Oil filter question - JeepForum.com
post #1 of 32 Old 08-02-2009, 03:25 PM Thread Starter
Carl48
Oil filter question
Been using Fram PH16 oil filters in my XJ and YJ for years probably because they are what the local parts place sells. Anyways, took a couple of old used ones apart recently with a filter cutter for inspection. The spring for the plastic bypass valve seems kind of wimpy...it only takes less than 10 lbs to fully compress it. However, by comparison, the spring taken from a Champion aircraft oil filter doesn't hardly begin to compress with 10 lbs of weight on it. Just wonder how much oil the Fram filter is filtering and how much it may be bypassing. Anyone have any input on this? Thanks.
Carl48 is offline
post #2 of 32 Old 08-02-2009, 03:32 PM
tangofox007
Normal oil pressure on a Lycoming is about twice that of a 4.0L. And the oil viscosity is higher.
Fram isn't what it used to be. Use a Wix if you want a quality filter. In addition to a poor bypass valve, the Fram anti-backflow seal isn't worth a hoot, either. I used to have lifter clatter at start-up with Fram filters. That problem completely ceased when I switched to a different brand.
tangofox007 is offline
post #3 of 32 Old 08-02-2009, 03:37 PM
Ridin' Around
Not much (Quality filtering going on there). If you search Fram filters on here you will see that we have pretty much voted them off of the island!
You can get the Wix filters at most places as well and they use a coil style by-pass spring rather than the leaf. I cut open a Baldwin this week, it also had the coil. And of Course the Amsoil EAO filter has a coil as well.
The WIX can be grabbed off the shelpf at most places. Also Carquest & NAPA Gold filters are made by WIX, but I have not opened either of those to verify the coil spring.
What concerned me most when I opened the Fram filters was the cardboard end caps they use.
Ridin' Around is offline
post #4 of 32 Old 08-02-2009, 03:42 PM
Rollin
Purolator Pureone is what I run. I run the one for a Mustang 5.0 on my Jeep and I can hold about .5 to .75 qts of extra oil. My TJ had drainback problems with Fram filters because their anti drainback valve blows. Purolator, Wix and Mopar filters dont have this problem so I stick to them.
1998 Jeep Cherokee Classic: Bull Bar, TracLock Chrysler 8.25"
Rollin is offline
post #5 of 32 Old 08-02-2009, 03:47 PM
spnkr94
I've heard nothing good about fram. The worst out there from what i read. I guess they are made of cardboard inserts and have platic valves that let dirty oil leak back into the pan. Not enough oil flow...so I think it'll up your oil pressure according to the sensor. Get a napa gold filter, also heard good things about purolator.
spnkr94 is offline
post #6 of 32 Old 08-02-2009, 03:56 PM
cornbrizzle
1992 XJ Cherokee
I run a NAPA 1515 made by WIX for NAPA the same filter the 5.0 mustang uses it'a a little taller for more filtering media, lot's of people run this filter on their 4.0 on this forum and others
you will neep a tad more than 6 qt of oil on your oil change so go ahead and get 7 qts!!
Brizzle
cornbrizzle is offline
post #7 of 32 Old 08-02-2009, 04:49 PM
mattathayde
i remember on one of the last fram topics that supposedly cumins will void a warranty on any of the motors if a fram filter is used due to how bad they have gotten
i use purolator usually
-matt
mattathayde is offline
post #8 of 32 Old 08-02-2009, 04:51 PM
99Greenmachine
I used to use Fram, but man, I watched too many youtube videos of filter reviews bashing Fram. I chose not to use Fram on my Jeep.
Now, I use the Napa Gold Filter P/N #51515 IIRC
'99 XJ Sport
Thank You Hooligan!!!
[SIZE="4"]XJ Dana 44, Yukon 4.56 D44 Gears, LeBaron hood vents for sale
99Greenmachine is offline
post #9 of 32 Old 08-02-2009, 05:23 PM
Matt Gertsch
www.lp.org
Matt Gertsch's Avatar
I run K&N 3001s. They're a Fram PH8A equivalent but they're top notch quality. Every time I fire my rig up, the oil pressure is there instantly, instead of waiting for several seconds for the rig to build pressure.
Derpy Hooves for President in 2012
Matt Gertsch is offline
post #10 of 32 Old 08-02-2009, 08:42 PM
xJoshxx
2012 WK
Ford FL-A1 Works on the 4.0 Also I hear it's a Monster filter.
I used the K&N one before i switch to amsoil smaller filter but better filtration.
I put the same K&N filter on my g/fs 2000 neon and it held 1/2 qt more haha and weighed almost 3x the stock oil filter empty lol.
K&N 3001 PH8A='s Amsoil Ea015
Sold4" Hybrid lift TeraFlex coils IRO Adjustable LA's Jks tracbar 1.25spidertrax spacers 265/75/16 Dura-tracs
Originally Posted by moPowered View Post
The SRt-8's are a liberty design.
2011 WK2 ORA2 sold
2012 WK2 SRT8 - Current
99 WJ Limited Lifted.
2001 WJ stock 4.0 304k miles
xJoshxx is offline
post #11 of 32 Old 08-02-2009, 08:48 PM
bmyohn
Youngin'
bmyohn's Avatar
i also use the K&N HP-3001
auto zone was having a deal that if you buy the 5+quart jug of valvoline conven. oil and buy a fram filter you get the oil AND filter cheaper then just buying the oil and a different brand of filter...explain that to me lol i suppose theyre just trying to get rid of fram filters haha so i now have a "spare" fram filter sitting in the jeep lol
2014 Jeep Wrangler Sport S
3.6L V6 - Manual
2001 Jeep Cherokee Sport
4.6L Golen Engine Stroker
6.5" TnT Customs Longarm Kitl Ford HP D60 l 6.5" Rock Krawler Coils l TnT Customs HD Trac Barl Omix Ada HD SYE l 1" UBEsl CV Driveshaft l39.5" IROKsl 17x9" Pro Comp 98sl High Clearance Shock Mounts [COLOR="red"] l Hidden Hitch l AJs Custom Front Bumper l SONY Xplod stereo l Alpine Speakers l TnT Frame StiffenerZ l 22" RE SS Brake Lines l 1.5" TnT Customs Boomerang Shackles l Sterling 10.25 *FULL WIDTHS* l JKS Mini Skids and Sway Bar Brackets l 7/8" Heim Joint High Steer
bmyohn is offline
post #12 of 32 Old 08-02-2009, 09:02 PM
xJoshxx
2012 WK
Only time id think about using a fram is doing a motor flush or on somebody else's car haha.
2011 WK2 ORA2 sold
xJoshxx is offline
post #13 of 32 Old 08-02-2009, 11:34 PM
filluptrk
Mobil1. The M1-301 like the PH8A, FL1 etc. Have never heard anything bad about them. Got 6 in a case from a guy on eBay, free shipping. Cheaper than local stores, including WalMart. Phil
filluptrk is offline
post #14 of 32 Old 08-03-2009, 09:30 AM
tjwalker
It's the crank sensor!
tjwalker's Avatar
I run the Puralator Pure One.
Good research numbers and the pricepoint is not much more than an "el-cheapo".
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #15 of 32 Old 08-03-2009, 09:51 AM
jeeptown
Has anybody ran or run a STP oil filter. They are on sale at AZone.
jeeptown is offline
Fuel Filter Question JeepXJ2001 XJ Cherokee Technical Forum 13 12-24-2009 04:41 AM
Oil filter question natertots XJ Cherokee Technical Forum 7 08-16-2009 06:33 PM
Air filter question? badlands1 XJ Cherokee Technical Forum 3 07-22-2009 12:08 PM
Oil filter Question rodneyw71 XJ Cherokee Technical Forum 11 02-02-2006 06:46 PM
Air Filter question 2ksportNY XJ Cherokee Technical Forum 10 02-21-2003 02:38 AM
