OBD-II Port won't communicate - JeepForum.com
post #1 of 18 Old 02-05-2010, 02:26 PM Thread Starter
CV8Mate
I recently went to get an inspection and I ended up failing due to the fact that my OBD-II Port will not communicate. I then took the dash apart to investigate and learned that the previous owner removed the check engine light. I replaced it and now the light stays on. The jeep has been running well. I have had a couple of rare instances where the car has hesitated a little when it's cold.
While doing a little searching I saw something about crank positioning sensors not allowing the OBD-II port to be read, but I'm not having any of the other symptoms.
CV8Mate is offline
post #2 of 18 Old 02-05-2010, 02:35 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Originally Posted by CV8Mate View Post
... the previous owner removed the check engine light. I replaced it and now the light stays on.
CEL light on is a symptom. Download the CEL codes and fix the problem(s) the codes refer to.
CJ7-Tim is offline
post #3 of 18 Old 02-05-2010, 03:18 PM
jdearmitt
He can't read the codes because the scan tool won't connect to the vehicle..
'01 Black Limited-Build in Process
'96 Green Sport-Totaled but Bought Back
jdearmitt is offline
post #4 of 18 Old 02-05-2010, 03:39 PM
CJ7-Tim
CJ7-Tim's Avatar
On a 1996 can't you use the key on-off-on procedure to get the CEL light to display trouble codes ?
OBD-II ports not communicating with a code scanner when caused by the CPS is because the CPS has failed. If the CPS is failed, the engine will not run.
Try another brand or model of code scanner. Try a different Emissions testing station.
CJ7-Tim is offline
post #5 of 18 Old 02-05-2010, 06:30 PM
tjwalker
It's the crank sensor!
tjwalker's Avatar
I think it should work on a 96.
Here is a link to the key-on, key-off procedure. Worth a try. You need to get to those codes!
Computer codes
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is online now
post #6 of 18 Old 02-16-2010, 06:47 AM Thread Starter
CV8Mate
I still can't pull the code. The OBD-2 plug wouldn't read at the Chrysler dealership either. They had no clue why and wanted 150 bucks to "investigate". I also tried to do the key on-off-on procedure and it didn't work.
CV8Mate is offline
post #7 of 18 Old 02-16-2010, 08:55 AM
theglowingbus
1997 XJ Cherokee
Check your ground wire that is connected to where the oil dipstick tube is bolted to. It should be a ground coming out of a wiring harness. This was the ground for my obdII connector on my 97 it should probably be the same for your 96. I had the same symptoms as you also.
theglowingbus is offline
post #8 of 18 Old 02-16-2010, 10:18 AM Thread Starter
CV8Mate
Thanks, I'm going to check this out later today. Did you have any other issues solved by this? I am having an issue with the headlight going out and the turn signal arrows and high beam dash indicators go on. I am trying to figure out if this is a related issue or separate problem.
CV8Mate is offline
post #9 of 18 Old 02-16-2010, 10:55 AM
theglowingbus
1997 XJ Cherokee
I don't remember a problem with headlights or turn signals although i also don't remember trying them in that period of time, but i do remember that every time i tried to plug in a scanner the airbag lights would go on and some other dash lights and sometimes the tach wouldn't work either.
post #10 of 18 Old 02-16-2010, 11:44 AM Thread Starter
CV8Mate
I just check the ground wires attached to the dipstick. They are all intact and don't appear corroded.
CV8Mate is offline
post #11 of 18 Old 02-16-2010, 11:51 AM
PhilipJ
PhilipJ's Avatar
I can't pull any codes from my XJ either. The scanner will initialize the connection okay but will freeze halfway into pulling the codes. I know the scanner works because it's worked fine on friends' vehicles.
I get a CEL maybe every other month but it only stays on for a day and then goes away again.
PhilipJ is offline
post #12 of 18 Old 02-16-2010, 01:53 PM Thread Starter
CV8Mate
Does the car run fine while the check engine light is on?
CV8Mate is offline
post #13 of 18 Old 02-16-2010, 02:16 PM
PhilipJ
PhilipJ's Avatar
Yep, runs like a champ. It's probably just from me not cranking the gas cap back down enough clicks.
PhilipJ is offline
post #14 of 18 Old 02-16-2010, 03:56 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Friend of mine at the dealership said to disconnect CPS before hooking up scanner/DRB if you are experiencing a lack of communication problem.
cruiser54 is offline
post #15 of 18 Old 02-16-2010, 04:07 PM Thread Starter
CV8Mate
Thanks, I will give that a try as soon as I get home.
CV8Mate is offline
cel , obd-2 , obd-ii
A/C, which port is low pressure Ex-Jay XJ Cherokee Technical Forum 3 04-30-2013 08:20 PM
OBD II does not communicate spdnjoe XJ Cherokee Technical Forum 6 11-04-2009 04:42 PM
port and polish? jackdup XJ Cherokee Technical Forum 6 09-30-2008 07:18 PM
NYC port authority 9/11 XJ tozier9 XJ Cherokee Technical Forum 9 05-29-2007 10:47 AM
Port match or not? Steve88XJ XJ Cherokee Technical Forum 6 02-19-2007 12:10 AM
