#76 | |
This should become a sticky!!
Good info here
1989 XJ, 5spd, np231 with bjconversion SYE , re3.5, 33x12.5r15 BFgoodrich ATS, D30 F, Dana 44 from 87 with 4.56s, Custom front bumper. 94 yj: stock everything and 4 angry squarrels under the hood. |
#77 | |
The Guru of Nothing
but basacally the spicer flange is the only thing that can connect to the HnT flange (there is one other but i wont go into that) -Kyle
North Bay, CA Jeepers Post Here My Build Thread ~My Write Ups~ It's Not Just a Jeep, It's a Lifestyle
#78 | |
The Guru of Nothing
again thanks, and im glad you like it -Kyle
#79 |
thanks a bunch for posting this thread. Ive read it several times in the last few months, and i think im about ready to get a SYE now. After reading, im pretty sure i have this right, but just want to double check. I plan on purchasing this:
http://www.jeepinoutfitters.com/scripts/prodView.asp?idproduct=567 which replaces the output shaft. one of my buddys has several front driveshafts from various cherokees and grand cherokees, so as long as they came out of a 91+ cherokee or grand cherokee with an auto transmission, this drive shaft will work just fine correct? id eventually like a tom woods DS, but for now id like to save some money for other things (like my wedding in april!). sorry for bringing and old thread back to life, i just wanted to make sure i was correct before i start shelling out the cash. also, i have an 8.25 rear end, not sure how much that matters. right now, i think i will need the HD SYE kit and a front drive shaft. anything else im missing? thanks for the help!
99 XJ Sport, Rubicon Express 3.5" Super Flex, JKS adjustable track bar, 15x8 chrome cragar soft 8's, 32x11.50 BFG AT, OME Nitro Charger Shocks, hacked front fenders |
#80 |
Just read through this, great information. It may have been mentioned, but I don't recall, it's my understanding the OEM front CV drive shaft won't work unless you have a fair amount of lift, like 3.5 to 4 inches or more because it's too long, in particular on the later models like mine with the 8.25 rear. So it's a bust for say a BB of 2-2.5 inches on these later year models which seem subject to problems with even minor lifts and you end up having to buy a shorter custom CV shaft when you install an SYE. Am I correct in this?
G.Thomas [B]"If at first you do succeed, try to hide your astonishment!"[/B] |
#81 | |
#82 | |
91+ auto 4.0 xj front shaft is what you want. It will work perfect with 3.5" of lift and the 8.25 axle. You'll want to rebuild the front DS before you put it in there. |
#83 | |
The Guru of Nothing
your setup sounds fine, get the HD sye and put a front DS from an auto tranny XJ back there and you will be just fine. As dopod said make sure you rebuild the new front DS with new ujoints. -Kyle
#84 |
what type of uj oints will i need to rebuild it?
#85 |
The Guru of Nothing
somebody chime in here i forgot the exact u joints, but if you go to NAPA they will have the correct you joint numbers for you (thats what i did)
-Kyle
#86 |
The Guru of Nothing
napa PN
Standard Joint NUJ 2180153 Greasable U-Joint PUJ 280 -Kyle
#87 | |
Little Red Menace
http://www.pavementsucks.com/tech/doublecardan.php
93 Sport Beer is proof that God loves us and wants us to be happy............Ben Franklin Specs in Profile. http://www.cardomain.com/ride/325707/1 http://www.cardomain.com/ride/2406854/1 |
#88 |
ok, I've read through all the posts, I think- got a question. My setup- 2 inch spacers up front, 2" AAL in the rear, (stock shackles) 30x9.50 tires on stock 15x7 rims. 96 4.0 w/ aw4 auto tranny, 8.25 rear, 231 tc. Got vibes immediately, so I bought the RE hack-n-tap, spicer flange and front shaft out of a 93 xj. Got everything in the garage, waiting to go in. So, those with experience with this setup, will I need any shims to get the angles right, or will the axle to shaft angle be where it needs to be? thanks
#89 |
The Guru of Nothing
with 2" you should be all set to go with just the SYE. Your pinion angle wont be too much of an issue at 2".
-Kyle
#90 |
cool. I got about 2 1/2 inches from the AAL's, maybe they'll settle some, maybe not- I'm impressed with the Black Diamond stuff- pretty thick leaf, and rides nice too. Oh, yeah, new shocks too - I did the Rock Lizard suggested Monroes and used rear swaybar mounts for BPE's. I'm pretty happy with it so far. I think I'll be really pleased with it when I get the front shaft and sye on.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
