oil pressure - Page 3 - JeepForum.com
post #31 of 34 Old 07-10-2013, 10:40 PM
BIGBADWOLF
Originally Posted by brettgorringe View Post
I don't have a manual. Shouldn't I put like some Lucius high milage oil or something in it if I want the engine to run real smooth and good and longer. I mean if you say not to use some pos filter then I shouldn't use just some oil that's just the number thing the Manuel says. Maybe a fully senthetic?
For your climate 15-40 and the 4.0 go together like peas and carrots!
BIGBADWOLF is offline
post #32 of 34 Old 07-10-2013, 11:26 PM
xjdantheman
1993 XJ Cherokee
i used quaker state defy 10-30 with good results level never seemed to run down. rotella 15W-40 seems to burn up quicker for me.
i have bad valve guide seals and a low end tapping noise i suspect as a cracked flexplate.
i also have low pressure at idle when warm.
xjdantheman is offline
post #33 of 34 Old 07-19-2013, 06:39 PM
brettgorringe
OK guys so I replaced the the oil filter with a Mopar one and it surprisingly did help a little. I know my next step is to test the oil pressure manually but untell I get around to doing that is there anything else I could replace first?
brettgorringe is offline
post #34 of 34 Old 07-19-2013, 10:43 PM
cruiser54
1990 MJ Comanche
Not surprised at all. Drive it for a bit, but check the pressure first chance you get.
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
