Oil In Distributor.... - JeepForum.com
post #1 of 6 Old 05-01-2009, 07:34 AM Thread Starter
Jmprep
Hi Fellow Jeep & XJ Lovers, I have a new problem, which I need your help with. I recently pulled my distributor cap and to my surprise there was alot of oil inside the distributor and on the cap. I am wondering if anyone knows were I can purchase the seal thats internally in the distributor or am I better off replacing the distributor??? Thanks To All...
Jmprep is offline
post #2 of 6 Old 05-01-2009, 08:51 AM
mgramann
A new distributor isn't too pricey. I have never heard of this before. Does your engine have alot of blowby that would have blown the seal out in the first place?
mgramann is offline
post #3 of 6 Old 05-01-2009, 01:52 PM Thread Starter
Jmprep
Hi mgramann, Thanks for the reply. Yes I did have a lot of blowby, the ccv tubing was clogged. I have recently cleaned the vavle cover and all the vacuum lines. So what am looking to do is replace the seal inside the distributor. Do you know where I can get this seal? I priced a distributor $49.00 plus a $20.00 core charge. The XJ budget is kinda tight.
Thanks JR.
Jmprep is offline
post #4 of 6 Old 05-01-2009, 03:07 PM
conrasm
conrasm's Avatar
Since you cleared the clog in the tube, you might not need to mess with the distributor. I'd do a wait and see approach.
Shawn
'00 TJ Sahara (RC 4" LA kit)
'06 Grand Cherokee Limited
'07 Ram 1500 quad cab
conrasm is offline
post #5 of 6 Old 05-01-2009, 03:19 PM
mgramann
10char
mgramann is offline
post #6 of 6 Old 05-01-2009, 03:27 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
The oil should stop being pushed inside the dist. since you have cleared the lines. I agree with the above posts and would clean out all you can and check it in a week or so.
xjfever is offline
where is my distributor? greenchief11 XJ Cherokee Technical Forum 8 02-28-2009 01:01 PM
oil in distributor seeyalaterbye XJ Cherokee Technical Forum 2 02-06-2009 03:51 PM
distributor jtvl5 XJ Cherokee Technical Forum 3 04-07-2008 09:17 PM
distributor? 91cherokeeMatt XJ Cherokee Technical Forum 5 05-06-2005 02:08 PM
2.5L Distributor willysxj XJ Cherokee Technical Forum 1 04-11-2005 12:49 PM
