Oil in my air filter!!? - JeepForum.com
post #1 of 6 Old 09-24-2008, 12:28 PM Thread Starter
E-Dubs88XJ
There is oil in my air filter. I was told it could be a bad pcv system. I havnt tried that yet but is there any other thing that it could be?
E-Dubs88XJ is offline
post #2 of 6 Old 09-24-2008, 12:30 PM
tangofox007
Try cleaning the CCV suction line. When it gets clogged, crankcase vapors exit through the fresh air intake line and into the air cleaner.
tangofox007 is offline
post #3 of 6 Old 09-25-2008, 10:46 AM
tjwalker
It's the crank sensor!
tjwalker's Avatar
Jeep 4.0 has a CCV system, not a PCV system. You are probably experiencing some BLOWBY, a relatively common problem, especially on your vintage XJ. I had it on my 88 Comanche but it is really pretty easy to manage and it doesn't necessarily mean your engine is on its last leg. Use the SEARCH function for information on BLOWBY; no need to reinvent the wheel here. Good Luck!
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is online now
post #4 of 6 Old 09-25-2008, 11:36 AM
Giviner
Giviner's Avatar
Check out this article. I have an 88 that does the same thing. I just ordered these parts a few days ago which will hopefully fix the problem.
http://jeep.off-road.com/jeep/articl....jsp?id=257985
2003 TJ Sahara
2010 WK
Giviner is offline
post #5 of 6 Old 09-25-2008, 11:54 AM
Ed Rico
1997 XJ Cherokee
Along with the updated CCV parts, you could also switch to a late 4.0L valve cover. It has some revised baffling to help keep oil out of the CCV lines.
-Ed Rico
Ed Rico is offline
post #6 of 6 Old 09-25-2008, 12:08 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
-Ed Rico
x2 If your lines are clogged, you will deff. get oil in the air filter. and it's not really blowby. I had an oil soaked air filter last year, bought new lines and elbows from the factory (around 30 bucks). and havent had any oil in there since.
xjfever is offline
Changing Air filter with performance filter vecky4858 XJ Cherokee Technical Forum 2 05-08-2009 10:39 PM
Fuel Filter 99 4.0 Cherokee?? 159.98 for the filter alone? Mike94ZLT1 XJ Cherokee Technical Forum 24 05-07-2007 06:04 PM
Update: Cone Filter VS Drop in Filter ..... trailblaze XJ Cherokee Technical Forum 4 07-08-2006 01:55 PM
K&N oil filter 91xjgawes XJ Cherokee Technical Forum 9 01-25-2006 10:11 PM
New Air Filter Rescue XJ XJ Cherokee Technical Forum 24 09-22-2005 09:22 AM
