oh crap, help please. - JeepForum.com
post #1 of 3 Old 08-14-2002, 01:10 AM Thread Starter
cladinshadow
While tightening down a tire a rotor got backed on too far and is now frozen in place. it won't rotate, nor will it come off. it seems to be stuck against the thing that the caliper attaches to. it's the front. i've tried banging it off and i can't get a good prying point. does anyone have any suggestions?
Darren
96 XJ
"Oh, thank god. It's some sort of rescue toaster."
cladinshadow is offline
post #2 of 3 Old 08-14-2002, 02:27 AM
85XJ
The caliper is connected to the knuckle. If it won't bang off, there should be two bolts that an allan wrench fits to remove the caliper. Take caliper off and give er ****. If that doesn't work then heat it and smash it. Good luck
85 XJ / 8" skyjackerrock ready& custom lift / 35x12.50r15 Kumho MT's on 15x10 Rock Crawlers / 4.56 gears / Detroit locker rear-Lockrite front / Bushwacker flares / Slot drilled rotors / detachable swaybar links / Rancho & Skyjacker shocks / 32 gallon tank / Webber carb conversion / posi lock axle engagement /Shania Twain sticker
85XJ is offline
post #3 of 3 Old 08-14-2002, 02:37 AM Thread Starter
cladinshadow
I had already taken the caliper off. I'd look hella dumb if i was trying to remove the rotor w/ the caliper on. ;c)
I finally got it off, took a really hard, and square hit with the sledge.
thanks though!
Darren
96 XJ
Should it still run like crap? bhicks XJ Cherokee Technical Forum 9 04-18-2009 05:50 PM
rusty's adj. LCA, crap or not crap? trailblaze XJ Cherokee Technical Forum 3 12-06-2007 05:43 PM
well crap.... trailblaze XJ Cherokee Technical Forum 1 11-01-2007 12:22 PM
Crap.. RamboPants XJ Cherokee Technical Forum 3 10-21-2007 06:11 PM
Crap onlyinajeep07 XJ Cherokee Technical Forum 6 08-16-2004 04:10 AM
