Quantcast oil filter oil leak? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > oil filter oil leak?
Old 01-22-2009, 02:33 PM   #1
MxAjN
ok so i came home and i always park in one spot in my driveway but i decided to park in another for once and i saw an oil puddly nothing huge but noticable enough so i check everything and dont find anything, then i checked my oil filter and thats the problem on the bottom of it i found oil like when i touched my hand under it, so i did an oil change and i got a new filter a fram one when i last had an stp just changing it up to see if it made a difference and i checked after driving it and theres still oil coming out of there, i checked to make sure the seal was off the old filter its tightened up good and im just wondering if anyone has had the same problem with a leak out of the oil filter?
thanks guys - Alex
MxAjN is offline   Reply With Quote
Old 01-22-2009, 02:41 PM   #2
jjg214
I have it too, cant tell where its coming from but it seemed so insignificant that i didnt really spend that much time on my back in the 10 degree weather looking for the problem haha. my oil filter always has a little bit of oil on the bottom of it, and it is on tight enough iv checked that 3 times. i was going to replace the oil filter adapter o-rings when its warmer out.
jjg214 is offline   Reply With Quote
Old 01-22-2009, 03:15 PM   #3
mattathayde
kinda basic questions but
did you put the filter on all the way (1 full turn after the seal contacts)? and did you oil it before putting i ton?
only other thing i could think would be that the face the filter seals against is marred
-matt
mattathayde is offline   Reply With Quote
Old 01-22-2009, 03:18 PM   #4
mnoeltne
Might not be the oil filter itself, but an o-ring on the filter adapter?
Mark N
2001 Sport - almost stock
mnoeltne is offline   Reply With Quote
Old 01-22-2009, 03:29 PM   #5
XJNUTTIER
I had the same issue with my 90, and when we looked at it, it was the oil filter flange o ring, that would be a real likey cantidate, and I have to ask. Why are you using a fram oil filter? You can buy a Mopar at Wal mart for $5-6 bucks and way better quality, I have seen 3 engines fail due directly to Fram oil filter, and thee poor quality. 1 filter blew the seam, and lost all engine oil, seized engine before it was realized. 2 two seperate Cummins diesel engines, the internal filter element, AKA: paper, broke down and went into the engine plugging the oil journals, thus starving the engine, leading to engine failure. Cummins will NOT warranty an engine failure, when a FRAM oil filter is used, they are NOT Cummins certified, that may tell you something, if a company like Cummins black balls them, there is something to it.
XJNUTTIER is offline   Reply With Quote
Old 01-22-2009, 03:56 PM   #6
jjg214
mine is a fram... i didnt now know this, it will no longer be haha. and im going to replace all the oil filter o rings once its warm enough to go outside and work without freezing.
as to the poster a bit above, yes i installed the filter correctly.
Old 01-22-2009, 03:58 PM   #7
grn99
Fram filters suck. Most will leak when placed horisonatly. Mopar are better, but I perfer Mobil 1 filters.
One man's junk is another man's Jeep.
grn99 is offline   Reply With Quote
Old 01-22-2009, 05:28 PM   #8
MxAjN
hmm mines installed tightly too the only reason i got a fram is because autozone has a million stp oil filters and a million fram ones also so i thought they were a good brand? and what do u mean by being placed horizontally ? and are the o rings hard to replace?
Old 01-22-2009, 05:30 PM   #9
MxAjN
how much do you think it would be at a mechanic to fix like an estimate?
Old 01-22-2009, 05:41 PM   #10
jjg214
the o rings arent a hard job from what i understand, but frustrating. im going to do it myself, would never consider a mechanic. however, say a 1-2 hour job, at avg of $90 labor for mechanics, not worth it. i hear that the o ring kit at a dealership is only around 20 dollars.
as the horizontal comment, it is referring to the orientation of the oil filter, its on its side because that is how the adapter works...i thought fram was decent too, but apparently not, ill be changing mine.
Old 01-22-2009, 07:05 PM   #11
MxAjN
yeah i hear that mobil 1 makes good oil filters.
Old 01-22-2009, 08:25 PM   #12
blacky_j
how tight should the oil filter be? i tighten it by hand till i can't turn it with my hands no more. or is that too tight?
[IIIIII]
blacky_j is offline   Reply With Quote
Old 01-22-2009, 08:40 PM   #13
grn99
Fram was good till they started outsourcing there tin work. Allied signal still assembles them but all parts are imported.
Old 01-22-2009, 08:54 PM   #14
mattathayde
one full turn from when the filter seal contacts the adapter, you need to get an oil filter wrench to get it on like that, a little more or a little less is probably ok, i put mine on a littler over one full turn
-matt
Old 01-22-2009, 09:25 PM   #15
AZ Jeff
-matt
ONE FULL TURN IS TOO TIGHT!!!!!!!! ALL manufacturers recommend NO MORE THAN 3/4 of a turn AFTER the gasket contacts the mating surface. You should be able to do that with your hands no problem.
AZ-Jeff
1992 XJ 2" lift -- RIP
2000 XJ 3" lift -- Australian Ford Big Brakes up front, rock rails, ZJ rear discs (with WORKING parking brake), C4x4 rear bumper/tire carrier, Hella H4 headlights, IPF driving lights, OEM skid plates, OME springs/shocks, JKS LCA's, JKS Sway Bar links.
AZ Jeff is offline   Reply With Quote
Glock Forum
