Odd Marking on Brake Drum - JeepForum.com
post #1 of 25 Old 08-27-2013, 06:43 PM Thread Starter
who_datjeep
I've just been overhauling the rear brakes and when I took the drums off I noticed a rough strip in the middle of the drum going along its circumference. There is a slight mark in the middle of the shoes as well now which probably came from rubbing on the drum. I have replaced all hardware and both wheel cylinders. I have not tested it yet and I have not put the drums back on. What might be the problem? Is this normal?
Also: When I was putting the star/self adjusters back on I noticed a stamping on the center shaft that said L on one and R on the other. L is for the driver side and R is for the passenger side right?
I saw on another thread that you need to center the shoes? Is this true or necessary?
Look here:
Originally Posted by Jeepster83 View Post
To properly adjust rear drums you're going to have to install, remove, and reinstall your drum several times. You go through the normal process of turning the adjuster to move the brake shoes out (closer to the drum) but I didn't know you had to do anything with the brake pedal to properly seat the shoes.
Adjust as normal feeling for drag while turning the drum. You want just a little bit of drag as the drum turns. Then, with the drum reinstalled, you go inside the Jeep and stand on the brake pedal one or two times to center the shoes in the drum and go check the drag again. You'll notice there isn't as much as there was just a second ago. Readjust the brakes and stand on the pedal again. You might have to do it 3 or 4 times but it's getting done right. Repeat the same thing on both sides and go see how much better the pedal feels after you recheck your fluid reservoir. You get immediate brake response and much better peace of mind if you're driving any precious cargo like your kids.
Hopefully this will clear up any confusion with adjusting drums as I believe this applies to any hydraulic drum brake setup. My pedal is nice and high where it belongs and even very light pressure on it will gently slow me down to a stop from 30-35 mph on my 33" tires.
Kevin
Here's a picture of the drum:
who_datjeep is offline
post #2 of 25 Old 08-27-2013, 08:17 PM
M35A2
1995 XJ Cherokee
It had a failure at some point in it's life. If it were me, I would just buy drums and call it good.
Volunteer, American Society of Military History. http://tankland.com/
Just got a 1989 YJ too!
M35A2 is offline
post #3 of 25 Old 08-27-2013, 08:33 PM Thread Starter
who_datjeep
Yeah that's what I was thinking. The problem is I supposedly just had the drums machined a year ago along with new shoes.
Is it better to get new drums or machine these? I know there is a maximum allowable diameter on drums and I don't know if these have already been maxed out.
If I get new drums will I need new shoes too? What do you think caused the drums to wear like this?
post #4 of 25 Old 08-27-2013, 09:16 PM
AZ Jeff
2014 JK Wrangler
The photo is not real clear, but the center section of the drum looks heat checked to me. If that is the case, the drum is trash and needs to be replaced. Get new shoes as well. They are cheap.
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #5 of 25 Old 08-27-2013, 10:25 PM
M35A2
1995 XJ Cherokee
^^^ this, brakes are inexpensive, a pita to do the rears, but it's something to do all the way correctly, not half way. Remember, it could be your loved one in the car next to the guy that did a half azz brake job.
M35A2 is offline
post #6 of 25 Old 08-28-2013, 06:50 AM Thread Starter
who_datjeep
It doesn't really look like heat checking since those aren't cracks. It looks more like surface rust. A year ago I had my brakes replaced at Ford Idiotlane and they said they machined them. Is it possible they machined it wrong? I should argue that they destroyed my drums and shoes and make them reimburse me for replacement. Or get a refund.
Could y'all clarify if I need to center the shoes once I get the drums on too? I quoted it in my first post.
Thanks,
Kevin
post #7 of 25 Old 08-28-2013, 07:47 AM
mayeni
1992 XJ Cherokee
I dont know what you mean about center, but you need to ajust them through the back, once you get the drums on.
mayeni is offline
post #8 of 25 Old 08-28-2013, 07:53 AM Thread Starter
who_datjeep
Read the quote in the original post.
post #9 of 25 Old 08-28-2013, 08:00 AM Thread Starter
who_datjeep
It says to stand on the pedal after you adjust them and then adjust them again. Supposedly this seats the shoes?
post #10 of 25 Old 08-28-2013, 08:07 AM
gs69350
Pushing the brake pedal will help "center" the shoes to the drum and may get you a slightly better adjustment. That said, I've done dozens of drum brakes (including front) and never did that step, and never had a problem. It'll take you an extra minute, so do it if you want. If your adjusters are working properly, backing up and hitting the brakes a couple times will accomplish the same task.
1998 Jeep Grand Cherokee 5.9 Limited - Stone White - Stock for now.
<-- 5.9 Owner's group on FB.
gs69350 is offline
post #11 of 25 Old 08-28-2013, 08:11 AM Thread Starter
who_datjeep
Thanks man that really explained it.
Do you have any idea what the problem with my drum is?
Kevin
post #12 of 25 Old 08-28-2013, 08:18 AM
gs69350
Kevin
Its hard to tell from the picture, but it looks like something got wedged between a shoe and the drum. Can you feel it with your fingernail? If there are no signs of heat cracks, I'd just have it cut and re-use it.
And to give yourself a future project, start hitting some junkyards and find a ZJ with rear disc and gather some parts for a rear disc swap
gs69350 is offline
post #13 of 25 Old 08-28-2013, 08:30 AM Thread Starter
who_datjeep
It's about even with the rest of the surface, just a little rough. There are no cracks. By cutting do you mean to get it turned again?
I've been to almost every junkyard in Houston when I was looking for some seats and most all jeeps are stripped to the frame....or unibody. I kinda like the old school factor drum brakes give though. But for sure, it is sooo much easier working on discs.
If y'all need more pictures let me know and I can take some. Let me know at what angle y'all want it.
post #14 of 25 Old 08-28-2013, 10:06 AM Thread Starter
who_datjeep
Anyone?
post #15 of 25 Old 08-28-2013, 10:34 AM Thread Starter
who_datjeep
I meant it is easier to work on discs.
adjust drum brakes , adjuster , brake shoes , cherokee , drum
