-   -   np231 wont go into 2h??? (http://www.jeepforum.com/forum/f11/np231-wont-go-into-2h-1613785/)
RjJeeps 09-22-2013 11:05 PM
Hey guys, my dad put a np231 tc out of a 99 xj into his zj and he then installed a sye. Now even when the linkage is in 2h, the tc is engaged in 4h?? What the heck?:confused: Please any info or comments regarding the problem would be awesome.
Thanks
sAe23 09-23-2013 01:47 AM
Was he replacing a 231 or 242?
Is he sure the linkage is hooked up correctly?
psychoteen101 09-23-2013 09:45 AM
Linkage is probably adjusted wrong. Try disconnecting it and shifting it by hand to make sure it engages into 2wd. If it does, adjust the linkage accordingly.
RjJeeps 09-23-2013 10:10 AM
He replaced a 249 and had a shop install the SYE
RjJeeps 09-23-2013 10:13 AM
He unhooked all the linkage and moved shift arm completly into 2H and left it unhooked, but still 4H is still engaged..
Could they have installed the SYE incorrectly????
CJ7-Tim 09-23-2013 11:16 AM
There is no common 231 problem that causes that. You should be talking with the shop that did the SYE install about getting it to work correctly.
The time now is 03:18 PM.
