O2 sensor fail (P0161) Where is sensor? - JeepForum.com
post #1 of 6 Old 01-18-2011, 03:19 PM Thread Starter
nerdkiller
I have the reading from autozone. Here's the following:
aa1 - Oxygen sensor defective
aa2 - Pooor connection at Oxygen sensor
aa3 - Check circuit-fuse
For a non technical person how can I determine the solution. I already reset the CEL and it came back a few hours later. I found this fuse diagram: http://www.lunghd.com/Tech_Articles/...tification.htm
But not sure which is which.
Aside from checking the fuse where do I check the O2 connection?
I assume if those 2 dont solve it then the sensor itself is defective.
I'm still within the used car warranty but don't want to drive an hour or more just to have someone else change a fuse or jiggle a connection.
thanks all,
Nick
nerdkiller is offline
post #2 of 6 Old 01-18-2011, 03:22 PM
carguy68ssrs
1977 CJ5
If it falls under warranty any Jeep dealer should fix it
carguy68ssrs is offline
post #3 of 6 Old 01-18-2011, 03:37 PM Thread Starter
nerdkiller
Look's like sensor #2 based on the AZ print out. See the attached scan.
post #4 of 6 Old 01-18-2011, 04:11 PM Thread Starter
nerdkiller
Didn't buy it from a jeep dealer. It just falls under the New York State 30 day used car return warranty. If the place was nearby I'd go over there and let them check, but with average traffic it's over 2 hours roundtrip on a week day.
Should be a simple fix, or at least easy to rule out the fuse and the o2 connection right? Long as I know where to look?
post #5 of 6 Old 01-18-2011, 04:45 PM
Holder350
1995 XJ Cherokee
Knowing what year XJ we are working on would be helpful.....but the fact that it is OBD2 tells me its probably above a 97.....I'm going to guess 99
The O2 sensor fuse is in the PDC....and it is fuse #24
The upstream and downstream heaters are both controlled by that fuse, so I doubt its bad....but it never hurts to check.
95' XJ Country - Stock Skids - D30/D35 Limited Slip - 3" Lift - 31x10.50R15 - 4.0 HO - AX15 - NP231
98' XJ Classic - D30/C8.25 - 4.5" RC Lift - 33x12.50R15 - 4.0 HO - AW4 - NP231
Originally Posted by Azzy View Post
You can tell the character of a person in how they treat someone who can do nothing for them.
Holder350 is offline
post #6 of 6 Old 01-18-2011, 05:30 PM Thread Starter
nerdkiller
[QUOTE=Holder350;10809118]Knowing what year XJ we are working on would be helpful.
It's a 2000 w/ 94k miles. Thanks, I'll check fuse. first.!
Check Engine Light - 02 sensor voltage too high bank 1 sensor 2 billbarr100 XJ Cherokee Technical Forum 15 05-19-2010 04:04 PM
Pulling VSS, Cam Position Sensor, and Bank 1 Sensor 2 Codess 9Classic8 XJ Cherokee Technical Forum 7 03-09-2009 03:43 PM
TPS sensor, Coolant temp sensor, and 02 Sensor fail kadetklapp XJ Cherokee Technical Forum 2 09-07-2008 02:48 PM
halls effect sensor or camshaft position sensor? mackg@goodweb.o XJ Cherokee Technical Forum 4 07-13-2007 07:23 AM
P0138 Oxygen sensor high voltage, bank 1 sensor 2 Back2Basics XJ Cherokee Technical Forum 3 08-03-2004 12:33 PM
