o2 sensors - JeepForum.com
post #1 of 2 Old 04-15-2017, 05:57 PM Thread Starter
anony
o2 sensors
My Check Engine Light has started to illuminate with a P0132 DTC.
Started to occur after crossing a dip along the ocean beach. I didn't slow down when crossing dip produced by water run-off.
A code P0132 may mean that one or more of the following has happened: The oxygen sensor heater circuit is shorted out The wiring to the sensor is broken / frayed (less likely)
Possibly a wire or connection was jarred loose or the sensor just went bad as it's stuck at a 1 volt reading from an OBD2 scanner.
__________
I'm wondering which brand(s) of o2 sensors are currently considered to be any good for use with the XJ 4.0L?
I remember when purchasing the current front and rear NTK O2 sensors a couple years ago, the warranty was for 50,000 miles.
Currently NTKs o2 sensor warranty is for 60 days and the online store for the NTK o2 sensors purchased ~2 years ago. "No longer covered under the manufacturer's warranty."
anony is offline
post #2 of 2 Old 04-15-2017, 07:55 PM
bluejunior
bluejunior's Avatar
__________
NTK is the preferred brand, they were the OEM. ~25/sensor on rockauto. If you do go with something else, stay away from Bosch. They're known to cause issues
Lifted, Locked, Stiffened
bluejunior is offline
