Oil Pressue Maxed Out - JeepForum.com
post #1 of 10 Old 02-21-2011, 06:43 PM Thread Starter
nyaben
Really confused by this one. Changed the sending unit on my 2000 roughly 3 weeks ago and oil pressure read like normal (around 60 during acceleration, 45 at idle). Yesterday, I crank it only to find my oil pressure gauge maxed out. I drove it back to school that way and had no issues. I drove it earlier today and no change, pressure gauge is maxed out Any idea of what could be the matter?
Thanks!
nyaben is offline
post #2 of 10 Old 02-21-2011, 06:58 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
If you bought the sending unit from autozone or advanced or the like it is likely faulty. I only use the ones from jeep because of the same problems with 2 in a row from autozone.
xjfever is offline
post #3 of 10 Old 02-21-2011, 07:29 PM
NC96XJ
1997 XJ Cherokee
Could be the gauge. I have a 97 that done the same thing. Changed the sending unit an nothing. Finally swapped the gauge out with another one an it started working properly.
96 xj 4.5" 33" cooper stt's bumpers roof rack
Built Not Bought #312
NC96XJ is offline
post #4 of 10 Old 02-21-2011, 07:38 PM
jeepski89
This is a very common problem, if you change your oil like i did and accidently tap it hard enough it pegged mine out aswell, buy a new one and replace it, its very easy.
jeepski89 is offline
post #5 of 10 Old 02-21-2011, 07:39 PM
97tjtom
if it pegs while the motor is off (key in the on position) then its a bad sender.
Current: 1999 TJ 4.0 5 Speed
Past: 1999 XJ 4.0 Auto, 1993 XJ 4.0 5 Speed, 1997 TJ 4.0 5 Speed, 1994 XJ 4.0 5 Speed, 1993 Cadillac Sedan Deville 4.9L V8, 1991 Isuzu TrooperII 2.8L 5 Speed
97tjtom is offline
post #6 of 10 Old 02-21-2011, 07:56 PM Thread Starter
nyaben
I got the sender from Jeep and like I said, just replaced it. Gauge does peg when motor is off and key is in on position. More than likely the sending unit I got was no good?
nyaben is offline
post #7 of 10 Old 02-21-2011, 08:03 PM
TrailRider94
sorry for a thread jack, but its kinda the same topic, but just saying, my pressure gauge kinda fluxuates, like it stays right around 40 but sometimes its right above, sometimes it right below, some time its right on 40, but mine moves around slightly
TrailRider94 is offline
post #8 of 10 Old 02-21-2011, 08:06 PM
97tjtom
yes. swap it out with a new one. its possible it was hit during installation or was defective
97tjtom is offline
post #9 of 10 Old 02-22-2011, 08:35 AM
Oldjeepman
Check if unit is for a gauge or not,same thing happen to our xj started it up look good and then pegged.checked around and there are two types got 1st one from dealership, 2nd from rockauto,should be listed gauge or not.if your going to replace it worth checking it out?
Oldjeepman is offline
post #10 of 10 Old 02-22-2011, 11:27 AM Thread Starter
nyaben
How long has the RockAuto held up for?
nyaben is offline
cherokee , oil , pressure , sending , xj
oil pressure way maxed out racingbrett XJ Cherokee Technical Forum 10 12-16-2009 05:19 AM
Finally maxed out my suspension (PICS) Rural-Assault XJ Cherokee Technical Forum 15 05-25-2008 01:07 PM
Crap...Oil pressue drops close to 0 when i stop. RamboPants XJ Cherokee Technical Forum 40 12-16-2007 11:18 PM
erratic oil pressue ktmracer419 XJ Cherokee Technical Forum 6 09-23-2005 08:21 PM
Oil presure gauge maxed out... Wisbar XJ Cherokee Technical Forum 4 09-04-2005 09:52 AM
