The Official SYE (Slip Yoke Eliminator) Thread *All Read* - Page 9 - JeepForum.com
post #121 of 335 Old 07-09-2008, 05:03 PM
winkosmosis
Originally Posted by slvrathlon View Post
I've been quoted in between $160 - $250. I just purchased the JB and sourcing a Drive shaft.
This was full install. Removing T-case, SYE, shaft install.
I've scaled back my plans so I will do 2", and hopefully won't need an SYE... But that's good to know the general cost
Atheist Jeep Club member #3
Non-Astrologist Jeep Club member #?
Pull the Socialist Plug on Old People Jeep Club member #1
winkosmosis is offline
post #122 of 335 Old 07-11-2008, 09:28 AM
slvrathlon
Anyone have any basic measurements on a XJ? Roughly 35"s or so? 97+ drive shaft measurements...
I purchased the JB brand SYE and need to source a DS now
slvrathlon is offline
post #123 of 335 Old 07-19-2008, 01:49 PM
01TJCRAWLER
anyone know the bolt size that holds the cv joint to the yoke on the t-case. the tom wood drive shaft is threaed to accept the bolts that come thru the yoke. my shaft did not come with bolts so i have been trying to track some down...none of the local hardware stores have the right ones.
there not 8mm 1.0 pitch or 8mm 1.25 pitch and there not std fine or coarse thread.
anyone.....
01TJCRAWLER is offline
post #124 of 335 Old 07-22-2008, 11:56 PM
SmrtJustin
SmrtJustin's Avatar
anyone.....
I'd like to know this as well.
1999 Cherokee Classic
Deep Amethyst
60,000 miles
Mods:
Dynomax Cat-back
OME CS035RA Heavy Load Rear Leafs (~3.25")
RE 1334 Front Spacers (~2.5")
P.O.R.C. HD SYE
30x9.5 General Grabber AT2s
B&M SuperCooler 70255 and Temp Guage
SmrtJustin is offline
post #125 of 335 Old 07-23-2008, 06:34 AM
mortalenema
mortalenema's Avatar
If they are the same as stock they are .312-24x1.170. That's 8mm-24 threads per inch x 30mm.
mortalenema is offline
post #126 of 335 Old 07-23-2008, 02:41 PM
SmrtJustin
SmrtJustin's Avatar
Where can I get those bolts? I tried buying M8x1.00x30mm, but they don't thread in properly.
EDIT: I think I found them here: http://www.performance offroad center.com/oscommerce/product_info.php?cPath=37_185&products_id=3767 (remove spaces) but its like $13 to ship them
I'd like to find them somewhere else.
EDIT #2: I found the Mopar part #, it's: 6034 966. A dealership should be able to get that, I'll try calling tomorrow.
Deep Amethyst
60,000 miles
Mods:
Dynomax Cat-back
P.O.R.C. HD SYE
post #127 of 335 Old 08-10-2008, 10:22 PM
Eggdashure
Ok...this is quite possibly a NOOB question, but I am curious on something.
I have pulled my rear driveshaft off several times to lube it in an effort to correct the "thud" I would here after a stop.
Now then, this is totally hypothetical and just a curiosity question. Could I drill a hole in my skip yoke at stock length and one through the U-Joint flange and basically eliminate the "slip" portion of things. Then attach a front DS to this setup? I'm sure there is a reason for not doing it this way, but I recently pulled a DS off the front of a GC and was noticing how it bolts up...which got me thinking...
I mean is it really necessary to buy an SYE HnT?
Eggdashure is offline
post #128 of 335 Old 08-11-2008, 12:46 AM
EricsXJ
The Post man
EricsXJ's Avatar
This is my take on your question. I think the problem with it is the distance that the joint is from the transfer case. A CV joint ("double cardan") is much heavier than the single cardan joint of your stock driveshaft. Having that weight out that far is a lot of leverage which would amplify any vibrations if not make them much worse. In some cases, the stock output shaft has bent from people not having SYEs. I think in this case due to the weight and leverage it is at more of a risk of bending. You will notice that one thing the hack-n-tap does is shorten the output shaft. A shorter piece of metal is less likely to bend than a longer one.
Eric
2000 XJ "PROJECT RUBICON" 3-link front / 4-link rear / coilovers / running 37's on Dana 60s
My website -
EricsXJ is offline
post #129 of 335 Old 08-11-2008, 08:14 AM
Eggdashure
Ok, the weight makes sense. I know that the front DS is meaty. I've never heard of the DS bending though. Being centrifugal I wouldn't think it could...but maybe during some rock crawling with too much pressure? Honestly, I wasn't planning on trying this I was just curious why it isn't an option.
post #130 of 335 Old 09-28-2008, 05:40 PM
tuesdaysdreams
i have a 2001 jeep cherokee xj with a rockyroad 2" lift get some vibes and i wanna put on a SYE? does anyone know what transfer case i have? i need to know exactly what cv drivetrain to get also. im a little lost.
tuesdaysdreams is offline
post #131 of 335 Old 09-28-2008, 05:50 PM
ReconMill
Flat-4 Turbo
ReconMill's Avatar
2005
just so you know there is no such thing as a 2001 FSJ Cherokee. It should be 2001 XJ Cherokee. Welcome!
Kyle - I mod stuff®
2005 Subaru Legacy GT
ReconMill is offline
post #132 of 335 Old 09-28-2008, 08:05 PM
tuesdaysdreams
i thought when i set up this account that i put in XJ, i guess i hit the FSJ by mistake. thanks for pointing that out.
post #133 of 335 Old 10-09-2008, 07:59 AM
RockRodHooligan
RockRodHooligan's Avatar
I'm in the prosess of installing my hack-n-tap SYE from RE, but can't seem to get it to drill deep enough into the output shaft, without burning up the edges of the drill bit tip. I drilled a pilot hole as per instruction, but not sure if it was a 3/16 bit or not(I do know it was a little smaller than 1/4").
I'm not sure if I should A) go get a cobalt bit(not sure the quallity of the supplied bit), B) try a larger drill/tap/bolt, or C) remove the tailshaft and hit it with a drill press(but I don't know how easy/hard it is to do). Any one have any suggestions?
96 XJ:
89 MJ: Project: Ground up - Sold
01 XJ: Project: Silverback - Totaled
***** inches...
Good god man. Indyorv :rofl: d**k and fart jokes. :rofl:
RockRodHooligan is offline
post #134 of 335 Old 10-09-2008, 08:07 AM
1offroadin4x4
If you were drilling good and then just hit a spot where it won't drill any more, you've completely dulled the drill bit. Get another bit the same diameter, hit the hole w/ some wd-40 or other lubricant, and drill away, should solve the problem. Ran into this when I was drilling out my broken spindle bolts. Got so far and then the drill just stopped going in....switched drill bits and worked great. Going to invest in a good drill sharpener next spring.
03 F-250 Super Duty Diesel
01 Cherokee Sport
Member Of: Empty Pockets Offroad Club
emptypocketsoffroad.org
1offroadin4x4 is offline
post #135 of 335 Old 10-09-2008, 08:15 AM
RockRodHooligan
Well I've been making a lot of use of my dads Drill Doctor and a can of PB so far, maybe today will go better after some sleep, I gave up last night about 8:30, too tired to think about it and was getting cranky.
I didn't think about the hard spot in the shaft(like I said, I was tired), gives me some hope though, just try to push though.
96 XJ:
***** inches...
Slip Yoke Eliminator OFFCHAMBERXJ XJ Cherokee Technical Forum 17 03-23-2010 03:04 PM
slip yoke eliminator? travis_floyd XJ Cherokee Technical Forum 4 08-13-2008 02:53 PM
slip yoke eliminator? bdiddydawg1 XJ Cherokee Technical Forum 3 12-30-2007 04:57 PM
Slip Yoke Eliminator... MY00XJSPORT258 XJ Cherokee Technical Forum 2 08-12-2004 08:14 AM
RE slip yoke eliminator heathen68 XJ Cherokee Technical Forum 1 05-02-2003 01:07 AM
