#151 | ||
2001 XJ- 5.5 inches of lift consisting of 4.5 RE coils and spacer and ajd trackbar, RC full 4.5 leafs, 1 inch Shackle, RC Control arm drop brackets, Extended brake lines, RE HnT. What I still need: 4.56 gears!!! 1997 XJ 4.5 Inch lift, 32's, SOLD 2000 XJ 2 Inch Lift, 30's, SOLD 1990 XJ Cut Fenders, 32's SOLD |
#152 |
Under Construction
Some one did me the same favor when I was looking for mine.
#153 |
Thanks for the great post! Just got a 3.5 RE lift and instantly vibrations at 40-50 mph, "labored" acceleration, and mpg dropped by a third. TC drop and axle shims already done. I'm a newb, got a lot to learn, but I think I'm on the right track now.
#154 |
Im about to do a HD SYE kit on my 96, Ive read the thread like 3 times and am still trying to figure out whether or not a stock front ds will bolt directly up to my tc with the hd kit installed? Is it just the Hack n tap kits that require the 1310 centering yoke to fit the ds? Do all sye kits require you to purchase the spice flange to hook up a stock ds?
96 Country...Weekend warrior |
#155 | |
FOR SALE 1998 Cherokee Classic - White
5" lift - 35" tires - locked/geared/shafted/armored 2012 Subaru WRX Limited |
#156 |
Yea I saw you post before that you got yours from aa, they have it pretty cheap, Im definitely planning on getting it from there. Did you find your front ds fairly easy? The junkyards around me have them from like $75, I guess that sounds about right. Well anyways thanks for the help dcorn, any chance your going to be at the Wheel In at Oak Ridge this year?
#157 |
hello I'm interested in doing the hack and tap sye. is there a write up on this because only half the links on the first page work also besides the drive shaft i would only need the flange from spicer?
does some one make a new shaft that you can just drop in because i will probably rebuild my t.c. when i do this. |
#158 |
Where is the best place to buy an AA SYE?
2000 Jeep Cherokee Freedom 2002 LS1 Camaro 2003 F250 Sonic Blue 20" wrapped in 37 BFG's 2000 S10 Extreme Blacked out on 20's |
#159 |
Rustys has them with a Tom Woods shaft for $480.00
http://rustysoffroad.com/mm5/merchant.mvc?Screen=PROD&Product_Code=AACOMBO1&Cat egory_Code=SYE
2000 Jeep Cherokee Classic 1992 M101 CDN2 1/4 Ton Off-road Trailer. 90% Daily Driver 100% Fun! ____=__= l l ,[_____], l---- L -[]lllllll[]- ()_) ()_)--o-)_) |
#160 |
Hopefully someone can answer this for me...
I searched, and came up with as many questions as answers. lol I have a guy locally selling a front Drive Shaft off of a 1989 Cherokee. I have a 2000 and am installing an AA SYE (as stated in here already). I have asked if it is an auto... and for some measurements, but I am not certain that an older DS will work in a later model XJ anyhow? I need to know... The front DS that will work for my Cherokee by model year (89??)? I have a Dana 30, Chryco 8.25, NP231 and an AW4 auto. I understand that it may need to be lengthened, and that it "may" need a rebuild. I haven't seen it yet so I am not sure of the condition. Help... any advice will help.
#161 |
94 zj 4" lift
I have a 94 zj 4" rough country and I have swap out the 249 for a 242 i'm looking to do a sye. i hear alot of people saying the front ds from a zj will work in the back but mine is shorter than my rear ds. Did I miss something or does my zj require a longer shaft and if i put my front ds back in it vibrates and it turns all the time. Pinion angles are straight with the ds front and back I have tried up to 1.25" tcase drop. I'm also looking for a hub conversion any suggestion this is my first post. the 242 is a 2001 model??? with a 96 zj main shaft to get a speedo gear. the 242 says (on the tag) 242 wj it is the one with a sealed main shaft and exposed slip yoke please help not my dd but my ride of choice thanks great thread
#162 | |
#163 |
Thanks man
#164 |
I just ordered the iro hack in tap i believe if i have the front shaft lengthened it should work shouldn't it. I'm i going to run into problems doing this on a 242 with dana 35?
#165 |
now if i have a 2000 xj with a np242 do i have to use a hack n tap sye or can i use Rugged Ridge heavy-duty SYE kit
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
