The Official SYE (Slip Yoke Eliminator) Thread *All Read* - Page 15 - JeepForum.com
post #211 of 335 Old 12-04-2011, 09:56 PM
durrell
1975 CJ5
Just ordered it. Here's to hoping I can do it without ruining the shaft.
durrell is offline
post #212 of 335 Old 12-13-2011, 11:55 PM
KINGJB
Originally Posted by No4x4Yet View Post
I believe that the hack and tap sets the mounting point out further allowing you to run a front shaft in the rear. Im not positive but that what i got outa what I read. So if you did real SYE you also need to buy a new axle.
why would you need a new axle just to install an SYE?
Build Thread:
KINGJB is offline
post #213 of 335 Old 12-14-2011, 12:50 AM
Corcor4
1990 XJ Cherokee
you don't need a new axel... just the sye and extended driveline that you measure, then send the company for them to make you one.
ebay's ur friend.
My second try: 1990 Jeep Cherokee Xj 6.5ish" lift with tj componets, 33" duratrac's, oversized roof rack, onboard air, body armor.
-OREGON JEEP OWNERS, NORTH WEST CREEPING JEEPERS
18 years old and lots to learn :D
Corcor4 is offline
post #214 of 335 Old 12-14-2011, 08:52 AM
No4x4Yet
ebay's ur friend.
I ment to say new driveshaft. I havent seen anyone saying they run a stock from axle with a SYE short shaft kit. If Im wrong please correct me but as far as Ive seen you need the HnT to run a factory front shaft and save money.
No4x4Yet is offline
post #215 of 335 Old 12-14-2011, 08:59 AM
KINGJB
I was gonna say, I've never heard of anyone needed to get a new axle so they could install an SYE.
Build Thread:
KINGJB is offline
post #216 of 335 Old 12-14-2011, 10:25 AM
Kevin108
You did it again.
My build thread has pics again. http://www.jeepforum.com/forum/f177/kevin108s-2000-xj-build-867428/
Kevin108 is offline
post #217 of 335 Old 12-14-2011, 11:09 AM
No4x4Yet
Originally Posted by Kevin108 View Post
You did it again.
I give up!
No4x4Yet is offline
post #218 of 335 Old 12-14-2011, 11:14 AM
aircruiser
aircruiser's Avatar
I am lost but no need for a new axle, just a new driveshaft. I was able to get away with using a stock front driveshaft in mine for 4" of lift to 8.5" of lift. I was looking into doing axle swaps and then I would need to get a custom shaft made but if you are running XJ axles, a stock front shaft will work fine.
aircruiser is offline
post #219 of 335 Old 12-15-2011, 10:03 PM
brian0128
I'm still torn between HnT or the JB SYE. $100 more and less chance of messing something up it seems. If I go ahead and bite the bullet for the HnT, what cut off wheel do I buy at Home Depot. Any 4 inch cutting wheel? And how is everyone keeping the hole they are drilling straight? What if I drill it at an angle?
brian0128 is offline
post #220 of 335 Old 12-15-2011, 10:14 PM
SFRautomotive
#WannaBeRockBouncer
SFRautomotive's Avatar
1992 XJ Cherokee
unless you run a dana 35 or an AX15
stock XJ shafts end up being to short
00XJ limited.....Tons, ORI's, Caged
92xj....Linked, Locked, Caged, Armored...RIP
what are leaf springs?
"You're what's wrong with America. You don't drink enough PBR and you probably run sway bars on the street. Fawking communist."-ibjeepin95
2013 COTY
SFRautomotive is offline
post #221 of 335 Old 12-15-2011, 10:30 PM
aircruiser
aircruiser's Avatar
When I did mine with my friend we jacked up the front, put it in 4lo and let it idle in 1st while he took a 4" cutting wheel to it and slowly took it off, made it smooth, then measure dead center and used a punch as a guide. No issues.
Ah yeah forgot about that I was running an AX15 and 8.25.
post #222 of 335 Old 12-15-2011, 10:56 PM
No4x4Yet
How much is the axle for the JB SYE?
No4x4Yet is offline
post #223 of 335 Old 01-10-2012, 11:39 AM
Azzy
So im lost at the moment, but slowly figuring this all out. From what I have read... a front auto DS and this kit: http://www.ebay.com/itm/1987-2006-Je...item5d31e2361e
Would be what I need. Rather not H&T.
Im the guy who makes new gauges, check out our gallery at Teamadw.com
Azzy is offline
post #224 of 335 Old 01-10-2012, 01:05 PM
No4x4Yet
I dunno if the stock front shaft would fit with a SYE like that. The H&T yoke sits out a good but further.
No4x4Yet is offline
post #225 of 335 Old 01-11-2012, 12:37 PM
Azzy
I got an answer back that says it will fit, but like you said, might need a longer driveshaft. Ive read that the PORC one will work with a front auto shaft, which is the same price as the Rugged ridge on ebay.
The wait to the next pay begins.... Unless i get some of these other parts sold.
Azzy is offline
Slip Yoke Eliminator OFFCHAMBERXJ XJ Cherokee Technical Forum 17 03-23-2010 04:04 PM
slip yoke eliminator? travis_floyd XJ Cherokee Technical Forum 4 08-13-2008 03:53 PM
slip yoke eliminator? bdiddydawg1 XJ Cherokee Technical Forum 3 12-30-2007 05:57 PM
Slip Yoke Eliminator... MY00XJSPORT258 XJ Cherokee Technical Forum 2 08-12-2004 09:14 AM
RE slip yoke eliminator heathen68 XJ Cherokee Technical Forum 1 05-02-2003 02:07 AM
