Ohm output for fuel float - JeepForum.com
post #1 of 2 Old 02-20-2010, 09:20 PM Thread Starter
whiteys_red_XJ
Hi I have a 96 cherokee xj with a straight 6 4.0 litre i think my fuel float is on it's way out when I feel up my xj the gas pump stops so I know my tank is full but my gage only reads 3/4 full and it won't go lower then 1/8 full so I was going to get a new float thought jc whitney but I need to know my ohm out put for the float and also someone had told me that the float is in the pump and sending unit is it seperate or all in one unit
96 xj 3.5 rustys lift, 33x10.50x15 BFG MT, t case skid plate, front tow hooks, open front and rear diff, NP-242 T-Case 1 in drop, AW4 transmission, dana 30HP, chyrsler 8.25 stock gears, K&N drop in air filter, flowmaster 40 series, poweraid throtle body spacer
whiteys_red_XJ is offline
post #2 of 2 Old 02-20-2010, 11:49 PM
Curly5759
5 ohms full, 33 ohms half, 105 empty.
Sender is part of fuel pump assembly (if it is like my tj)
JC whitney isn't going to work for you.
curly
I start what I finish!
77 Jeep Cherokee S
97 Jeep Wrangler
Curly5759 is offline
96 xj , fuel , pump
rear axle end float autograsser XJ Cherokee Technical Forum 9 08-16-2009 03:09 PM
semi float vs. full float ep191 XJ Cherokee Technical Forum 4 10-28-2008 01:30 AM
XJ cherokee rear axle end float jon_tallis XJ Cherokee Technical Forum 1 10-02-2007 08:47 AM
What is a full float and semi float differential. twisted_ed XJ Cherokee Technical Forum 3 06-11-2005 10:37 PM
Why a fuel pump relay output on my A/C Relay twisted_ed XJ Cherokee Technical Forum 0 04-02-2005 03:11 PM
