np231 wont go into 2h??? - JeepForum.com
post #1 of 6 Old 09-22-2013, 11:05 PM Thread Starter
RjJeeps
1990 XJ Cherokee
Hey guys, my dad put a np231 tc out of a 99 xj into his zj and he then installed a sye. Now even when the linkage is in 2h, the tc is engaged in 4h?? What the heck? Please any info or comments regarding the problem would be awesome.
Thanks
RjJeeps is offline
post #2 of 6 Old 09-23-2013, 01:47 AM
sAe23
1995 XJ Cherokee
Was he replacing a 231 or 242?
Is he sure the linkage is hooked up correctly?
sAe23 is offline
post #3 of 6 Old 09-23-2013, 09:45 AM
psychoteen101
Linkage is probably adjusted wrong. Try disconnecting it and shifting it by hand to make sure it engages into 2wd. If it does, adjust the linkage accordingly.
1996 Jeep Cherokee- Project-- Rusty's 8in long arm, SYE kit, Teraflex driveshaft, Cragar soft 8's 15x10 with 33x12.5 Firestone Destination MT's, Eaton Tru Trac in the front
psychoteen101 is offline
post #4 of 6 Old 09-23-2013, 10:10 AM Thread Starter
RjJeeps
1990 XJ Cherokee
He replaced a 249 and had a shop install the SYE
RjJeeps is offline
post #5 of 6 Old 09-23-2013, 10:13 AM Thread Starter
RjJeeps
1990 XJ Cherokee
He unhooked all the linkage and moved shift arm completly into 2H and left it unhooked, but still 4H is still engaged..
Could they have installed the SYE incorrectly????
RjJeeps is offline
post #6 of 6 Old 09-23-2013, 11:16 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
There is no common 231 problem that causes that. You should be talking with the shop that did the SYE install about getting it to work correctly.
CJ7-Tim is offline
sye , transfer case
