Oil In Air Filter (jeep Newbie Here) - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Oil In Air Filter (jeep Newbie Here)
JcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRaceline/Allied Wheels on Sale NOW !
Unread 10-26-2007, 08:23 PM   #1
indyfireman419
Ok, I know this has prob been addressed here before but not real sure yet on how to navigate and search effectivly. I have a 92 Cherokee 4.0 and stock airbox. I opened it up to find quite a bit of oil in it and on the filter. The parts guy at the local store who is a self proclaimed "Jeep guy" said this is common and that there is no fix to it due to poor design. I would have to think that someone if not DC came up with a fix of there own. He said that there is no PCV valve and that the lines are just vents and will always leak oil like that....
indyfireman419 is offline   Reply With Quote
Unread 10-26-2007, 09:41 PM   #2
cnskate
I had the same problem with my 94 and I fixed it by replacing the clogged vent hoses and spraying some cleaner in the valve cover vents(I changed my oil right after). The hose kit is cheap and common from a dealer. Find a new "Jeep" guy.
cnskate is offline   Reply With Quote
Unread 10-26-2007, 09:52 PM   #3
pgdyk
1988 XJ Cherokee
The valve cover on these jeeps are a crappy design, at high rpm all the oil flying around in there gets past that little roof in the valve cover that is supposed to keep oil out and let air escape. The lines get clogged like said before. It could also be a more serious but unlikely problem - heavy blowby, but if you don't burn oil you don't have that problem. And in my book, any tube that runs from the valve cover to the air box is pcv. I think there is a write up on this forum somewhere about oil in the air cleaner.
88 XJ 194K 4x4
84 Dodge Ramcharger 4x4
pgdyk is offline   Reply With Quote
Unread 10-26-2007, 10:26 PM   #4
indyfireman419
I saw a write up about using a different pcv and tube setup involving a air cuck fitting. I believe it was probably for the one closest to the firewall that goes into the manifold????
92 Country Cherokee 4.0
Homemade free flow exhaust
Always lookin to Mod. Just started with this much to come...
Unread 10-26-2007, 10:42 PM   #5
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
I went ahead and spent the $25 or so and replaced mine with 00-01 CCV lines. Nice new clean fixtures and a wider tube in the rear.
I think I have that link in the Tech/FAQ sticky.
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
http://www.cardomain.com/ride/325707/1
http://www.cardomain.com/ride/2406854/1
balloo93 is offline   Reply With Quote
Unread 10-26-2007, 10:55 PM   #6
BB1980
The way it was designed was to allow fresh filtered air to enter the valve cover on the front connection and then the intake manifold would suck the pressure off through the way smaller tube running to the back of the VC. When the smaller tube gets clogged or whatnot, the suction starts pulling the blowby through the larger airbox hose and the oil starts dripping on the filter. I am testing a PCV valve inline on the larger front hose to see what difference it makes. I will get some pictures up after a little while.
BB1980 is offline   Reply With Quote
Unread 10-27-2007, 08:01 PM   #7
AZ Jeff
If you are using the front opening the valve cover to vent crankcase vapors, WHERE is your inlet for fresh air into the crankcase?
The crankcase ventilation system needs an inlet and an outlet. Sounds like you turned your inlet into an outlet, so where is the new inlet?
AZ-Jeff
1992 XJ 2" lift -- RIP
2000 XJ 3" lift -- Australian Ford Big Brakes up front, rock rails, ZJ rear discs (with WORKING parking brake), C4x4 rear bumper/tire carrier, Hella H4 headlights, IPF driving lights, OEM skid plates, OME springs/shocks, JKS LCA's, JKS Sway Bar links.
AZ Jeff is offline   Reply With Quote
Unread 10-27-2007, 11:25 PM   #8
BB1980
That is the inlet. The front is the inlet that should let fresh air IN to the crankcase, and the rear vents it into the intake. The problem comes when the rear gets clogged and it trys to vent through the front into the airbox and gets oil into the filter and can get up to the throttle body as well due to engine suction. I was trying to put a PCV in line to not allow the front to vent backwards into the airbox, but found out tonight that when the rear gets clogged, the crankcase gets pressurized and the jeep started sputtering in high gear under load. There was oil trying to push past the oil fill cap to vent out.
A better fix would probably be to allow the front to go both ways but to put a catch bottle inline that would collect the oil and be able to be drained.
This link is for an XJ Jaguar I found while searching, but looks interesting.
http://bernardembden.com/xjs/pcvfilter/index.htm
Unread 10-28-2007, 11:01 AM   #9
BB1980
This also looks helpful:
http://jeep.off-road.com/jeep/articl....jsp?id=257985
http://jeep.off-road.com/jeep/articl....jsp?id=257836
Unread 10-28-2007, 11:10 AM   #10
AZ Jeff
Thosse links reference the later style CCV plumbing that Jeep introduced to improve the flow rate (and reduce clogging) of the crankcase vent system.
I know of no later style CCV system that have developed the "puking of oil into the air filter" issue that plagued older 4.0 engines.
I think that it's safe to say that installing that cheap (and proven) upgrade would fix your crankcase venting issues once and for all.
AZ-Jeff
Unread 10-30-2007, 12:27 PM   #11
indyfireman419
I went to the madxj website and found the parts list for the conversion. My local dealer wants 55.00 just for the 2000 intake manifold nipple. Hell for that I might as well buy a new intake off ebay for 100.00. Anyone have luck finding an online parts distrubtor to find all the necessary parts???? They want 35.00 for everything else needed including a new front tube assembly for the front.....
