which oil filter???? - JeepForum.com
post #1 of 35 Old 05-27-2006, 11:01 PM Thread Starter
marcocor
I am in vancouver canada and I can not seem to find mobil or wix filters any ideas?
I am having the low oil pressure problem and you guys recomend staring with a new filter
marcocor is offline
post #2 of 35 Old 05-27-2006, 11:11 PM
asheets934
I swear by pureone. Really you should be okay as long as it is NOT a POS Fram . . .
89 XJ Wagoneer Ltd. 4.0, AW4, NP242. TBM, Cat temporarily gutted *cough*, Removed Air Box Silencer, flat black rattlecan job. Ghetto Fab all around!
asheets934 is offline
post #3 of 35 Old 05-28-2006, 04:24 AM
cmotsvt
Purolator.
cmotsvt is offline
post #4 of 35 Old 05-28-2006, 08:16 AM
anony91xj
Purolator, Fram, STP, whatever, they all work fine.
1998 VW GTI 2.0
anony91xj is offline
post #5 of 35 Old 05-28-2006, 10:05 AM
schuellk
I would stay away from Fram personally. I've seen plenty of cases of these filters in all kinds of engines where the internal filter media comes apart and starts going through the oil stream. Not a pretty picture after a while.
I stick to PuroOne myself. Best bang for the buck IMHO.
schuellk is offline
post #6 of 35 Old 05-28-2006, 01:29 PM
Trippe
Trippe's Avatar
1997 XJ Cherokee
Location: Tampa: When Hell is just not hot enough for you!
i use k&n oil filters and so far they've worked well for me.
1997 Green XJ 2 door
*RIP*
GREEN JEEP CLUB MEMBER #130
Parrothead Jeeper Union Member #1
Trippe is offline
post #7 of 35 Old 05-28-2006, 02:03 PM
1986Comanche
1986 MJ Comanche
Mobil 1. Best oil filter you can buy...
1986 Jeep Comanche 4x2, 2.5L I-4 TBI, 4 Speed
Blue Jeep Club Member #123
Easy to be a truck. Hard to be a Jeep.
1986Comanche is offline
post #8 of 35 Old 05-28-2006, 07:48 PM
NissanHB41
NissanHB41's Avatar
1997 XJ Cherokee
I use Fram. I change it every 3000 miles and have not had any problems with them.
I sold my XJ. Now I want one again.
NissanHB41 is offline
post #9 of 35 Old 05-28-2006, 07:52 PM
Bowhunter46563
Bowhunter46563's Avatar
Napa Gold(made by Wix) Fram have had issues of coming apart.
01 XJ/4" lift/33" DC Muds/Sidebiter Wheels/Surco/ Hi-lift/Pilot lights/Bad Apple Fab diff gaurds/Front and rear receiver hitches/Rusty's LCA's/ Magnaflow/Rubi HD Track bar and Brace/Big Daddy tie rod/TB Spacer/Ractive air intake/ Jet Stage 1/Pioneeer & Fusion Sound/AJ's Super rails/Warn Skid /BW Flat Flares/Bedlined Rockers and Quarters
Bowhunter46563 is offline
post #10 of 35 Old 05-28-2006, 09:54 PM
XJChris98
x2 on the Napa gold. Seemed to make my oil pressure more consistent.
XJChris98 is offline
post #11 of 35 Old 05-28-2006, 10:09 PM Thread Starter
marcocor
new oil pump????? 2000 xj
having problems with low oil pressure the gauge and sending unit seem to be ok so I put a mech gauge on to see what I really had. It was not good!!! at idle (warm) it was 5-7 psi at around 2500 rpm I got about 30 psi. If I go ahead and change the oil pump should I get a standard or high volume? second question is while I am there should I do the main bearings because I can hear a little knock at idle.can the mains even be done with out pulling the crank.the motor only has 100 thou km or 60 thou miles
thanks guys
marcocor is offline
post #12 of 35 Old 05-28-2006, 10:13 PM
cmotsvt
IIRC the rule is a minimum of 10psi per 1000rpm. What oil viscosity are you running.
cmotsvt is offline
post #13 of 35 Old 05-28-2006, 10:28 PM Thread Starter
marcocor
I just changed it new filter with 10w 30 and a bottle of lucas
marcocor is offline
post #14 of 35 Old 05-28-2006, 11:10 PM
79cherokee
FleetGuard filters are good, if you can find them. Heavy equipment and big truck dealers usually can get them.
03 Liberty Sport 4x4 3.7 auto, stock
84 CJ7 2.5 4 speed , stock
79cherokee is offline
post #15 of 35 Old 05-28-2006, 11:21 PM
josephmartins
Long-time Jeep Nut
josephmartins's Avatar
Couple of great oil filter reviews online if you Google "oil filter review", but they're all a couple years outdated now.
Amsoil and Wix seem to do well.
While Fram never earns high marks it's easier to find and I've yet to have a problem with the premium Frams. YMMV.
I've been using x2 as of late, and I'm seriously considering a high-end bypass system with remote-mounted filter just to see how well it performs. Haven't decided on the brand yet.
Kind regards,
Joe Martins
Milford, NH
12 Wrangler Sahara JK8 conversion, <10 miles (FOR SALE, $56,700)
01 WJ Limited, 4.7, 247, black on black, 157k miles (sold)
96 XJ Classic, 4.0, 242, black on grey, 267k miles (sold)
00 XJ Sport, 4.0, 242, fern green on grey, 76k miles (sold)
90 XJ Wagoneer, 4.0, 242, burgundy on tan, unknown mileage (sold)
97 ZJ Limited, 5.2, 249, black on black, 138k miles (wrecked 12/15/05)
98 ZJ Limited, 5.2, 249, burgundy on black, 197k miles (sold)
josephmartins is offline
Changing Air filter with performance filter vecky4858 XJ Cherokee Technical Forum 2 05-08-2009 10:39 PM
Fuel Filter 99 4.0 Cherokee?? 159.98 for the filter alone? Mike94ZLT1 XJ Cherokee Technical Forum 24 05-07-2007 06:04 PM
Update: Cone Filter VS Drop in Filter ..... trailblaze XJ Cherokee Technical Forum 4 07-08-2006 01:55 PM
K&N oil filter 91xjgawes XJ Cherokee Technical Forum 9 01-25-2006 10:11 PM
New Air Filter Rescue XJ XJ Cherokee Technical Forum 24 09-22-2005 09:22 AM
