The Official SYE (Slip Yoke Eliminator) Thread *All Read* - Page 8 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > The Official SYE (Slip Yoke Eliminator) Thread *All Read*
Smoking Deal on Jeep Slip Yoke Eliminator Kit with rear 13Rough Country Jeep Suspension Deals at Rockridge 4WD!Spartan Locker Promo Running now @ ROCKRIDGE 4WD plus FREE
Unread 03-13-2008, 09:35 AM   #106
ThxDex
1997 XJ Cherokee
Hello guys ... help a Jeeper from Europe please ;-)
Problem -SYE and still vibes on my 1997 XJ :-(
I read a lot, i tryed a lot but my Jeep still vibes starting at 65mph. As our speed limit here is 80mph and its my daily i want to have it as comfortable as possible and not vibing and humming on the highway.
Setup is 2" lift, 4.0 with 242, Hack n Tap Kit, Tom W. CV cardan. Axel is shimed with 2,5 degrees so the diff yoke is slightly below the cardan - angles should be perfect this way. Tires are okay, all u-joints are new, all wheel bearings are new, motor mounts look okay.
Is there anything left to check that could cause my vibrations?
Can a bad differntial bearing cause vibrations? (because i have some noise from the rear Dana 35 i guess).
Thanks!
Ingo
ThxDex is offline   Reply With Quote
Unread 03-13-2008, 10:27 AM   #107
1badxj
Thanks!
Ingo
Not likely. But quite possibly a pinion bearing.
New Toy: 2005 Rubihara #111 of 1000
Wife's: 2005 Liberty CRD
2.5"lift, Rock Lizard rock rails, Front True Trac, Rear Powertrax N0-Slip locker, & 31" Duratracs on 15x7 rock crawler rims
Tow Rig: 2003 Silver Reg. Cab Dodge 2500 2wd
5.9 Cummins (lots of mods) dyno proven 550+rwhp
1badxj is offline   Reply With Quote
Unread 03-26-2008, 10:19 AM   #108
born2jeep87
Thanks!
Ingo
Have you had your tires balanced recently?
born2jeep87 is offline   Reply With Quote
Unread 03-29-2008, 11:02 PM   #109
Highway 4x4
I did my SYE today. AA/ Woods. Did it alone in the garage. Never had a TC apart before. All went well except I struggeled a little putting it back togeather. Could not have done it without the help here. When I get this thing done I will have to post some picks. I have spent some $$$ but saved some doing it all myself. I got the Woods DS, all heavy duty, it's a beast. My D35 is now the weak link.
Highway 4x4 is offline   Reply With Quote
Unread 04-01-2008, 04:07 PM   #110
trailblaze
highway 4x4... post up more on the aspect of doing this with no t/c internal work expericance... i might give it a shot... i like the fact i can use one d/s as a spare!
also, i've read through this and have seen posts saying you have to use a np231/aw4 front driveshaft....i assume someone measured would know the length differences between the 242/aw4 front shaft and the 231/aw4 shaft???
Matt
trailblaze is offline   Reply With Quote
Unread 04-01-2008, 04:09 PM   #111
mall_crawler
Nah
[B][COLOR="Navy"][ ] lllllllllll [ ][/COLOR][/B]
The Trail Never Ends.....
mall_crawler is offline   Reply With Quote
Unread 04-01-2008, 07:40 PM   #112
trailblaze
kyle... anyone .... i am half way though the rebuild of the older 242/aw4 shaft...am i wastin time?
Matt
Unread 04-01-2008, 11:31 PM   #113
Highway 4x4
OK, for those that are just thinking about doing it but not sure. Watch and read all you can find on the net about this. Get some good snap ring pliers. If you can get a person to help, do it. You don't need to pull the TC but it might be easier to put it back togeather on a bench. Remove the front DS yoke nut first. Keep the area clean!. Have the TC and underside clean before you start. Start in the AM, durring the week is best so there are more people to call for help if needed, tech lines. Don't wory about a bunch of parts falling out, they won't. Get a tube of the mopar sealer for trans pans, it works and is made for ATF. Double check the pick up tube for the oil pump. Good luck and have fun.
Unread 04-02-2008, 12:54 PM   #114
trailblaze
edit:
OK, it's official. xj aw4/231 front shafts are the same length as xj aw4/242 front shafts... and I'm 99.87 % sure.
weld to weld they both are 19" and the "sliding" parts are both 7"....unless there is something i overlooked , it should be exact.
yeah, had to crawl under the jeep.... not knowing was killing me.
now i can stop bringing this back to the top
Matt
Unread 04-07-2008, 11:41 AM   #115
crateampscal
thanks
That helps a lot. Thank you
crateampscal is offline   Reply With Quote
Unread 04-09-2008, 09:44 PM   #116
BTreff-XJ
I've read this entire thread and I'm left with a question. First though a big thanks to the OP for starting this thread and consolidating all the information.
On it's way to me right now is an OME 3" kit and I'll be running 31's. I have a '98 XJ - 4.0L NP231 but I have a manual tranny. I was hoping to get the HD SYE kit and run a front driveshaft from a post 91 NP31/auto XJ but I have read that the manual tranny is shorter than the auto trannies meaning I would need a longer rear driveshaft. I have not seen any confirmation that I can use a front driveshaft with the HD SYE kit on a manual trannied XJ. Can anyone help out? Is this possible or am I going to be stuck with a H n'T and custom DS. I'd like to go the HD SYE/front DS but don't want to chance it with a DD if it doesn't work and I need to order a new custom driveshaft. Thanks in advance.
-Brian
98 XJ - 4.0L 4x4 NP231 AX-15, Custom AL roof rack with waterproof luggage box, retractable awning, 340w F&R, Rock lights, custom rear swingout bumper & rock rails
88 FC - 13B-RE swap, TwinTurbo apox 400 BHP way too many mods to consider listing, track ready, street legal WARNING: TOO MUCH FUN.
BTreff-XJ is offline   Reply With Quote
Unread 05-30-2008, 07:58 PM   #117
01TJCRAWLER
bumb neewbie question here....i have a 01 tj 4.0l 5-speed with a dana 35,2" tera-flex susp lift,and really need a sye due to vibrations...does anyone know what the new drive shaft length will need to be collapsed/extended??
chris
01TJCRAWLER is offline   Reply With Quote
Unread 06-14-2008, 06:38 PM   #118
winkosmosis
Planning to do SYE whether or not I feel vibration after lifting. How much should labor cost for installation of an SYE kit like the JB or RE? I can't do stuff like that or a lift install myself because I don't have a garage or even a driveway.
Atheist Jeep Club member #3
Non-Astrologist Jeep Club member #?
Pull the Socialist Plug on Old People Jeep Club member #1
winkosmosis is offline   Reply With Quote
Unread 07-09-2008, 12:46 PM   #119
afguy
After reading this and looking up prices I dont think the H&T with spicer flange is really worth the savings. $100 for the H&T and $80 for the flange when I can get a full SYE for just a bit more and it bolt right up, not to mention it would have a bigger shaft.
98 XJ Sport with 4.5" lift, 31" MTZs, and other goodies.
afguy is offline   Reply With Quote
Unread 07-09-2008, 01:26 PM   #120
slvrathlon
I've been quoted in between $160 - $250. I just purchased the JB and sourcing a Drive shaft.
This was full install. Removing T-case, SYE, shaft install.
slvrathlon is offline   Reply With Quote
