Oil Pan Both Threads? - JeepForum.com
post #1 of 5 Old 08-01-2010, 01:34 PM Thread Starter
allibaster
EDIT: Title should be: Oil Pan Bolt Threads?
Alright. So I went to change my oil. Last time, I really tightened the bolt due to a light oil leak through the plug. I used a larger socket than I should've to get it off just now. Needless to say, the bolt it messed up. Since this is my only ride, I can't take it out and drive to Ace Hardware for comparison.
My question: What is the threading on the oil pan bolt?
Thanks, guys.
allibaster is offline
post #2 of 5 Old 08-01-2010, 02:33 PM
Holder350
1995 XJ Cherokee
12x1.25 IIRC...just go to your local auto store.....they will have it listed.
95' XJ Country - Stock Skids - D30/D35 Limited Slip - 3" Lift - 31x10.50R15 - 4.0 HO - AX15 - NP231
98' XJ Classic - D30/C8.25 - 4.5" RC Lift - 33x12.50R15 - 4.0 HO - AW4 - NP231
Originally Posted by Azzy View Post
You can tell the character of a person in how they treat someone who can do nothing for them.
Holder350 is offline
post #3 of 5 Old 08-01-2010, 03:38 PM
robsjeepxj
Those bolts are only supposed to be tightened to about 20 or 30lbs which is not very tight at all, over torquing them will only strip out the threads in the block. If the pan is leaking you probably need a new gasket. It could be the rear main seal or the oil filter housing o-rings (not the filter gasket) as well these are common causes of leaks for jeep engines too.
robsjeepxj is offline
post #4 of 5 Old 08-01-2010, 04:28 PM
5-90
5-90's Avatar
1988 XJ Cherokee
Check my site - I list stuff like this...
Use the 1996-up oil sump gasket, the one-piece moulded rubber is easier.
The small screws down the sides are 1/4"-20x1/2". Torque to 84 pound-inches/7 pound-feet. The large ones in the corners are 5/16"-18x3/4", torque to 132 pound-inches/11 pound-feet. A bit of light-duty LocTite (#222 or equivalent, or clear nail polish. Even silicone will work) won't go amiss. Check and retorque after a week's service.
"recon" (sic - reckon)(tm) "hihgly"(tm) "seceed"(tm)
"Outback AIDS - Alcohol-Induced Dizzy Spells"
5-90 is offline
post #5 of 5 Old 08-01-2010, 05:10 PM
Holder350
1995 XJ Cherokee
I believe hes talking about the drain plug guys....
As much as I hate these threads.... rustedxj XJ/MJ Cherokee Non-Technical Forum 17 01-06-2010 01:42 PM
Techno XJ Threads Jebussaves0 XJ/MJ Cherokee Non-Technical Forum 37 12-16-2009 09:16 PM
I know you hate these threads but Which one? bowersk XJ/MJ Cherokee Non-Technical Forum 10 04-14-2009 03:43 PM
New threads... xr8dxj XJ Cherokee Technical Forum 6 09-10-2005 10:57 PM
