oil pan damage - JeepForum.com
post #1 of 5 Old 04-17-2007, 01:01 PM Thread Starter
kanky1972
oil pan damage
I went offroad this weekend, and I damaged my oil pan, eventhough it is above my differential. Could it be that my front differential hit the oil pan as I removed the sway bar arms???
kanky1972 is offline
post #2 of 5 Old 04-17-2007, 01:08 PM
skullver
Tarpitz
1991 XJ Cherokee
bumpstops, extend them
Blah blah blah blah.
my Jeepspeed build thread:
skullver is offline
post #3 of 5 Old 04-17-2007, 01:09 PM
Timo_90xj
Timo_90xj's Avatar
It's a possibility, but I'd suspect something else. If you haven't done it already, you might wanna check how the dent looks like and what might have caused it. Front axle can get pretty close to the oil pan under extreme articulation, and if you haven't added any bumpstops it's possible that happens.
I managed to hit my oil pan with the steering shock mount attached to the drag link (on the ORO U-Turn kit). I mounted it in a slightly wrong place, and since that I removed it altogether since I have no need for a SS.
Btw, there isn't too much extra space at the front of the oil pan so I would make it absolutely certain your oil pan isn't hitting the crankshaft (which you obviously would hear) or the main bearing caps.
***Under construction***
Timo_90xj is offline
post #4 of 5 Old 04-17-2007, 01:50 PM Thread Starter
kanky1972
thanks a lot..... so far it seems that as I don´t have any bumpstops, that could be the problem.
Anymore suggestions?
post #5 of 5 Old 04-17-2007, 08:40 PM
severous01
severous01's Avatar
i say if it isn't clunking and it isnt leaking...you're fine. also, if you can still easily remove the plug you're fine.
one thing to check though is the torque on the bolts. since the pan was hit apparently hard, you'll need to make sure the gasket wasnt crushed more than it was supposed to be. so...torque the bolts.
i had some idiot lift the front of my camaro by the oil pan...put a nice dent right in the middle of the pan...where the plug was. the plug was pulling off shavings so i replaced the pan with a canton race pan. everything's good now.
severous01 is offline
oil pan damage? howhedoesit XJ Cherokee Technical Forum 11 12-13-2008 10:07 PM
Frame Damage ausi02 XJ Cherokee Technical Forum 6 03-31-2008 11:52 PM
Assessed the damage Mtxz453 XJ Cherokee Technical Forum 3 09-14-2005 04:18 PM
Should I worry about damage? Help! WarHorseXJ XJ Cherokee Technical Forum 4 06-16-2005 12:02 AM
damage DonEighties XJ Cherokee Technical Forum 1 10-06-2004 04:41 PM
