80 when barely hitting the gas. I'm guessing it's the same problem as you.
Marconis is offline
post #13 of 13 Old 09-07-2012, 12:54 PM Thread Starter
acurrier2012
I ordered a new sending unit, but it hasnt came yet. As you stated several times above, thats probably the issue. Just seeing what anybody else has done. Part should be here this afternoon/Monday.
cherokee , oil , pressure
Need Opinions!!! Please give me your opinions!! bmxer0122 XJ/MJ Cherokee Non-Technical Forum 5 05-05-2011 06:29 AM
ac pressure cycling and high pressure cutout NorbertSTL XJ Cherokee Technical Forum 8 08-11-2010 10:33 AM
Low Oil Pressure *Not Sending Unit* need opinions please... MB_01XJ XJ Cherokee Technical Forum 16 12-08-2008 08:27 AM
New & need some opinions.. trailrunnerx XJ Cherokee Technical Forum 2 03-02-2004 09:58 PM
Need some opinions b(k)ill94xj XJ Cherokee Technical Forum 3 03-02-2004 02:04 PM
