Oil pressure guage pegged - JeepForum.com
post #1 of 5 Old 10-13-2009, 05:42 PM Thread Starter
carenza
Hey there all, my oil pressure guage has been pegged past the 80 psi (like it isnt even connected) and before it worked fluctuating from 40-80 so it was still messed up. Well I replaced the sending unit, still no dice its pegged at max. The needle doesnt move in the on position at all. I grounded the wire for the sending unit and the guage will go to 0 right when grounded so I know the guage works. I highly doubt I have 2 completely shot sending units, I plugged the sending unit into my friends cherokee and it works fine.
Any ideas?
carenza is offline
post #2 of 5 Old 10-13-2009, 08:09 PM
dacotua
1992 XJ Cherokee
Your gauge died.
dacotua is offline
post #3 of 5 Old 10-14-2009, 08:09 AM
tooofast
did you get the correct sending unit? there is one for the light on the dash for about $5 and one for the gauge for about $15. its just a thought as the previous owner had put the wrong one in on mine and thats what i had.
If you have the correct one and dont have a connection (wire) problem then as stated it likley to be the gauge in the dash i would think.
Dave
4" clayton long Arm, 5 inch rear stretch. CRAWLER tank. 35" KM2 muds, 1" MML from Brown Dog. Rear D44 Locked with a Detroit & trussed on Alloy Shafts, 4 point triangulation. Rear disc conversion. AtoZ Cage. Rubicon OR241 4:1. Front D30, Polly Performance Sleeve kit, locked with ARB, Alloy Shafts and HD steering linkages. Clayton belly up and oil pan skids, PSC Rocker Knockers, ORO air powerd Swayloc, Onbard Vita 450 and tank for fills and ARB compressor for the locker. Covered in dents.
tooofast is offline
post #4 of 5 Old 10-14-2009, 08:21 AM
BunnyHunterOG
did you accidentally disconnect it near the oil filter last time you changed the oil?
BunnyHunterOG is offline
post #5 of 5 Old 10-14-2009, 08:24 AM
foxr4cing27
1989 XJ Cherokee
did you tighten it too tight. cuz it should be just snugged i believe
foxr4cing27 is offline
Oil pressure pegged at +80psi? SerialKiller XJ Cherokee Technical Forum 16 12-13-2010 09:06 AM
Oil pressure pegged out at 80! Specops54 XJ Cherokee Technical Forum 14 02-01-2010 06:20 PM
oil pressure guage is pegged on high CDX74 XJ Cherokee Technical Forum 12 12-10-2006 06:29 PM
Oil Pressure pegged this morning...then back to normal cj7guy XJ Cherokee Technical Forum 10 12-08-2006 03:17 PM
oil pressure guage is at 0 SpecR XJ Cherokee Technical Forum 2 10-29-2006 07:38 AM
