The Official SYE (Slip Yoke Eliminator) Thread *All Read* - Page 10 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > The Official SYE (Slip Yoke Eliminator) Thread *All Read*
Poison Spyder from CCOR!Oconee Offroad Sales Tech are Available To Help!Free shipping on slip yoke eliminator kits New lower Price
Unread 10-12-2008, 06:37 PM   #136
01MonsterXJ
great thread!
2001 XJ- 5.5 inches of lift consisting of 4.5 RE coils and spacer and ajd trackbar, RC full 4.5 leafs, 1 inch Shackle, RC Control arm drop brackets, Extended brake lines, RE HnT. What I still need: 4.56 gears!!!
1997 XJ 4.5 Inch lift, 32's, SOLD
2000 XJ 2 Inch Lift, 30's, SOLD
1990 XJ Cut Fenders, 32's SOLD
01MonsterXJ is offline   Reply With Quote
Unread 10-27-2008, 01:00 PM   #137
thetank
awesome thread, really helped me alot, thanks.
thetank is offline   Reply With Quote
Unread 10-27-2008, 02:17 PM   #138
dcorn
Not sure if this thread really helped me out with my install, but all the writeups online definitely did. It was quite a process to get everything installed and put back together correctly, but it seems like its all working fine. I bought a used front driveshaft and all the u-joints and CV center section to rebuild it, but for some reason, the last u-joint in the CV doesn't want to go on. I am certain the parts are correct but its not fitting so I had to use my front driveshaft in the rear and I'm running with no front at the moment. Also, when I filled up the TC with fluid, it barely took more than a quart, even with the XJ on a flat surface. I thought the capacity was 2 quarts.
1998 Cherokee Classic - White - 5" lift - 35" tires - locked/geared/shafted/armored
2004 Grand Cherokee Overland - Stock DD
dcorn is online now   Reply With Quote
Unread 10-27-2008, 07:48 PM   #139
mortalenema
Drivin' me nuts...
mortalenema's Avatar
SELEC-TRAC 242 . . . . . . . . . . . . . . 1.3 L (2.85 pts.)
COMMAND-TRAC 231 . . . . . . . . . . . 1.0 L (2.2 pts.)
How is the u-joint not fitting?
'99 Classic: "Emma"
8.25 * NP242 * Auto trans * 3" OME HD lift * IPF lenses and H4s * Uniden PC78elite
JKS Discos and adjustable track bar * 31" BFG T/A KOs on 15x8 black Cragar soft 8s
Tom Wood's SYE and custom drive shaft * Custom evil shark mouth skid plate * Hingeless 2-way hood vents
Jeeps with Teeth #1
MN Jeeper #14
_____________________________________________
"When is the best time to do things? Who is the most important one? What is the right thing to do?"
"BORN TO WHEEL" PRODUCTS FOR SALE
**********More designs here**********
mortalenema is offline   Reply With Quote
Unread 10-27-2008, 10:24 PM   #140
dcorn
Haha, thanks for the fluid quantities, makes me feel better.
I have no clue what is up with the driveshaft. I put the first u-joint in the CV end in fine. When I install the new spicer part that is the center of the CV joint, then try to put the other u-joint in the TC yolk side of the CV, I can't get the caps on. It's like the center section of the CV won't completely go together. No idea, I fooled with it for at least an hour.
Unread 10-27-2008, 10:29 PM   #141
RockRodHooligan
RockRodHooligan's Avatar
1989 MJ Comanche
When I did mine, there was a little rubber cap in the ball, that had a little spring and a bunch of grease in it, that I had to remove(leaving the spring in the ball), did you do that?
89 MJ:Project: Ground up
96 XJ:Parking lot Pre-Runner
Project: Silverback Ash to ash, dust to dust... Skin to bone, steel to rust... You will be missed.
Penis inches...
Good god man. Indyorv :rofl: d**k and fart jokes. :rofl:
Originally Posted by kyle_craig View Post
Cleanly done bob jobs are so cool.
RockRodHooligan is offline   Reply With Quote
Unread 10-27-2008, 10:46 PM   #142
01MonsterXJ
I just bought the RE HnT for my 01 xj, Now I gotta go to napa and order the spicer part and try and find a junkyard nearby that has a newer xj front driveshaft . Cant wait to get this on!
Unread 10-27-2008, 11:09 PM   #143
dcorn
Yeah, I believe so. I got the spicer CV part and it had a small cardboard tube holding the spring in. I took that out so everything fit together well. I'm going to try and pull it all apart and install the u-joint that I'm having trouble with first, then the inner.
Unread 10-27-2008, 11:12 PM   #144
RockRodHooligan
1989 MJ Comanche
Maybe there is a bit of a difference in doing one with a yoke type CV vs a flange type CV like i did, mine went together pretty easily.
Penis inches...
Unread 10-28-2008, 05:33 PM   #145
GoneWheelin'
Is there such a thing as the "best" SYE for a 1997 TJ with 5" of lift? Thanks.
Obama Redistributed My Wealth And All I Got Was This T-Shirt
Colorado Jeep Club Member #84
USN Jeep Club Hull #137
GoneWheelin' is offline   Reply With Quote
Unread 10-28-2008, 05:37 PM   #146
1990JEEPXJ
1990 XJ Cherokee
check the TJ thread. but i super shorty SYE is available from multiple companies. i think that would work best for a TJ
My POS
1990JEEPXJ is offline   Reply With Quote
Unread 10-29-2008, 02:23 PM   #147
GoneWheelin'
Kewl, thanks.
Unread 10-29-2008, 04:13 PM   #148
01MonsterXJ
Hey, I called napa about getting the spicer part number 211229X for the hack and tap when using a front xj driveshaft and they wanted like 80 bucks. Anyone know of a parts store chain that sells em for cheaper? I was thinking I'd try calling advance auto and a few others but if someone knows where they are cheaper I'd appreciate it. Or someplace online?
Unread 10-29-2008, 07:37 PM   #149
RockRodHooligan
1989 MJ Comanche
hold on, I got mine for llike $45, let me find the post.....
Penis inches...
Unread 10-29-2008, 07:40 PM   #150
RockRodHooligan
1989 MJ Comanche
Alljeep.com: $43
http://www.alljeep.com/oscommerce/ad..._description=1
Penis inches...
