Oil pressure drops? 4.0L - JeepForum.com
post #1 of 17 Old 03-26-2010, 06:10 PM Thread Starter
JeepNoma
So my 1998 oil pressure drops when at idle and the minute i accelerate the needle jumps back up to 40psi. it happens maybe once a month..any ideas?
JeepNoma is offline
post #2 of 17 Old 03-26-2010, 06:48 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Check your oil pressure with a manual gauge. It is possibly the sending unit. Exactly which oil filter are you using?
cruiser54 is offline
post #3 of 17 Old 03-26-2010, 06:52 PM Thread Starter
JeepNoma
where is the manual tie in? and the thing that sucks is it rarely does it so id have to check it manually on the road.
JeepNoma is offline
post #4 of 17 Old 03-26-2010, 06:55 PM
bmac13sv
does it do it when it gets hot? mine does it only when i idle and when its already hot. it SUCKS and i run 10w-40. Im wondering if it my sender. we might be in the same boat/.
Jeep XJ. 3.5" Full spring pack Rusty's suspension. aFe cold air intake. 33x12.5x15" BFG TA KO's on Cragar Soft 8's. 60mm TB. JCR Offroad Stage 3 Front and Rear Bumpers. New 4.0L (victim of 0331 head). aFe cold air intake. Dynomax Catback.
BUILD THREAD: http://www.jeepforum.com/forum/f177/bmacs-2000-xj-build-1292498/
bmac13sv is offline
post #5 of 17 Old 03-26-2010, 06:56 PM
COLOUXJ
2010 JK Wrangler
what is your pressure at idle?
COLOUXJ is offline
post #6 of 17 Old 03-26-2010, 07:02 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Oil pressure is directly related to engine RPM's. With a warm engine, oil pressures should be 10-20 psi at idle and 40-60 psi at 60mph.
If your gauge does not register these changes, you may have a bad oil pressure sender, or a wiring problem.
CJ7-Tim is offline
post #7 of 17 Old 03-26-2010, 07:15 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
What CJ-7 Tim is suggesting is what I was getting at. If it's that intermittent, and knowing the high failure rate of sending units, I would probably bite the bullet and replace the sender. As to your question about where to hook up a manual gauge, it is the same place your sending unit is threaded into now. You would unscrew the factory sender and screw in the manual gauge hose.
post #8 of 17 Old 03-26-2010, 08:19 PM
captreebb
My oil pressure always increases with increased engine speed and the opposite.When my sender went the gauge just spiked.Thats all I know about that.
captreebb is offline
post #9 of 17 Old 03-26-2010, 08:28 PM
GearGuy10
I've had a couple occasions where the oil pressure will swing wildly from idle to acceleration. It always happened after changing the oil and filter. Each time I grab a new filter and swap it out and it goes away. I've heard the cheap oil filters can cause this type of thing and in my experience it seems to be true. I've also replaced the oil pressure sending unit twice over the years and in those cases the pressure just goes to zero and stays there.
Try a new filter. The $3-4 might be worth it over the $40 for the sending unit.
HIS: 1998 Cherokee Sport Chili Pepper Red-SOLD
DrawTite front hitch
HERS: 2009 Liberty Sport Light Graystone Pearl
100% Stock
GearGuy10 is offline
post #10 of 17 Old 03-26-2010, 08:32 PM
yukonwheeler
just tap the gauge like everyone else does unless your engines about to die which i doubt being as its the 4.0L and killing those is difficult to say the least. my guess bad gauge mine drops off to nothing all the time till i tap it
yukonwheeler is offline
post #11 of 17 Old 03-26-2010, 08:48 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
The cheapie oil filters should not be used. The 4.0 oil filter mounting arrangement necessitates using an oil filter with a high quality anti-drainback valve. Use either the factory filter from the dealer or Wix or Napa Gold.
post #12 of 17 Old 03-26-2010, 09:55 PM
GearGuy10
I used to buy whatever filter was cheapest and that was when I had the fluctuation issues. I started buying Mopar filters at Walmart and have never had the issue since.
100% Stock
post #13 of 17 Old 03-26-2010, 10:00 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
GearGuy10 qualifies for the "been there, done that" award and I thank him for his response and support.
post #14 of 17 Old 03-26-2010, 10:29 PM
bmac13sv
i have a mobil 1 filter on there now. I just replaced my cracked 0331 head and thought that was the issue because the crack would propigate when the engine was hot. but it seemingly did not solve that problem. i no longer lose coolant though but when im at a hot idle it will definitely drop to under 10 and the check gauges light will come on. im gonna check it with a mechanical gauge sometime soon here.
bmac13sv is offline
post #15 of 17 Old 03-26-2010, 11:18 PM
the_weirdo
the_weirdo's Avatar
This is totally normal - you should have more oil pressure with higher RPM. You should be above 13 psi at hot idle, and above 30 psi at hot when driving.
Most cars have "idiot" gages that don't move according to the actual oil pressure. The Jeeps do, which is a benefit. When the oil is hot and your idle pressure is above 13 psi then you are fine.
the_weirdo is offline
fuel pump replaced pressure still drops fiddlin1 XJ Cherokee Technical Forum 1 05-03-2009 07:48 PM
Oil Pressure Drops to 0PSI When It's Warm xjarchaeologist XJ Cherokee Technical Forum 10 04-22-2009 09:44 PM
Wierd oil pressure problem - Drops to 0 at idle! Whtfairladyz XJ Cherokee Technical Forum 7 11-24-2008 02:26 PM
Oil Pressure Drops drastically after driving a distance OoOBigWillyOoO XJ Cherokee Technical Forum 30 07-02-2008 12:26 PM
oil pressure drops to 10?????? arieljeep XJ Cherokee Technical Forum 10 12-09-2004 08:10 PM
