The Official SYE (Slip Yoke Eliminator) Thread *All Read* - Page 16 - JeepForum.com
post #226 of 335 Old 01-11-2012, 11:59 AM
No4x4Yet
Originally Posted by Azzy View Post
I got an answer back that says it will fit, but like you said, might need a longer driveshaft. Ive read that the PORC one will work with a front auto shaft, which is the same price as the Rugged ridge on ebay.
The wait to the next pay begins.... Unless i get some of these other parts sold.
What do you mean it will fit but you need a longer shaft? The shaft fitment (length) is what Im referring to. If the SYE were short enough and you run enough lift the shaft could separate. Not the best of situations.
No4x4Yet is offline
post #227 of 335 Old 01-25-2012, 04:57 PM
motorsports3
1997 XJ Cherokee
What do you guys think of the Tom Woods SYE kit. It is a stock shaft which is modified. How would you compare this to a standard (non HD) SYE kit?
In regards to a stock front drive shaft, do you think it would work with a 6.5" lift and a standard non short SYE kit (Rugged ridge for instance)? 4.0 with Aw4 and 8.25 setup.
How would you compare the strength of a front D/S to a standard Tom Woods drive shaft.
motorsports3 is offline
post #228 of 335 Old 01-25-2012, 08:19 PM
motorsports3
1997 XJ Cherokee
Anyone have an idea? I want to order a kit asap
post #229 of 335 Old 02-06-2012, 08:38 AM
Jeepfan1000
1978 CJ7
Hey sorry if this was already brought up, I couldn't find it, but yesterday on te trail I had to take my front drive shaft off because one of the bolts was missing that attaches it to the yoke but I didn't realize it before but it looks like my front drive shaft has a sye. Do those come stock? It wasn't lifted when I got it and I put 3 " on it with no vibrations. I'm not sure what tcase I have but it's an 89 with a 4.0
Jeepfan1000 is offline
post #230 of 335 Old 02-06-2012, 09:50 AM
rubiprime
I just did a rugged ridge sye this weekend and used a stock front drive line from an auto w/ a 231 t/c and it worked great . also on a 97 xj with 6 in lift.
rubiprime is offline
post #231 of 335 Old 02-06-2012, 05:16 PM
motorsports3
1997 XJ Cherokee
Yeah, I ended up doing a front driveshaft and PORC HD SYE for less than the TW one, and I didnt have to have $100.00 tied up in a core charge.
post #232 of 335 Old 02-18-2012, 07:22 AM
01xjblu
some helpfull info needed
2001 xj 4.0 auto 242 tc with 4" lift and 33" bfg(has vibe 45-55). I'm taking out 8.25 and putting a2002 8.8 with disk brakes in and i would like to do a sye with a yoke not flange (prob h&t) and run a xj front ds. also i would like a yoke not flange on the 8.8. has any one done this if so what parts did you use?
01xjblu is offline
post #233 of 335 Old 02-18-2012, 08:54 AM
SFRautomotive
#WannaBeRockBouncer
SFRautomotive's Avatar
1992 XJ Cherokee
you want a yoke on the 8.8?
dont think anyone has done that. besides, the flange setup is MUCH stronger than a yoke
00XJ limited.....Tons, ORI's, Caged
92xj....Linked, Locked, Caged, Armored...RIP
what are leaf springs?
"You're what's wrong with America. You don't drink enough PBR and you probably run sway bars on the street. Fawking communist."-ibjeepin95
2013 COTY
SFRautomotive is offline
post #234 of 335 Old 02-20-2012, 04:24 AM
01xjblu
Ok thanks. I will keep the flange on th 8.8 I will be doing a iro h&t. Can I still use a front stock ds or will I have to mod the shaft length? Has any one done the iro 8.8 weld on truss?
01xjblu is offline
post #235 of 335 Old 03-07-2012, 09:29 AM
Riley/MN
I did a quick search, but could not find an answer to this - Hopefully it is not one of those things that has been dead-horsed on here....
I have a 98 with 231. I have had the IRO 4" long-arm kit installed (LOVE IT, BTW) and have a little bit of vibration at low speed. Contrary to popular beliefs, I DO drive at lower speeds sometimes, so I had my shop order me IRO's H&T SYE. I also have a Dana 44 Rear from an early XJ that I hope to install eventually.
Should I wait & do the SYE and the 44 at the same time? Have any of you guys that put 44s in your XJs had to change the driveshaft length?
Thanks
~Riley
TMA MN State Rep
http://www.traditionalmuzzleloadingassociation.com
Riley/MN is offline
post #236 of 335 Old 11-13-2012, 01:59 PM
tycloud
Well I guess I found the spot to ask a ? about SYE. This is my first jeep it's a 96 XJ country and I just put a Rusty's 3" with new spring packs on it, and I have Drive line Vibes now. I tried a 1" TC drop and I swear that just made it worse a lower speeds but a little better in mid range and same at highway speed. This is my wife’s DD and we take it camping a lot so I need it to ride smooth at 70+ will the Tom Woods SYE and CV drive shaft do the trick?? Also I'm thinking about taking it to a shop so they can shim the axle if needed. I had the jeep down for 1 week doing the lift, and at this point I just want it running. Money isn't too big of an issue if. Any advice would be greatly appreciated.
tycloud is offline
post #237 of 335 Old 11-13-2012, 02:09 PM
AmbuGrl
AmbuGrl's Avatar
We used a tattons shaft and an AA sye kit
- HM1(SW/AW)Ret USN Dec 23,1992 to Dec 31, 2012
I drive an XJ, and all of my power windows work :)
2000 Pontiac WS6 - DD
DD (Mine) Sold - 98 XJ Moss Green
(His) - 92 YJ December 2013 YJOTM
Sold - 95 ZJ
Sold - 97 XJ Red
Sold - 98 XJ
USN Jeep Club Hull #36
NAXJA #3700
Originally Posted by RacerX View Post
WTF is Clockspring??? my Jeep has digital clock
AmbuGrl is offline
post #238 of 335 Old 11-13-2012, 02:32 PM
roblaza
So I read about 95% of this thread, and I've gained a lot a valuable info on the subject and I want to thank everyone who gave info!
I would like to just confirm what I've read 110% before I bite the bullet and drop the cash (as little as it is, it's still tight for me from just getting out of college). I've got a 3" zone lift in my 99 xj, and I have vibes at 50-60 km/h. I'm looking at the 231 HnT SYE to cure the vibes. From what I've read, If I do the HnT I can then run a front cv style shaft from the same year xj for a rear shaft, correct???
Thanks in advance guys!
roblaza is offline
post #239 of 335 Old 11-13-2012, 02:50 PM
No4x4Yet
Thats correct. IRO even says this on their site.
http://www.ironrockoffroad.com/Merch...egory_Code=XDT
No4x4Yet is offline
post #240 of 335 Old 11-13-2012, 03:53 PM
tycloud
Are there any options out there for those of us with a NP 242 and not a hack n tap other than Tom woods??
tycloud is offline
Slip Yoke Eliminator OFFCHAMBERXJ XJ Cherokee Technical Forum 17 03-23-2010 03:04 PM
slip yoke eliminator? travis_floyd XJ Cherokee Technical Forum 4 08-13-2008 02:53 PM
slip yoke eliminator? bdiddydawg1 XJ Cherokee Technical Forum 3 12-30-2007 04:57 PM
Slip Yoke Eliminator... MY00XJSPORT258 XJ Cherokee Technical Forum 2 08-12-2004 08:14 AM
RE slip yoke eliminator heathen68 XJ Cherokee Technical Forum 1 05-02-2003 01:07 AM
