oil pressure drops to 10?????? - JeepForum.com
post #1 of 11 Old 12-08-2004, 08:59 PM Thread Starter
arieljeep
i have an xj98 4.0. it seems like everytime i drive from brooklyn to manhattan,on the way to manhattan the oil pressure is fine, but on the way bak on stop lights the oil pressure drops to 10.why is that happening?
arieljeep is offline
post #2 of 11 Old 12-08-2004, 09:19 PM
Vertisce
lots of stuff could be going wrong. Bad idle speed, blown head gasket...pray thats not the problem...among other things...could also be that there is too little or too much oil in the engine.
Vertisce is offline
post #3 of 11 Old 12-08-2004, 11:39 PM Thread Starter
arieljeep
oil tevel is OK
oil level is OK
post #4 of 11 Old 12-08-2004, 11:40 PM Thread Starter
arieljeep
oil tevel is OK.
oil level is OK.
post #5 of 11 Old 12-08-2004, 11:40 PM
jandj
jandj's Avatar
if your relying on a stock gauge and there is no other evident that there is a problem I would get a good gauge and see what the pressure is really at. Stock gauge usually aren't that accurate. Bad oil pressure is a major problem, that why I have a new motor My oil pump went bad at 90K, My wife heard it knocking on her way home, so I took it out for a test drive and 100yards later the motor seized up.
sold my 96' XJ
Look'n to purchase now
jandj is offline
post #6 of 11 Old 12-09-2004, 12:00 AM
Kamaaina
On a hot day my 98XJ oil pressure will sometimes drop down to 10psi. I have 86K miles and use 10w-30. Like it was said earlier if your using the gauge on the dash it's not at all accurate. I've read other posts that also say the same thing.....it's normal.
Kamaaina is offline
post #7 of 11 Old 12-09-2004, 05:37 AM
blackbelt
blackbelt's Avatar
The stock guage is almost useless. Mine looks like it is working normally, but if i punch the gas, it DROPS! . Get a good guage and check it out for your peace of mind.
2001 XJ Sport
2007 Caliber R/T AWD
2000 Subaru Forester
2006 Scion xB
1987 VW Wolfsburg Cabriloet
1969 SAAB 96 V4
blackbelt is offline
post #8 of 11 Old 12-09-2004, 06:59 AM
homerscj7
homerscj7's Avatar
I get the same thing in my '98 while wheelin'...considering my old '90 rarely even showed any pressure, 10 psi is great
The road to destruction is paved with good intentions
homerscj7 is offline
post #9 of 11 Old 12-09-2004, 07:06 AM
XJ99
XJ99's Avatar
2006 XK Commander
It seems like the older the oil gets, the worse the oil pressure becomes. Mine will drop below the 20 line on hot summer days...
When we do right, no one remembers. When we do wrong, no one forgets.
XJ99 is offline
post #10 of 11 Old 12-09-2004, 08:44 AM
XJMark
XJMark's Avatar
The last time mine did that it turned out to be a gunked up oil filter. Changed out the filter, problem went away.
HTH,
Mark
XJMark is offline
post #11 of 11 Old 12-09-2004, 08:10 PM Thread Starter
arieljeep
i use K&N
I use K&N and the oil is 10w-40 and i had RESTORE
fuel pump replaced pressure still drops fiddlin1 XJ Cherokee Technical Forum 1 05-03-2009 07:48 PM
Oil Pressure Drops to 0PSI When It's Warm xjarchaeologist XJ Cherokee Technical Forum 10 04-22-2009 09:44 PM
Wierd oil pressure problem - Drops to 0 at idle! Whtfairladyz XJ Cherokee Technical Forum 7 11-24-2008 02:26 PM
Oil Pressure Drops drastically after driving a distance OoOBigWillyOoO XJ Cherokee Technical Forum 30 07-02-2008 12:26 PM
RPM Drops mudrunnerxj XJ Cherokee Technical Forum 2 06-08-2008 08:55 AM
