Quantcast The Official XJ Homebrew Front Disco Thread *Pics* - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > The Official XJ Homebrew Front Disco Thread *Pics*
Old 03-30-2007, 04:46 PM   #1
lost honda pro
1997 XJ Cherokee
Alright, so I've had my '97 XJ Country for almost two weeks, and while I am the usual broke college student, I still want to change stuff, and articulation is always a good thing to have, so I started doing some reasearch...
These sites had some great info, so I'm not pretending I thought this up myself, but I did manage to make a little combo of everything that I think turned out pretty good.
http://www.4x4xplor.com/homediscos.html
http://www.capitaljeeps.com/xjtech/discos/swaybardisco.shtml
http://www.jeepforum.com/forum/showthread.php?t=345039&highlight=swaybar+disconne cts
http://jeep.off-road.com/jeep/article/articleDetail.jsp?id=257851
Alright, now to the write up (pics for each step follow the description):
1) First thing is to pull of the old rusty hardware... Mine was a 17mm on the top of the end links, and 18mm on the bottom... This is what the hardware looks like, less the end link bushings, as I re-used them and they are on the vehicle. The red line is hardware from the top, blue line is bottom hardware.
2) I also wanted to get an extra set of the OE size hardware, in case push came to shove and I needed to replace everything, so I went to Ace Hardware and got new washers, lock washers, and nuts (the top nut is M10 x 1.5, bottom is M12 x 1.75)
3) Next, I test fitted the wing nuts on the top and bottom. They were matching M10 x 1.5 up top, and M12 x 1.75 below. Turns out the axle side of the track bar was too close to the end link bolt, so I had to trim the (passenger side only) wing nut with a Dremel. (Below is trimming the wing nut, and how it fit afterword)
4) Now I put on the wing nuts with the end links in place to mock up where the ideal hitch pin holes would be. Yellow dots/lines indicate where I decided to put em. I used a Ace brand bit for hardened steel, and it went through like a hot knife... I decided to use a 3/32" so there would be plenty of bolt still there.
5) I was going to use a lock washer on the top of the end link, but when I tried unscrewing it, the split dug into the other washer, and the wing nut, so that idea was out...
6) Drilled the hole in the lower bolt using the 3/32" bit referenced above. Hardest part is starting it, then just make sure it goes in straight and centered....
7) Then the top of the end link... Used the same bit and tried to stay true ( a press would have been nice )
lost honda pro is offline   Reply With Quote
Old 03-30-2007, 04:47 PM   #2
lost honda pro
1997 XJ Cherokee
8) Then I took my wire brush attachment on the Dremel, cleaned up the loose bits of metal, then ran the new hardware over the drilled area, to make sure nothing would snag... It was a little tight the first time, but spun freely afterwards.
9) Then just mount 'em up! Mine fit a little tight on top, so I suggest you give a little extra space if possible.
10) Price breakdown:
(2) OE replacement M10 x 1.50 nuts - $0.60
(2) M10 lock/split washers - $0.26
(2) OE replacement M12 x 1.75 nuts - $1.40
(2) M12 washers - $0.24
(2) M12 lock/split washers - $0.30
(2) M10 x 1.50 wing nuts - $1.30
(2) M12 x 1.75 wing nuts - $2.68
(4) 3/32" x 1 5/8" hitch pins (two spares) - $0.80
(4) 3/32" x 2 5/16" hitch pins (two spares) - $0.68
(1) 3/32" carbite (for hardened steel) bit - $2.99
Total: $11.25
I also chose to replace the bushings with some Prothane replacements:
(1) set of 8 bushings (for F & R) - $11.99
Total (with new bushings): $23.24
11) Drove it around the block, went over some speed bumps, my driveway is pretty rough, and it felt 100% stock, so I don't have any concerns for the time being. I will be carrying the spare hardware with me, however, along with some pliers for the hitch pins. You might also want some WD-40 to spray off the threads after some mud/trail running. I was thinking about using the clevis pins, but I didn't like the idea of it flapping around, so utilizing the stock bolts ended up working out.
Please let me know if you have any revisions/typos/websites to include. Hope it was helpful to some broke stocker Jeepers like me...
Disclaimer: The information here is presented to the best of my knowledge. All information given is as accurate as possible, but may not apply to your specific vehicle. I am not liable for any damage or injury resulting from use of information or procedures on this page. Please use all proper safety equipment and practices when working on your vehicle.
Old 03-30-2007, 04:58 PM   #3
Jeepokee
1997 XJ Cherokee
Click free.
Rock Lizard Fabrications 2.5" Leaf Pack Kit, Monroe Sensa-Trac Shocks, 30x9.5 Firestone Destination M/T, 15x7 Cragar Soft 8s with 4" BS, APN Header, Magnaflow Cat, Flowmaster 50 Delta Flow
Jeepokee is offline   Reply With Quote
Old 03-30-2007, 05:14 PM   #4
TehHelmet
2008 KK Liberty
Pretty sweet, man. I've been thinking of doing something similar myself. Nice work.
Colorado Jeep Club Member #76
TehHelmet is offline   Reply With Quote
Old 03-30-2007, 05:24 PM   #5
lost honda pro
1997 XJ Cherokee
Jeepokee - Thank you, Sir.
TehHelmet - Thanks, I really just got bored, didn't have money for much, but figured this is something that will hold me over until I can afford the lift/JKS/tires/etc...
and *EDIT* in #3, it wasnt the track bar in the way, it was the steering stabilizer brakcet...
Old 03-30-2007, 06:33 PM   #6
caino59
nice work and nice walk through.
definitely a worthwhile mod!
caino59 is offline   Reply With Quote
Old 08-18-2007, 03:48 PM   #7
tizzdizz
2003 WJ
So how's it holding up so far?
03 WJ Limited, 4" Zone, 265/75/16 Goodyear Wrangler Duratracs
89 XJ Pioneer: Stock with 31s and a trim. Sold
99 XJ Sport: 2" on 31s with armor and dents. Sold
74 Nova - 2" drop and disc conv. Sold.
My videos
tizzdizz is offline   Reply With Quote
Old 08-18-2007, 05:58 PM   #8
btfury
i used your writeup the other day and made mine... they work great. thanks for the info!
Silver 2000 XJ Classic, NP 231, D30/Aussie, Chrysler 8.25, C4x4 Tow Hook Brackets, Optima Yellow Top, RE 4.5in SF and RE CA Drop Brackets, 32x11.5 BFG MT, RE HD Adj Trac Bar, OMEs, SYE and front DS, C-Rok Steering Brace, AJs Superrails, Precision 4.56s
btfury is offline   Reply With Quote
Old 08-18-2007, 09:01 PM   #9
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
Awhile back I used this modified adaptation of the older design:
http://www.cardomain.com/ride/325707/12
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
http://www.cardomain.com/ride/2406854/1
balloo93 is offline   Reply With Quote
Old 08-19-2007, 09:16 PM   #10
lost honda pro
1997 XJ Cherokee
i remember coming across that page when i was researching how to do mine...
for a stock height XJ, i dont think the geometry would work too well, but now that i'm 2" up, i think that design will keep the swaybar in the OE position, and eliminate the need to unscrew the top of the endlink.
Old 04-06-2009, 02:16 AM   #11
BIGplansNOmoney
Is there any way to put the OEM splined bolt for the bottom of the endlink back in with the same amount of "stuck" that they had??? Cus I took mine out for the clevis pin way and ended up with alot of broken and bent hitch pins and loss of bushings... You couldn't do anything that involved "flex" with them connected or they'd break... so I went for the bolt and wing nut idea and lost them too... I thought about if mixing the 2 would work but you beat me too it lol... nice write-up...
XJ - My anti-drug
JEEPERS: (GE-PURRS): Proud, Arrogant, Egotistical Creatures of the human variety that have an undying passion for motor vehicles manufactured by the JEEP company.
BIGplansNOmoney is offline   Reply With Quote
Old 02-16-2010, 10:17 PM   #12
scottxj96
will this work with a lift ?
scottxj96 is offline   Reply With Quote
Old 02-16-2010, 11:57 PM   #13
oderalxjlaredo
Way to a resurrect a very dead thread.
And no, with any significant lift, you're going to want longer sway bar end links.
by the thing that spins when you drive underneath
oderalxjlaredo is offline   Reply With Quote
Old 02-17-2010, 02:31 AM   #14
chris87xj
Jeepaholic
chris87xj's Avatar
1987 XJ Cherokee
Is that a problem? Better to start another swaybar disco thread?
Yes it will work with a little bit of lift, 2-3".
***Chris***
JeepForum.com/IndyORV@Redbird-SRA
2009 COTY
Originally Posted by wgirvine View Post
You want my opinion? Ok… Shut the hell up... That’s my opinion.
chris87xj is offline   Reply With Quote
Old 02-28-2010, 01:01 PM   #15
scottxj96
i have about 4 inches of lift , my sway bar disc is pretty stretched at the top.. if that makes any sence..
Glock Forum
