Nut and bolt material - JeepForum.com
post #1 of 8 Old 03-12-2017, 07:06 AM Thread Starter
dented
In general what nuts and bolts should we be putting in our vehicles?
I broke a bolt on my valve cover so I went to Lowes and bought the correct size. I think its galvanized steel.
I had to remove my a bolt from my shock and it was so soft the nut and bolt stripped right away.
What is best?
What should be avoided?
dented is offline
post #2 of 8 Old 03-12-2017, 08:25 AM
desbennett004
Bolts usually have a number stamped on their heads if they are any good. Grade 5 is a good general purpose grade. Grade 8 is pretty heavy duty, and Grade 10 is what you would use on suspension parts, like leaf spring anchor bolts.
Sent from my SM-N900W8 using Tapatalk
desbennett004 is offline
post #3 of 8 Old 03-12-2017, 11:05 AM
Timo_90xj
Timo_90xj's Avatar
Grade 8 on the SAE- grade bolts is certainly good enough for anyhthing on the suspension parts. Grade 5 for most other stuff
If you are using metric, ISO class 10.9 us what ypu would use on suspension/ brake parts. Class 8.8 for most other stuff.
***Under construction***
Timo_90xj is offline
post #4 of 8 Old 03-12-2017, 05:02 PM
jay-h
Grade addresses strength issues. Corrosion needs sometimes be considered as well. Galvinized is helpful but since it the zinc may be thick, finish is not so good. Stainless is good, especially if you're going into a stainless nut. Stainless into carbon steel or iron does not work as well because corrosion can spread from the steel part.
Anti seize compound is usually a good choice.
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
97 Grand Cherokee (ZJ)
87 MB 560SL roadster
jay-h is offline
post #5 of 8 Old 03-13-2017, 05:35 AM
Timo_90xj
Timo_90xj's Avatar
Generally, there really are no reasons to use stainless steel mounting hardware on vehicles - not even if vehicle is used on area where road salt is spread extensively. High quality galvanized/ zink passivated bolts, nuts & washers, and high quality anti-seize or grease is all you really need in most cases.
Stainless steel hardware needs to be used in highly corrosive environments, like sea water, or when the mounting hardware or parts need very high anti-corrosion properties for other reasons.
post #6 of 8 Old 03-14-2017, 01:37 PM Thread Starter
dented
Thank you
dented is offline
post #7 of 8 Old 03-15-2017, 12:15 AM
BagusJeep
1981 CJ7
If you go for stainless steel, use gr 316 bolts and 304 nuts and isolate from any carbon steel. The different hardnesses will prevent galling. Yes, even stainless has nasty tricks and the additional cost is not worth paying
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #8 of 8 Old 03-17-2017, 07:17 PM
KF4SQB
1994 XJ Cherokee
As has already been said, stainless should be avoided unless there is a real need for corrosion resistance, or for extremely high temperature applications (however, NOT recommended for exhaust manifold applications, due to strength and galling issues). The stainless steel bolts that you commonly find in places like hardware stores are actually mechanically only a tiny bit stronger than a standard grade 2 bolt.
4-wheeling: because football, basketball, baseball, and golf only require one ball!
Confidence: The feeling you get just before you fully understand the situation!
KF4SQB is offline
