Quantcast Oil consumption - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Oil consumption
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFREE shipping on Rugged Ridge Soft tops @thejeephut.com
Old 07-30-2009, 05:07 PM   #1
JeepJinx
Oil consumption
JeepJinx is offline   Reply With Quote
Old 07-30-2009, 05:13 PM   #2
mgramann
Maybe try a heavier oil? Most oil consumption is through the rings, sometimes the valve stem seals. Engine blow by is an indicator of these failing.
mgramann is offline   Reply With Quote
Old 07-30-2009, 05:48 PM   #3
AZ Jeff
I would compression test the engine both wet and dry and diagnose further based on the results of those two tests.
AZ-Jeff
1992 XJ 2" lift -- RIP
2000 XJ 3" lift -- Australian Ford Big Brakes up front, rock rails, ZJ rear discs (with WORKING parking brake), C4x4 rear bumper/tire carrier, Hella H4 headlights, IPF driving lights, OEM skid plates, OME springs/shocks, JKS LCA's, JKS Sway Bar links.
AZ Jeff is offline   Reply With Quote
Old 07-30-2009, 06:57 PM   #4
JeepJinx
Old 07-30-2009, 07:01 PM   #5
cornbrizzle
1992 XJ Cherokee
pull the plug and squirt a little oil in the hole and then test comp, oil helps seal around the rings to tell you if it's the valves. (wet test)
Brizzle
cornbrizzle is offline   Reply With Quote
Old 07-30-2009, 07:15 PM   #6
JeepJinx
Old 07-30-2009, 09:12 PM   #7
OddTodd72
Definitely look into changing out the PCV valve or whatever Jeep calls, CPV valve or something like that. It is located on the top of the valve cover near the firewall. My buddy had a problem with oil consumption and the front breather tube and air filter were coated with oil and after changing out the plugged PCV valve his oil consumption dropped considerably. They are a pain to get out but I think the valve and grommet were around $15 from the Jeep dealer. Its not really a valve but a plastic elbow with a small orifice drilled in it.
OddTodd72 is offline   Reply With Quote
Old 07-30-2009, 09:36 PM   #8
JeepJinx
Old 07-30-2009, 09:39 PM   #9
mgramann
Originally Posted by JeepJinx View Post
I should have mentioned that I did a compression test, results below. Each cylinder checked 2 times (exc. #1, which was checked 4 times). I don't know what a "wet" test is.
Cylinder compression, from front to back:
#1 127
#2 148
#3 140
#4 140
#5 140
#6 140
Regarding "blow by", I checked the airbox and associated tubes, etc. when purchased. There was some gook in the air tube from the TB to the box, but not that much. I figure that was probably 140k+ miles worth and it was probably never cleaned out. I subsequently cleaned it and it's remained clean since.
Something is up with cylinder 1(obviously) I would perform a leakdown test on this cylinder to determine if it's a valve or the rings causing the compression to be down.
Old 07-30-2009, 10:02 PM   #10
BrunoS
compression check is always done with throttle body wide open.
overall compression is good.
so is oil pressure.
if no smoke is out of tail pipe...and spark plugs are dry...and clean/tan/light brown/gray...
could be an oil drip from oil filter elbow adaptor to block o-ring dripping while idling.
could also be pressure from within block from plugged ccv orifice in the back of valve cover.
step up from 5w30 oil to 10w30, 20w50 if you must in the summer.
for years i've used "restore" with CSL in the silver can (biggest one, $10, use half bottle in idling engine after an oil change and then go for a long drive, or trip) with excellent results, one of the few things to help old motors/rings/lifters out.
put flourescent dye in the oil and then check for external leaks and tailpipe as well...that will nail the leak....
Newly Painted! Emerald Green '96 XJ 4x4 4.0 HO 5-spd
3" Lift + 31" Tires / D35 TracLok / NP231
Drilled out Stock Airbox / Gauge Cluster Upgrade
Magnaflow Muffler / High-flo Cat / MSD Coil
BrunoS is offline   Reply With Quote
Old 07-30-2009, 10:07 PM   #11
AZ Jeff
That is the purpose of the "wet" compression test. If the pressures do NOT go up on a wet test, it's a safe bet that a valve on the cylinder with the unimproved reading is bad.
If the readings go up evenly, then all the valves are good, and depending on how MUCH they go up, you can determine ring condition.
AZ-Jeff
Old 07-30-2009, 10:40 PM   #12
JeepJinx
Old 07-30-2009, 11:33 PM   #13
BrunoS
wet compression test is 5 ml / 1 tablespoon of 30w oil squirted in spark plug hole just prior to cranking for compression testing.
another test is a cylinder leakdown test using compressed air in the cylinder with a pressure gauge and listening to exhaust, intake, or oil fill cap for rushing air.
after your response and symptoms, i suggest checking the engine coolant temp as a possibility as a motor running too hot can also burn oil without other symptoms.
Old 07-30-2009, 11:44 PM   #14
JeepJinx
Old 07-31-2009, 12:24 PM   #15
JeepJinx
Glock Forum
